Old 02-06-2008, 09:28 AM   #21
ScottW's Avatar
Hernando , Mississippi
Thanks, Rick. A brand name please.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 02-06-2008, 09:32 AM   #22
ScottW's Avatar
Rick,
disregard. I found them on PPL's site. Do they mount like enkays?
Thanks.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 02-06-2008, 12:46 PM   #23
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Originally Posted by CanoeStream
Good suggestions Bob. I seldom take the Enkays off the drawbar. One could mount a square receiver tube on your wall somehow and slip the entire drawbar with Enkay's into the receiver mounted on the wall. At least it gets it off the floor and allows the mudflaps to hang down. Karma coming your way.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 02-06-2008, 10:04 PM   #24
holland , Michigan
You guys are so handy, an idiot like me taking on over 15k/ miles/year just looks at the rock guards daily and counts more dents. The amazing thing is they have taken all the hits. Knock on wood, not one nick in the trailer. I plan to sell every 3 years so new rock guard before the 4 sale sign are in order. Still, your skirts are pretty cool. I wish all the semi drivers would put them on their trucks like UPS did. Makes a huge differenc passing them in heavy rain.
safari 28 is offline   Reply With Quote
Old 02-07-2008, 04:42 AM   #25
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Originally Posted by ScottW
Rick,
Thanks.
Scott-
They bolt right onto my receiver and stay there. Because of the PVC material it is very light weight. I will try to remember to snap a photo tonight when I get home.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-07-2008, 07:08 AM   #26
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Silvertwinkie has a Suburban with Enkay Rock Tamers. The lower body behind his rear wheels sweeps up more than my truck. He's had some rocks sneak through and gotten some dings. He cut up a mudflap from a truck stop store and riveted it to the itty-bitty OEM 'burb mudflaps behind his rear wheels - extended it 4-5" (?) but it's been a long time since I laid eyes on them.
Canoe is right....since doing both, I've been down many gravel roads....and have not seen one ding since.
When we went to the UP, my ma and pa have an SOB towed by a Silverado. He had some rinky dink mudflaps on the rear of the Silverado. It had rained the night before and he had sand, dirt, etc all over the front of his unit. I only had dirty water mist on the front of mine.
The Suburban wasn't too hard to add the mudflaps and to extend them lower, however, my Chevy sedan had no meat in which to fix the flaps onto it. I fabricated some "L" type brackets and with stainless nuts, bolts and washers (with caulk) attached the brackets to the frame and then attached the flaps to the brackets. This also worked very well along with the Enkay before moving to the Suburban. The issue with the 3/4 tonners (at least GM) is that the leaf springs get in the way and **could** make contact with brackets as I have described and that is why I went the other route with the Suburban.
Old 02-07-2008, 07:33 PM   #27
chaimemet's Avatar
2008 31' Classic
Ft. Lauderdale , Florida
Hensley with Rock Tamers?
I have a Sierra 07.5 2500HD and the AS 31 08 is equipped with the Hensley and the bar connector is shaped like an "s". Is there room to mount the Enkay flaps?
chaimemet is offline   Reply With Quote
Old 02-07-2008, 07:44 PM   #28
_
Originally Posted by chaimemet
.... Is there room to mount the Enkay flaps?
almost,
but no.
here is a thread with pics good pics (davidz71s) and a couple of modifications...
http://www.airforums.com/forums/f238...tch-17562.html
hensley USED to offer a stinger that was modified for the nks by adding 1-2 inches of shaft length.
they NO LONGER do this.
instead they have a stinger that is 6 FRIGGIN INCHES longer!
so your trailer will be in a different time zone way back there.
yes you can shorten this ridiculously long stinger and redrill the hole..
but IF you do this, hensley voids the warranty
NOW on the newer nks the routing out of the brass (as david did) is gonna be an issue,
since the center piece is chrome plated aluminum now...
cheers
2air'
Old 02-07-2008, 07:51 PM   #29
CanoeStream's Avatar
St. Cloud , Minnesota
Several people are talking about this subject in 3 posts here:
http://www.airforums.com/forums/f464...tml#post304427
http://www.airforums.com/forums/f464...tml#post314462
http://www.airforums.com/forums/f464...tml#post313772
Especially note that last one and the links to davidz71's pics.
5 meter Langford Nahanni
Old 02-07-2008, 08:50 PM   #30
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
why you need mud flaps.......or not.
This picture shows why you may need mud flaps. If you live round here you can wash the red dirt off...
Name:	Mud flap needed.JPG
ID:	53955   Click image for larger version
Name:	only in Texas.jpg
Old 02-18-2008, 04:30 PM   #31
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
After several good posts and suggestions, and few gin and tonics, I rummaged through my scrap pile and came up with a design that, while I can not claim as entirely my own, is a mixture of several.
Mud flaps from Ebay, $40.00.
I did have to buy a stick of 1”x1” angle at Lowes, and the large U-bolt. That part was a little spendy, but I still have less than $60.00 in the project.
The mount U-bolts to the receiver of the TV, and is very solid. No mods to the TV required. A quick flick of a wrench, and the entire apparatus is in removed, without so much as a hernia. It was simple to build with a hack saw, angle grinder and a cheap wire feed welder. A little spray paint covers a multitude of sin…
As it mounts to the truck side of the equation, it should work with any hitch.
Thanks to all for the suggestions.
ID:	54553   Click image for larger version
ID:	54556   Click image for larger version
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 02-18-2008, 05:19 PM   #32
_
very nice job!
but what's with the blue defects in the mudflaps?
i guess they'll sell anything on ebay...
cheers
2air'
Old 02-19-2008, 08:18 AM   #33
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
towtector
I bought this type as I was concerned about gas mileage and general overspray from under the truck. And I've got this weird thing for UPS trucks.
I am sure the solid rubber stop objects better, but rain water bounces right off. I plan to add two rubber flaps on each side. Or strips of rubber flaps to add strength. Keeping the hairy stuff inside to slow down the slurry.
Love the Enkay hardware. I may try that next.
Mud Flap, Truck Mud Flaps, Ford Truck Mud Flaps, Heavy Truck Mud Flaps made by TowTector
Oh yea, made in America
safari62 is offline   Reply With Quote
Old 02-17-2010, 06:44 AM   #34
"Cloudsplitter"
Thumbs up Me Too...
Also using the Towtector, light weight, easy install, very old fart compatible.
No marks at all on the trailer and oversize rear flaps have prevented any stone chips on the rear 1/4's of the Burb.
Old 02-18-2010, 12:21 PM   #35
TSchleff's Avatar
2005 30' Classic
Omaha , Nebraska
Robert ...
Quick question .. Can you use the Towtector with a Hensley Hitch without modifications? Or is it like the Enkay where modifications are needed?
I have a 09 2500 Chevy Duramax and I noticed on their [Towtector] website they specifically say ..
" Note Caution- under bumper rear exhaust will melt brush strips. "
So that means I have to buy the heat shield as well. That adds another $80.
TSchleff is offline   Reply With Quote
Old 02-18-2010, 01:22 PM   #36
"Cloudsplitter"
Thumbs up
Originally Posted by TSchleff View Post
Robert ...
I have the 8.1 in the Burb, good friend owns the local Mufflerman shop, had him weld on a stainless tailpipe extension off to the side, just behind the r/r wheel.
The only thing I had to do on the Hensley stinger was die grind the welds slightly to get some clearance for the clamp mount. I use a Reese class 5 Tow Beast so that might not be needed on your set-up.
Old 06-03-2013, 06:32 PM   #37
Anchorage , Alaska
Silvertwinkie: I realize this is an old post, but after reading your comments, I am concerned that my 2500 Suburban may not work well with Rock Tamer. I live in Alaska and about to head out on our maiden voyage - and want to protect my Airstream as much as possible! Any additional insights are appreciated!
Cheers!
AKSTRM
hrthelr is offline   Reply With Quote
Old 06-04-2013, 08:04 AM   #38
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
Get yourself a long and wide pair of DuraFlaps and you will be fine....
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 06-04-2013, 08:24 AM   #39
SteveH's Avatar
Common Sense , Texas
I built these for my 2500 Ram and attached them to the hitch receiver (holes already there) because the ones that slip over the draw bar, combined with the weight of the drawbar, are too heavy for my bad back. Two bolts and five minutes and they are off, when desired.
Regards,
Steve
Best Price Double Flap Seal Sundance Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 01-31-2008 08:15 AM
Mud flap ground clearance? hazegrey Hitches, Couplers & Balls 4 10-31-2007 08:42 PM
310 MH rear flap Andre Baillargeon Airstream Motorhome Forums 3 09-26-2003 03:00 PM
Mud flaps on an A/S Silvertwinkie Our Community 8 03-10-2003 06:29 AM
Mud flaps on an A/S MH ALANSD Airstream Motorhome Forums 3 03-10-2003 05:58 AM
