01-09-2018, 08:05 AM
#41
2018 27' Globetrotter
Columbus
, Ohio
Originally Posted by moosetags
We just Got a new tow vehicle for Lucy. She is a 2018 Chevrolet Silverado 2500 Duramax with crew cab and 6.5' bed.
We have added a Swiss Cap topper in matching color. The bed of the truck houses our Honda 3000 Generator that we operate from inside the topper. We are also equipped with an air compressor.
Brian
Brian,
I have a 2018 GMC Duramax on order. I am considering getting and ARE cap on it for storage and security when traveling. I have 2 EU2000’s I was planning on trying to run from inside to the cap. I was considering running the exhaust thru a port to the outside. I am not sure how much heat will build up in the cap. Can you share your experience?
Gary
(I have an EU6500 at the house, but it is way to heavy to transport. I got rid of a 3000 due to the weight. I like the portability of the 2000’s - I have not tried running them to power the AC when it was hot.).
01-09-2018, 10:30 AM
#42
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Originally Posted by Kodiak2006
Brian,
Gary
Hi Gary. My experience with my "new" system has been limited to tests. Running the Honda 3000 with the exhaust pipe running to the outside seems to work well. I am trying to control the inside temperature of the truck topper by slightly opening the front window in the topper and running my exhaust fan in the roof of the topper. This seems to work well, but, thus far, i have been able to test it only in the cooler weather.
As to using your two Honda 2000s to run the air conditioner, i can attest that they can do the job. I had two 2000s for 10 years, and used them extensively to run our air conditioner. I always used these outside the trailer, though.
Check on Ebay. I believe that there are after-marketeers offering exhaust extension options for Honda 2000s.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
01-09-2018, 06:55 PM
#43
2022 30' Flying Cloud
Phoenix
Originally Posted by pt.reyesfan
What brand of truck bed slide is that?
TruckSlide Cargo Access System from TSO Products. It holds 2000 lbs. I like the 5 inch high walls. Keeps most things from falling off. Holes in the wall for tie downs. Diamond plate is an option. Why wouldn't you get diamond plate?
https://tsoproducts.com/cargo-trays/...access-system/
01-10-2018, 03:23 PM
#44
Columbus
, Ohio
Brian
Brian,
Thank you for your input. I have search the “exhaust hoods” i have seen on ebay for the 2000. It looks like they are catching both the exhaust and the air outlet. I can imagine in tight quarters the heat buildup will be significant. I was originally thinking about a manifold to connect to both of my 2000’s exhaust, and port it outside through either a hot water heater exhaust port (on the cap). As for the waster heat, i was thinking about a fantastic fan in the roof of the cap. I did not consider using the front window of the cap as an intake for cool air. Did you install your vent in the roof -or was it an option on your specific cap? I was looking at a fiberglass model with swing (lift) to open side windows. These are not as aesthetic as the knob style frameless windows that are the other option.
01-10-2018, 03:52 PM
#45
1974 21' Globetrotter
2016 30' International
Houston
Brian,
New in-truck Generator set-up
http://www.airforums.com/forums/showthread.php?t=175334
Here is the dedicated thread.
01-10-2018, 03:56 PM
#46
2020 25' Globetrotter
Santa Rosa
2017 F250 6.7L Diesel Platinum Max Tow; almost every option except moon roof (which I didn't want). Added:
Ford trailer TPMS integrated with in-dash display
V1 radar detector hard wired to interior lift switch
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
01-11-2018, 08:00 AM
#47
2016 30' Classic
Hinckley
, Ohio
2016 Ford Diesel Ultra Lariat
I like lights so I added Big Rig Ice lights to the running boards. They are amber and change to white when you open the door.
I also put lights on the rear. Again they are red, brake, and change to white in reverse.
Titan 50 gallon mid ship fuel tank to replace the OME.
Transfer Flow 50 gallon in the front of the bed with a fuel pump wired to up fitter switch.
Back flip tonnow cover and spray in bed liner.
Lund bug guards and window shades all around.
And bigger floor protector mats.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
01-12-2018, 12:51 PM
#48
Aluminut
2004 25' Safari
I did these mods to my 3/4 ton:
http://www.airforums.com/forums/f463...des-51433.html
I also added slotted front Raybestos front rotors and brake pads. Will be adding a Mag-Hytec differential cover in the near future.
01-23-2018, 10:37 PM
#49
2014 27' FB Classic
Cambridge
, New York
2015 Ram 3500 CTD with 6 spd stick, 4x4, Club Cab, 8' Bed, Laramie Pkg.
1.) Manual transmission. That Cummins shifts when *I* want it to... ;-)
2.) Laramie trim pkg. Big, comfortable leather seats with built in tushy coolers and bun warmers. (I'm serious - best options, ever!)
3. Highway Products "Pickup Pack" Aluminum diamond plate combo: 8' side tool boxes, raised bed cover, and bed roller. I carry expensive toys like Yamaha gennys, ViAir compressor and lots of tools. Pickup Pack keeps 'em all well secured and out of site. Bed roller is great - I'm too old and fat to crawl in and out of a pickup bed...
4. *Good* mudflaps.
5. AirSafe hitch (used in combo with Equilizer). It makes TT and TV suspensions totally independent of each other - much smoother ride and less wear and tear on some very expensive toys!
Photos in my Gallery...
Tim
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
01-23-2018, 11:51 PM
#50
2017 27' International
Fall City
2013 RAM CTD 2500. Added rolling aluminum bed cover, AMP folding rear step,AMP tailgate extender,Condor motorcycle chock mounted in bed to haul dirt bikes
2017 27FB International
2013 Ram 2500 Laramie Crew Cab CTD 4x4
01-24-2018, 06:31 AM
#51
2007 30' Classic S/O
Somewhere
, South Carolina
Tim
Alright another handshaker triple pedal enthusiast!
May the clutch be with you!
Gary
01-24-2018, 08:27 AM
#52
Schoharie
, Unknown
On our 2013 F-250, 6.2 we added a 1 gallon on-board compressor for our rear air bag suspension aide as we also camp with a Lance slide-on in addition to our AS. We added a front receiver hitch that carries our truck spare tire. We found that with the slide-on camper in place, the spare tire crank-down hole was covered. Since the truck has electric fans for cooling, the tire in front has never caused an overheating problem, it surely makes the spare easy to keep clean and get in an emergency. Carry a second AS spare where the truck spare used to be. Other things we added include a truck cap(AS towing/camping), an aftermarket diamondplate steel bumper($6 more than the factory sheetmetal replacement OE bumper) which replaced a damaged OE bumper. Would like to find some very loud aftermarket electric horns to replace OE units. Any suggestions would be appreciated!! Jim & Gretchen
01-24-2018, 09:03 AM
#53
2016 27' Flying Cloud
Jones
, Oklahoma
For our 2012 F250 6.7, we've got an airbag suspension system (from previous owner), ATC camper shell and Rhino Roof Rack system, ProPride hitch, and hardwired Wilson 4gX cell phone booster.
04-02-2018, 03:46 PM
#54
2016 28' International
Sioux Falls
, SD
Decided to get a Leer top, CargoGlide 1800lb slide.
Install first week of May.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
04-02-2018, 08:21 PM
#55
Florence
, Alabama
Just ordered a BakFlip MX4. Will install this weekend.
04-02-2018, 08:37 PM
#56
2013 31' Classic
billings
, Montana
2017 ram, 6,7, 2500. Short box. 3.42. 4X4. Crew cab. Spray in bed liner. Running boards. Good enough....
06-27-2018, 11:23 PM
#57
2012 25' FB Eddie Bauer
laguna beach
Camper shell (topper), dash cam, racks on shell for kayak, led backup lights, air horns with 5 gal tank with quick release for airing up tires
06-28-2018, 07:34 PM
#58
diesel maniac
Airstream - Other
Tucson
, AZ
ARE topper with 1 hinged window, Bilsteins, 31 row tranny cooler with Derale thermostat, Frame rail mounted fuel filter/water separator, frame rail mounted tranny filter, coolant filter, battery tender with bumper mounted Marinco power inlet, bumper mounted Marinco for block warmer, air compressor with 2.5 gallon tank, AIS Severe duty air cleaner, In cab glow plug system diagnostic light. GAUGES: fuel pressure, tranny temp, HEUI system oil pressure, boost, EGT, coolant. Pioneer sound system with Alpine speakers and a RAM tablet mount with a Galaxy running Torque Pro via OBDLink MX bluetooth scanner. There's probaby more but that's what comes to the top of my head.......F-350 Powerstroke
Brian
06-28-2018, 08:27 PM
#59
2016 30' Classic
Hinckley
, Ohio
I just added a Viking dual air horn to replace the OME horns. I had to make a wood block to space it out. It hangs down from the factory location. I put the dual compressors in the airway to the filter. I also had to change the fuss to a 30 amp.
07-06-2018, 03:42 PM
#60
Sioux Falls
, SD
Some add ons
We have added a few items and finally have some pics so here they are.
Cargo Glide CG1800-HD bed slide.
Pro-Pride 1400 hitch w/ Straptek straps (no towers).
Front SS grille
Running boards
Leer top for the bed
Thats all the pics I have for now.
