Old 01-24-2012, 10:46 AM   #29
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Originally Posted by newroswell View Post
Where specifically did you read the tank voids the warranty? Is this something your dealer is pushing? It's common for the CA dealers to ask you to sign a disclaimer that lifting your truck voids drive train and suspension related warranty coverage. But I've never read anything in the truck forums regarding a tank replacement voiding anything.
It is in the 2011 diesel supplement book that comes with the NEW truck. Did you not get one with your new truck?
Give me a sec...I'll try and locate the link.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 01-24-2012, 11:18 AM   #30
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
I have the 5th printing. The only mention of a aux fuel tank is in the trouble shooting section;
If engine cranks but won’t start
Prolonged starter cranking (in excess of 10 seconds) could cause damage to the starter motor.
• Check the fuel gauge. You may be out of fuel. If the gauge shows that there is fuel in the tank, the trouble may be in the electrical system or the fuel system. If equipped with an auxiliary tank, be sure that the tank control switch is set for the tank with fuel and not on an empty tank.
I do see warnings & restrictions on the use of biodiesel though.
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 01-24-2012, 11:26 AM   #31
Chief Chili Cook
newroswell's Avatar
I didn't notice this when I originally read it (because I don't have this option installed) but a dual fuel tank is available from Ford. This must be for the chassis builders, there's no room for another tank under this truck (inside the frame rails).
Old 01-24-2012, 04:43 PM   #32
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
It says somewhere an aux tank could condensate and cause water in fuel, which would be the aux tanks fault....just can't find it.
Shane
TAC ID TX-1432
2011 F250 Clearance/side LIGHT swap... THEPILL Tow Vehicles 33 03-06-2011 02:14 PM
2011 F250 0% Financing THEPILL Tow Vehicles 9 02-18-2011 07:34 AM
