Old 02-13-2004, 12:15 PM   #1
2002 25' Classic
Kalama , Washington
more fuel capacity for my TV
Need to carry more than the 37g Dodge provides. Am considering an aftermarket replacement tank (55g) by Transferflow. Anyone have any experience w/these and any opinions to share on the subject? Want to keep the truckbed for storage so not too keen about a transfer tank. Many thanks in advance.
Brian
nwclassic is offline   Reply With Quote
Old 02-13-2004, 12:25 PM   #2
With all due respect, do you REALLY want to haul all that gasoline?
Gas stops are a good way to break the monotony and take a stretch.
Also, think of the sun beating down on the tank, or the fumes if you mount it inside.
Strongly suggest you review the risk/reward scenario.
Dick
Navigator is offline   Reply With Quote
Old 02-13-2004, 12:26 PM   #3
phred's Avatar
Extra Fuel
Brian;
Having done the extra tanks (2) on a Suburban I can attest to the fact that you can drive forever. There are problems to consider. If not kept full moisture forms in the tank. If not mounted between the frame rails, an accident can turn your rig into an inferno. (If the fuel is diesel it is much safer since its flash point is 180 degrees)
We have a tendency to treat gasoline like water. It is very dangerous. I have poured a half gallon on the ground in a ground bee hole and thrown a match at it. It about knock me down.
All in all my extra gasoline tank(s) were not worth replacing on any two vehicle since then.
Fred
phred is offline   Reply With Quote
Old 01-17-2006, 10:11 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Brian
Brian,
While this is an old thread, I have been contemplating the Transferflow large replacement tank for my '01 2500hd. What did you ever do on your Dodge?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
How can you tell the towing capacity? Dreamnair Tow Vehicles 4 01-04-2009 08:40 AM
How much towing capacity do I need? altamont Tow Vehicles 19 02-25-2007 02:16 PM
Towing Capacity hwpeddie Member Introductions 11 05-28-2006 06:19 PM
Argosy 24 MH Fuel Capacity Question outbound Airstream Motorhome Forums 6 05-12-2004 04:37 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 11:16 AM
