Old 09-21-2016, 06:05 AM   #1
2017 22' Sport
edison , New Jersey
Multiple Tow Vehicles
Hi all. I'm a AS newbie and will be picking up my Sport 22fb in a couple of weeks. I have a question regarding my tow vehicles.
My main TV will be a 2016 land Rover. I'm also planning to use my jeep wrangler unlimited to tow to my storage facility that is local.
The question is, my jeep is about 4 inches higher than the land Rover. Would I have any issues hitching and towing the AS?
2017 Ford Expedition EL
2017 Airstream 22FB Bambi
redvfr02 is offline   Reply With Quote
Old 09-21-2016, 06:08 AM   #2
dasams's Avatar
Marin , California
Not if you set the ball height of the jeep 4" lower than the Land Rover.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 09-21-2016, 06:20 AM   #3
2017 22' Sport
edison , New Jersey
Thanks. I haven't towed anything yet let alone seen the hitch that I'm getting. i'll probably understand it better once visualized.
Old 09-21-2016, 06:26 AM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
You'll likely need two ball mounts due to the differing heights
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 09-21-2016, 06:38 AM   #5
2017 22' Sport
edison , New Jersey
Something like this?
http://www.etrailer.com/Ball-Mounts/...en/AM3410.html
Old 09-21-2016, 07:26 AM   #6
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
If the storage facility is local, why use the jeep at all? Seems like a pain to set up two hitches (and possibly have to buy additional hardware).
BTW, good to see another local AS owner.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 09-21-2016, 08:07 AM   #7
mandolindave's Avatar
Unless the jeep is the longer four door model
I would stick with the tow vehicle that had the longest wheel base and the lowest center of gravity.
Please I don't want to offend jeep owners, who are happy with their choices.or resurrect the same old tired arguments
But I do believe that a shorter wheel based tow vehicle is more prone to being pushed around by a trailer into a jack knife situation.
mandolindave is offline   Reply With Quote
Old 09-21-2016, 08:19 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Since your trailer is single axle, the tongue being high or low will not substantially affect the way the load is distributed on the axle. If it were a multi axle trailer there would be an issue with the trailer being out of level.
Even though a level trailer is best when towing, if it were me, I would not have an issue towing a single axle trailer, only temporarily and only at slow speeds, with the tongue 4" high.
As someone else mentioned, why not use your main tow vehicle every time you tow.
If you use two vehicles for towing, you will need a brake controller and towing mirrors on both vehicles.
Alan
Old 09-21-2016, 04:08 PM   #9
2017 22' Sport
edison , New Jersey
Everyone has great points. The LR is driving by my wife so sometimes it not around. But I will stick with one TV and keep it simple.
Top Ten tow vehicles ?? darkStar Tow Vehicles 34 10-19-2005 09:20 PM
The Mother of all Tow Vehicles! mcneon Tow Vehicles 11 07-13-2004 10:01 PM
Tow/Haul feature on GM vehicles Silvertwinkie Our Community 2 08-06-2003 09:06 AM
tow vehicles paul k Tow Vehicles 96 01-19-2003 09:59 PM
