Old 11-11-2006, 12:30 PM   #1
Need battery isolator for my TV?
My TV is a 05 Dodge Diesel 4x4 with a tow package. Do I need to install a battery isolator or is there a system in place either in my 91 AS or the Dodge that isolates the two systems already? Thanks
ldetsf is offline   Reply With Quote
Old 11-11-2006, 01:01 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Meager as umbilical recharging can be while underway, are you asking about the opposite situation; ie, parked for the night with umbilical attached and you don't want to draw down your TV battery?
5 meter Langford Nahanni
Old 11-11-2006, 01:34 PM   #3
Just wonderng if anyone knows if my 91 AS or my 05 Dodge with tow package has an isolator built in already or if I need to get one. If I recall correctly, if you don't have one, then the AS is always drawing from the TV as well as itself whether driving or not. Thanks
Old 11-11-2006, 02:27 PM   #4
Tinsel Loaf's Avatar
Most tow packages isolate the tv when the key is off. Put a amp meter on the hot tv battery while the key is off and turn something on in the Airstream that draws some current and take a measurment. Then turn off the airstream current and measure again. You will find the answer.
Tinsel Loaf is offline   Reply With Quote
battery isolator/relay Honkity Hank Classic Motorhomes 11 11-18-2010 09:00 AM
Battery Isolator wa3vez Mechanics Corner - Engines, Transmission & More... 5 09-02-2004 12:27 PM
battery isolator kooblekidz Airstream Motorhome Forums 5 08-28-2003 06:04 AM
Battery Isolator thenewkid64 General Motorhome Topics 20 01-12-2003 09:00 PM
Battery Isolator shelocta Airstream Motorhome Forums 1 10-29-2002 10:32 PM
