Old 05-31-2009, 05:19 AM   #15
richinny's Avatar
2011 34' Classic
i'm with terry, it soulds like a pressure leak. you might try filling the overflow tank and leaving the cap just loose enough not to build pressure. it should get you to the mechanic without overheating and damaging the engine.
Ricky
Old 05-31-2009, 06:31 AM   #16
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
First thing I would do is Take it to a competent mechanic. He will have a pressure tester that is put on in place of the radiator cap . It has a pump and a gauge. With the system full of coolant he will be able to cause a leak by applying pressure to the system. My first guess was Thermostat. Second would be waterpump. Radiator caps do go bad especially on a 95. Yes coolant tanks are plastic and do crack .
Id still take it to a competent mechanic and have it checked out.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 05-31-2009, 06:34 AM   #17
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
A pressure test AND another test that checks for combustion gases in the cooling system will most likely show a blown head gasket. Hopefully my diagnosis based on your described symptoms is incorrect and it will be something much less serious.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 05-31-2009, 09:15 AM   #18
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Originally Posted by Inland RV Center, In View Post
Could it possibly be a fan clutch?
Good call Andy!
Ahab is offline   Reply With Quote
Old 05-31-2009, 10:36 AM   #19
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Lots of possibilities! I'm going to have it towed over, we have towing insurance, might as well use it rather than risk hurting the engine if it overheats again.
In December/January we had a bad sensor and a complete brake job, and then at the same time they replaced the radiator cap. I drove it a couple days and the new radiator cap apparently pressurized the system and caused a weak spot in the radiator to blow out, so it started leaking antifreeze. So it went back to the mechanic for a new radiator and hoses. So we dropped about $2k on it in two months. Dave's Dad said not to spend any more money on it since it's so old (1995), but you know it just nickle and dimes you, where you go 'well it's been a good truck, we might as well fix this', then another thing and another thing. Then it's like 'well now we've got $2k invested in repairs on it, and it's got new brakes'. If this is anything big it might be time to call it quits and replace it. We'll just have to see what the mechanic says.
Stephanie
Old 05-31-2009, 10:42 AM   #20
Kevin245's Avatar
Sounds like you're on the right path Stephanie. We have pool going, so let us know what the culprit is.
I have a 97 Ford F150 that has 306,000 miles. It was my daily driver until the alterantor went our at 295,000. It's now my "Weekend" ride. It sure beat the heck out of making truck payments.
Regards,
Kevin
Eleanor Roosevelt
Old 05-31-2009, 10:51 AM   #21
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Thermostats are cheap, water pumps used to be, but maybe not so much anymore. Head gaskets are not cheap (the gasket is cheap, getting to it is not, and once you have the head off, maybe it'll be time for a valve job). I appreciate your problem and unfortunately we can't usually predict just the right moment to sell a vehicle. Whatever is broken, it has to be fixed either to drive it or to sell it. At some point everyone gets sick of fixing it and either sells it, sends it to the crusher, or like they do where we live, park it somewhere out back alongside all the others and forget it.
If you sell it, you can advertise "new brakes, radiator!" Good luck. Check Edmunds and Kelly Blue Book for what your van is worth.
I gave up on fixing old cars and trucks some years ago because it hurt my body too much and bought new ones. Now I have an Airstream and I'm fixing a new vehicle. I don't understand how that happened.
Gene
Old 05-31-2009, 11:27 AM   #22
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Well, want a '94 1 ton Dodge van cheap? Has a new rebuilt transmission!
Just needs a new AC rebuild.. oh.. about $1700 to fix!
Sigh... I know what you mean... where do we draw the line...
Marc
Old 05-31-2009, 12:14 PM   #23
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Marc, I think we're both on the short end of the stick, when I was a kid we considered a 20 year old vehicle to be 'classic', and our vans are both just a few years away from that!
I just looked at new Ford vans on the Ford website - looks like someone beat them with an ugly stick! That grill is the most unattractive thing I've ever seen, and it just looks like it's stuck on the front end of the same van as always. Holy Cow, what were they thinking?!
Stephanie
Old 05-31-2009, 01:03 PM   #24
Master of Universe
Gene's Avatar
Steph, how much can you do with a van? 2 or 4 headlights; ugly or uglier grill, curved or flat windshield, but always is a really a big box.
I'm hoping it's the thermostat and you find a good deal on a new van or truck. I read they're selling certain US brands below cost. That depresses the used vehicle market, but I expect a 14 year old van's value doesn't change much no matter what's happening in the market.
Gene
Old 06-01-2009, 09:12 PM   #25
yakman's Avatar
2007 25' International CCD FB
Gahanna , Ohio
My money is still on a failing water pump. For as easy read, check this out. Autoclinix.com - Ford Econoline 5.0L / 5.8L Water Pump Repair
Cheers,
yakman
yakman is offline   Reply With Quote
Old 06-01-2009, 11:29 PM   #26
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
The word from the mechanic is that the new radiator blew out. Luckily it's under warranty still so the parts and labor are covered. Once they get it replaced they'll check to make sure there wasn't any other damage.
Stephanie
Old 06-02-2009, 07:13 AM   #27
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I don't know where it's at, but I know its the thermostat...we were going thru California, and started loosing power to the vehicle...we thought the radiater had a leak and were using the CB to get truckers to drop off water...we took it out and it worked fine after that.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 06-02-2009, 09:38 AM   #28
1975 Argosy 26
1963 24' Tradewind
Yup! How much lipstick can a pig get? My '94 Dodge looks the same as the 70's Tradesman, with a different grille! The Sprinter is really the only new game in town... if it came in a lower height, I'd buy one (it's even higher in the lowtop version than my 1 ton!! I barely fit in parking garages as it is...).
I dunno - I think I can replace the section of piping that needs to be replaced on the AC myself.. so I might hang on a bit more... still running!
Can't believe the radiator blew out! Where was that one made?
Marc
Need Advice On Purchasing A New Tow Vehicle ryan b Tow Vehicles 22 09-10-2007 06:55 PM
Tow vehicle advice needed.... crazylev Tow Vehicles 86 04-27-2007 06:11 PM
Tow vehicle advice needed! snackdragon Tow Vehicles 9 08-24-2005 07:52 PM
Wiring advice for tow vehicle Taffy Mechanics Corner - Engines, Transmission & More... 0 09-15-2004 06:00 PM
Need advice on tow vehicle GMC 3/4 van 63overlander Tow Vehicles 8 03-04-2004 07:41 PM
