Old 02-05-2008, 01:32 PM   #1
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
Mud Flap Mounting
I am always intrigued by the innovated solutions derived by this crowd.
What amazing design does anyone have for mounting mud flaps to one’s TV while towing without spending the $250.00 for factory designed models?
The rocks are killing the front of my trailer, and I have found mud flaps I like. I would like to hear of any mounting solutions contrived by folks more inclined to build rather than buy.
Jeff & Cindy
jdalrymple is offline   Reply With Quote
Old 02-05-2008, 01:39 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
mudflaps
I asked this question:......finally ended up with Duraflaps. I like 'em and they save the front of the Airstream.
They look like they could be duplicated easily with a good stiff, yet flexible, sheeting and then a stainless plate at the base for weight and looks.
http://www.airforums.com/forums/f238...cle-29377.html
Old 02-05-2008, 02:30 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
johnhd welded up his own - here and here.
I have Enkay Rock Tamers for my GMC Sierra -- they lift the bar holding the mudflaps higher than John's so there isn't as much space for rocks to sneak through. I've been very successful so far.
Silvertwinkie has a Suburban with Enkay Rock Tamers. The lower body behind his rear wheels sweeps up more than my truck. He's had some rocks sneak through and gotten some dings. He cut up a mudflap from a truck stop store and riveted it to the itty-bitty OEM 'burb mudflaps behind his rear wheels - extended it 4-5" (?) but it's been a long time since I laid eyes on them.
5 meter Langford Nahanni
Old 02-05-2008, 02:37 PM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
We mounted this unit onto our hitch. It was an easy mount, less than $100 and works really well. We too were getting upset over the few stray rocks that bounced over the front rock gaurds on the Safari. The other nice thing was I could drill a quick hole through it for the wiring harness.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-05-2008, 02:54 PM   #5
Rick -- that looks like slitted thick rubber. It must work then. I've heard the hula skirts you see between mohos and toads ain't worth beans.
Old 02-05-2008, 02:56 PM   #6
2005 22' Safari
1960 24' Tradewind
Bob, yes you are correct the grass skirts only look good on Hula-Girls! It is actualy PVC so it it sturdier (sp?) than rubber. I actually installed ours on our hitch in Maine a few days after our Airstream Wedding. Put 3K miles on it and it looks and works great. Bolts right onto the receiver so when we aren't towing no mess no fuss!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 02-05-2008, 03:07 PM   #7
I know my Enkays are a heavy dog to put on. I've got to clamp it on the hitch bar and lift both up together into the receiver. It helps to plan ahead and position carefully.
Old 02-05-2008, 03:08 PM   #8
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
Dura Flaps
I put Dura Flaps on my truck too: Mud Flaps For Pick Up Trucks SUVs by DuraFlap
Name:	F250 DuraFlap.jpg
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 02-05-2008, 03:11 PM   #9
ScottW's Avatar
2007 30' Classic
Hernando , Mississippi
Rick, is that a sto-bought item, or did you mfg it. if you made it, more pics would be appreciated. Thanks
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 02-05-2008, 03:21 PM   #10
jdalrymple's Avatar
Jay , Oklahoma
Thanks for the replies. My main problem is not enough room for any brackets on the draw bar of the hitch. A triangle gusset is welded on the bottom side of the draw bar to brace the ball mount. A factory addition, not mine. This renders any of the factory solutions, or any over-the-draw bar bracket, inoperable.
I was hoping for another creative mounting idea.
Jeff & Cindy
Old 02-05-2008, 03:30 PM   #11
_
I know my Enkays are a heavy dog to put on...
not so much with the newer version...
steel rods and flap attachments iron is replaced with aluminum...
brass center bits replaced with chromed cast aluminum...
much lighter and shinier and 'steamier...
Enkay MudFlaps | System
covered in august 07 here...
http://www.airforums.com/forums/f464...las-35330.html
cheers
2air'
Old 02-05-2008, 03:36 PM   #12
_
...I was hoping for another creative mounting idea.
others have mounted angle iron arms directly to the tv receiver box, UNDER and forward of the hitch opening...
there are several photos of this arrangement in other threads...
then of course there are LARGE/WIDE/METAL/RUBBER flaps that attach at the wheel wells...
i've also seen one piece FULL coverage rubber skirting mounted below the rear tv frame, but ahead of the receiver...
and cloth skirts that run horizontially from tv to trailer (often used with toads and on the al-can trips)
... I have found mud flaps I like. I would like to hear of any mounting solutions...
post a pic or 2 of the ones u like, i'm sure a talented diy guy will post a solution 4 ya...
cheers
2air'
Old 02-05-2008, 05:12 PM   #13
Janet H's Avatar
1964 19' Globetrotter
OlyPen , Washington
Images: 101
cheers
2air'
sa - weet! But we have the older, leaden ones. Sigh... I guess I know what's on the wish list next.
AirForums Custom Search
Old 02-05-2008, 06:25 PM   #14
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I have the new style Enkay's. Pretty happy with them, but they are a little difficult to store when not is use.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 02-05-2008, 07:32 PM   #15
Images: 59
Do you remove the flaps and bars when you take it off the truck?
It's still heavy, but at least it's not six feet wide.
Old 02-05-2008, 07:44 PM   #16
Royce, your wish is my command ! My garage wall has open studs and I store my Rock Tamer at about belly button height so I can walk the Rock Tamer to the wall without bending over. I ripped a piece of fir 2-by so that it would go through the main hole at an angle and not crank the Enkay out of vertical.
Name:	Enkay holder front.jpg
I used a single carriage bolt through this piece. What really keeps my mounting shaft from displacing are a small piece of 2x4 fastened well above and below the fir shaft. This is right behind my garbage cans in the garage and very out of the way.
Name:	enkay holder vert.jpg
Old 02-06-2008, 04:36 AM   #17
2005 22' Safari
1960 24' Tradewind
Scott- After the second ding in our AS I was going to make my own then found this one for less than $100 at a RV shop. I believe PPL has them in stock.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 02-06-2008, 05:45 AM   #18
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
I made these mudflaps for less than $50.00
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 02-06-2008, 08:34 AM   #19
Royce's Avatar
Mark,
Good suggestion, I have the Al model and was worried about galling the threads from frequent dissasembly, so havn't taken it apart for storage yet. May start doing that once per year for winter storage. I have already noticed that the two small bolts that holld it on the stinger will work loose in travel. Could just remove the flaps, that would help a lot.
Bob,
Thanks for the photo and storage idea. Really like your simple approach. I may use that idea in the future. For now I leave the entire setup on the Equal-i-zer drop stinger, and just set it on the floor next to the wall. Makes for quite a load at one time.
AIR# 3913
Old 02-06-2008, 09:20 AM   #20
I do the same and just set it below the front of my truck when I'm using the rig frequently during the summer.
Best Price Double Flap Seal Sundance Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 01-31-2008 08:15 AM
Mud flap ground clearance? hazegrey Hitches, Couplers & Balls 4 10-31-2007 08:42 PM
310 MH rear flap Andre Baillargeon Airstream Motorhome Forums 3 09-26-2003 03:00 PM
Mud flaps on an A/S Silvertwinkie Our Community 8 03-10-2003 06:29 AM
Mud flaps on an A/S MH ALANSD Airstream Motorhome Forums 3 03-10-2003 05:58 AM
