in my truck is mis-behaving again. For the third time my limited slip has failed. The first two times it was replaced under warrenty. Now I am faced with having to pay to have it replaced myself. It is a Ford manufactured rear axle. I was hoping it was Dana. No luck. The only replacement parts for the limited slip are available from Ford. Parts $200, Labor at least $500. It is a "10.5". I talked with a local 4 wheel shop and found I can get a manually locking rear end much like the front. It works under air pressure. This is much like ones you see in rock crawlers. The only problem. cost around $1500. Double that of replacing my limited slip.
Any one else have a limited slip rear end and having as many problems as I have?
Ford says--- Build Ford Tough!!! What they don't say is that means it's a piece of cr@# that will fall apart as soon as the useless warrantee runs out. That's what "Ford Tough" really means.
Michelle, I know you're not a truck mechanic, but do you know what parts failed? There's not a lot there, as far as the limited slip, some springs, a couple of contact plates, and a set of clutches.
Terry,
I have seen the clutch pack the last time they replaced it. According to the parts diagram for the Limited Slip there is about a dozen parts in the package including shims.
I have lost faith that any one can install and adjust it properly. They seem to be adjusting it for pavement use. I need it for loose dirt, slick mud and loose gravel.
My car has better traction control that my truck!
I did not start this thread to have my trucks warrenty or quality based. The Limited slip is the only problem I have had in the 70,000 miles of driving her. Most of it towing my Classic 31. It has seen heavy service and performed well. Flame elsewhere please.
Is your L/S a clutch pack, or electronically locking? I had a local shop (They have a couple of locations in the U.S.... Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services.) put my clutch pack in... it's been a lifesaver, and reliable too! What part of it is failing? Is it the bearings? If the pinion angle isn't right, it will burn up the bearings real fast (my Astro had this issue). If it's the clutch packs, I'm not sure why. I do know I've got synthetic gear oil in mine..
I'm not sure you'd want a air locker.. I believe they LOCK for good, and don't allow any side/ side differential.. which would be fine in snow and ice, but not usable anywhere else. I think a Torsen gear pack would be great, but also expensive (I think it was around $1000 4 years ago).
I know your truck warrentee is out, but how long has it been since the diff's been replaced? Usually there's a 1 yr warrentee on these kind of things...
Hi, I think I explained this before. Limited slip is just what it says, LIMITED. If the traction loss between the two wheels is around 250lbs or less, this will allow the other wheel to help keep you moving. [wet street, ice, sand, or snow] But if one wheel is stuck, and you spin the other wheel trying to move, you just burned up your clutches. If this is how you are driving this truck, you need something like a Detoit Locker that works with gears, not clutches. This is not a Ford defect. Also I believe Auburn makes a vacuum operated locker that locks solid only when you activate it.
Hi, I think I explained this before. Limited slip is just what it says, LIMITED. If the traction loss between the two wheels is around 250lbs or less, this will allow the other wheel to help keep you moving. [wet street, ice, sand, or snow] But if one wheel is stuck, and you spin the other wheel trying to move, you just burned up your clutches. If this is how you are driving this truck, you need something like a Detroit Locker that works with gears, not clutches. This is not a Ford defect. Also I believe Auburn makes a vacuum operated locker that locks solid only when you activate it.
The nice gentleman (seriously) at Inland Truck in Missoula explained my options. They could replace the Clutch pack. Not an option. They could install the Detroit locker which is a mechanical locking device based on the rotation of one tire and not the other. Noisy and would lock up turn corners. Not an option. He also explained the manual locker. I believe Auburn was the company name but after the price check I didn't remember much else.
The manual locker is what I want. I got my truck up one two wheels about a week ago. one front, one rear. I was stuck until I engaged 4 High which locked the front end. I was then able to back out.
Good luck!
Marc
Marc,
It is a clutch pack. I wish I had electronic traction control like the current F-250s.
For getting to my property out of town I need to able to have true 4 wheel drive if I get stuck. the current situation only gives me two wheel drive in the front. I need the rear to lock up like the front.
The last replacement is well out of warrenty. I don't test the LS often I only know it's non-funtional when I get stuck.
Ford also uses a friction modifier lube that has to be used along with required lube (more than likely synthetic oil) or destriction to the rear-end will occur.
Louis
Louis,
I made sure the friction modifier was installed the last time.
