Old 10-03-2015, 07:59 AM   #1
BW1
1991 29' Excella
Rockwood , Ontario
Most Efficient & Capable 3/4 for Towing
Time to get a new truck... have been using my F150 for 3 years now and after many trips through steep grades, the truck is way overworked. Now before you jump all over me, I had the TRUCK FIRST, then the Airstream .
Looking at all 3 makers in the 3/4 ton, I don't really want a diesel since we only pull for about 5 weeks a year, then it is just a truck for regular stuff.
Any comments about V8 power as well as favourable gas mileage from the big three based on your experiences would be helpful.
Towing a '91 Excella 29ft.
Can't wait to weigh out the outcome
BW1 is offline   Reply With Quote
Old 10-03-2015, 08:18 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think Ford, GMC/Chev, and Dodge are all good trucks and very capable of towing your Airstream. We went from a Ford 150 to a Dodge diesel 8 years ago and the difference was astounding. 155000 miles later we are still towing with the "new" truck. I am a "diesel head". If buying new I think you ought to at least look at the possibility of the diesel. My wife drives ours daily and likes it.
Old 10-03-2015, 08:40 AM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I, too, am a "diesel head" and would highly recommend one. I like Fords and would look at them first, but that's just my preference. If you go with a gasoline engine, you'll do fine with any of the 3/4-ton trucks. When I was a kid and after I left home, my dad did a lot of cross-country trailering with 3/4-ton trucks with gas engines. I would be happy if I could get 12-15 mpg with the gas engine while towing. The difference between the 3/4-ton drive train and your current F150 will be quite noticeable.
Good luck with your search.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 10-03-2015, 10:03 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I saw a new F-150 at the dealership with a 3.5 Ecoboost and 2070 lbs of payload capacity. You could say that makes it a 1 ton truck with pretty decent fuel economy, and the boosted engine makes it's torque at a low rpm and keeps it at altitude. And without the extra 2,000 lbs of a heavy duty truck in structure, components, and ride stiffness you most probably don't need for towing an Airstream.
If you drop the 1/2, 3/4. and 1 ton arbitrary designations, and size according to needs there's some interesting choices.
Doug and Cheryl
Old 10-03-2015, 10:19 AM   #5
2012 30' Classic
Homosassa , Florida
I towed with a 1500 Chevy 5.3 for 10 years and loved the truck. Since you tow infrequently I would look at 1500s again. We looked at our 10 year plan and went with a 2500 Chevy diesel(personal preference). Unless you plan to bump the load capacity of the truck stay with a 1500. If more travel is in your future I would very seriously look at a diesel. We average almost 2,000 miles per month mostly towing.
Tater is offline   Reply With Quote
Old 10-03-2015, 10:30 AM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
If you do not want the diesel then I would stick with the F-150 with the 3.5 liter Eco-boost engine. It's plenty of truck for your rig and is a friendlier daily driver than any 3/4 ton. Lots of people I know pull their AS' with that truck/engine and they love it. Unless you plan to carry your rock collection or full wood-shop in the bed, the 3/4 ton is more chassis than you need for your purposes. In my opinion, the only reason to get the 3/4 is to get the diesel.
Bob Martel
WBCCI# 5766
Old 10-03-2015, 11:05 AM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
A major factor that all too many overlook when buying a TV is the rear axle ratio. The manufacture try and sell the lowest rear they can to get the government MPG approval rating as high as possible. If you are going to tow in any hilly areas consider this carefully or be prepared to lose speed on the hills
2004 Excursion 4x4
Old 10-03-2015, 01:48 PM   #8
BW1
1991 29' Excella
Rockwood , Ontario
Wow...I feel confused! We really load up the truck with 2 people 2 big dogs, extra water, bag of dog food, mats, bikes, chairs etc. The trailer has all it's regular everyday stuff in it, as well as sometimes, a full fresh water tank.
I really thought going 3/4 ton would solve it all. My current F150 is a 2010 crew cab 4x4 with the 5.4L Engine, tow haul package trailer brakes, 20" tires, and the upgraded rear differential, can't remember what.
Anyway, it really feels overworked going up hills, and there have been some mechanical issues, that may or may not have been contributed from towing.
I get what you mean about the actual use of the truck for towing compared to other stuff with the truck.
Old 10-03-2015, 02:38 PM   #9
1979 23' Safari
Wayland , New York
I think a f-150 should be plenty. I think that unless you buy something way oversized you'll find they all work hard going up a hill.
Old 10-03-2015, 03:01 PM   #10
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Gas or diesel or?
I pull with a diesel, now with 100,000 miles....and it will go up any hill as fast as I like. Pulling at between 60 - 70 mph, as I allow the run downhill to have momentum for the uphill in hilly country, usually about 62- 65 mph on the flat, I get from 12 - 14 mpg. Not towing, in town I get 16+, on the road about 20+ mpg.
If, I were to purchase a gasoline engine, the Toyota Tundra with a V-8 or the Dodge with a big Hemi V-8. Probably poor mpg, but very nice trucks.
Oh, I do drive my 22' long Dodge around town, parking being the biggest issue.
The advantage for towing of the huge torque with diesel is IMO such a comfort, especially if one does long trips (>1000 miles each way)....as I do regularly. And, as I have a 60 gallon auxiliary fuel tank in the bed, I can cruise for a long time, about 1,000 miles, finding the least expensive fuel. With gasoline, no auxiliary tank is possible.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 10-03-2015, 03:56 PM   #11
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I guess I'm a diesel head also. I've pulled with a GMC duramax, Ford power stroke & now a Ram eco diesel. Any 3/4 ton truck will support your effort, big time, & do it well but you going to miss out on the diesel envy from all your friends
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 10-03-2015, 04:15 PM   #12
Mission , Texas
We like our 99 F250 SuperDuty diesel 4x4 short bed xtra cab 4 wheel antilock disc brakes with a cap on the bed - 17-18 mpg towing our 27' AS, 20+ when not ... it doesn't know the trailer is there on Colorado mountain passes, gusty cross winds, etc.
nrgtrakr is offline   Reply With Quote
Old 10-03-2015, 04:27 PM   #13
1981 31' Excella II
New Market , Alabama
Do some math. You won't save money with a diesel with gas as cheap as it is. You could get a used gas hog 3/4 ton and figure out how many miles you can travel on that $40-$50k you will save on a used gasser over a diesel. I paid $7000 for my used V10 Excursion so that leaves me a lot of money to buy gas. Don't know if you can get a pickup that cheap or not. The rednecks have to have trucks here in the south so even a junk one is expensive. Diesels are nice but it is just as easy to gear down. HP is HP.
Perry
Old 10-03-2015, 05:42 PM   #14
1987 25' Sovereign
Oregon , Ohio
Bought a 2005 F250 V10 4.10 rear end with 38,000 miles two years ago for $10,000. It gets 9 to 11 mpg towing and 15 mpg not towing This past May I talked with a guy with a new 2015 F150 Eco boost, he paid $55,000, and gets 10 to 12 mpg towing. I figure I will have to tow about 500,000 miles at 2 mpg less to burn $45,000 worth of gas. I am 64 now and hope to tow for another 15 to 20 years. I do not think I will tow that many miles in that length of time.
msmcv51 is offline   Reply With Quote
Anyone wish for more off-road capable Airstream? Zybane Our Community 21 08-21-2015 08:59 PM
SUV capable of safely towing 25' Safari ghaag On The Road... 29 05-11-2013 01:47 AM
Easiest, most efficient way to skirt the tin can?? movin-in Winter Living 11 04-02-2012 10:49 AM
Is a 98 Ford Explorer capable of towing an 84 Soverign? fun2bethad Tow Vehicles 3 10-02-2004 01:13 AM
Are A/S energy efficient? John Our Community 2 10-06-2003 11:49 AM
