Old 08-25-2015, 04:33 AM   #15
Flying Cloud 27
smlbob's Avatar
2015 27' Flying Cloud
Union Hall , Virginia
Originally Posted by greghoro View Post
How timely, we will be going that way in a month and i wondered about that grade and how my Sequoia would handle it. Given we have an equivalent Engine/Drivetrain combo and same size trailer, I have a good idea of what to expect.
Why is it you always keep your gear in 5th rather than Drive (and 6th) and let the Tow Haul handle the shifting? I understand on the grades but why also on the flats? I've seen this discussed on the Tundra forums but have not gotten a good understanding of the rationale.
Greg
Greg....with my Sequoia, I only use my shifting setting on grades. The rest of the time I keep it set in Drive, use the Tow Haul always, and rarely use the 4WD at all. RPMs will peak out on the steepest climb, but no strain for the most part.
smlbob is offline   Reply With Quote
Old 08-26-2015, 06:46 AM   #16
1965 mustang's Avatar
Stoughton , Wisconsin
Originally Posted by KJRitchie View Post
That looks to be an excellent location. Did you have to remove that area to mount the controller? Did you have to lengthen the harness that connects the controller to the plug under the dash by the driver's door?
Kelvin
That pocket is easy to remove, carefully insert a thin putty knife around its edges to undo its clips. Drill a hole in the back of the pocket for the wires to go through. You will have to make the harness longer.
1965 mustang is offline   Reply With Quote
Old 08-26-2015, 06:34 PM   #17
Goal15's Avatar
Dallas , Texas
Originally Posted by 1965 mustang View Post
I mounted my brake control in the dash under the climate control.Attachment 246207
What year is your tundra ?
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 08-26-2015, 07:01 PM   #18
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Great Video !
BTW I mounted my P2 controller in the face of the dash below the Traction button in my '14 Tundra SR5 Double Cab with bench seat. I posted on TundraTalk.net how I did it.
I use the S mode all the time and find myself in 4 the majority of the time and 5 in the flats. I only use 6 when not towing.
I love the way the Tow/Haul mode changes the throttle response and shift points. I use it when towing in town and getting on the Hwy., not so much in 5 as it wants to shift a bit sooner under load.
ID:	246431   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 08-26-2015, 08:31 PM   #19
It's a 2011
Old 09-08-2015, 07:21 AM   #20
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Just came back to Missouri over this same pass through the Ike tunnel. No issues at all with the Tundra. We are only pulling a 23FB though.
I kept it in S 5 almost all the time, and used the cruise control. My back is acting up, and using the cruise helped my comfort, quite a bit.
We went out on 24 through Colo Springs, then over to Buena Vista and up to Leadville. I was getting over 10 mpg with some tanks better than others. I try to set it at 67 and ignore it, but I did get going a little faster from time to time depending on traffic. Not sure if the racks and kayak cut into our mpg or not.
Turquoise Lake
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Winterizing-- do I have what it takes?! By the Bay Winterizing, Storage, Carports & Covers 46 08-26-2010 08:35 PM
Hurricane Ike, In Harms Way Crusty Off Topic Forum 54 09-24-2008 05:47 PM
Ike & escapees.com website. Status? al66pine On The Road... 2 09-15-2008 09:03 AM
Fishing line takes out brakes? LI Pets Brakes & Brake Controllers 16 02-28-2007 08:05 AM
