Old 06-01-2014, 04:59 PM   #1
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
ML350 2011 vs. 2012
Looking to tow a 23' or 25' trailer. Will likely have either hitch reinforced by CanAm.
2012 is considerably more expensive, but it looks like it comes with a spare tire vs run flats (I assume the ride is nicer and understand that I can't throw the spare on while towing), has the AdBlue moved from the rear to the fuel filler which I believe clears access for a cleaner hitch reinforcement, and torque is up to 455 vs 400.
It's also redesigned a bit and has a reportedly nicer user interface for the electronics.
Does all that add to a better tow experience justifying the increased cost of the '12 vs. '11?
Thoughts?
SCOTTinNJ is offline   Reply With Quote
Old 06-01-2014, 05:34 PM   #2
Zephyrhills , Florida
We have the 2012. Last September we had Andy at Can Am reinforce our hitch and set us up. We pull a 27' EverLite and could not be happier with his work. He met me personally at the door, wrote us up and took care us. We have relation in NY so we drove up from Florida, visited relation, then went to Can Am. The US customs thought we were nuts to drive all the way from Florida to have a "Trailer hitch" put on......... We average 15mpg towing, 28mpg around town and 34mpg on the highway......
Smatrsounds is offline   Reply With Quote
Old 06-01-2014, 07:39 PM   #3
N/A , N/A
I could be wrong, but I believe the 2012 only has a donut, not a full size spare. I don't think you can use the donut for towing. Some reviews I read mentioned the ride in 2011 was better. I guess a test drive of both SUVs can determine that for you.
rostam is offline   Reply With Quote
Old 06-02-2014, 06:28 AM   #4
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Thanks guys. I guess what I'm wondering most is if the 2011 modification is relatively straight forward like the 2012 is. I've seen photos of the 2012 but not 2011. The 2011 seems to have the AdBlue tank in the way.
Anyone have a photo of a 2011 reinforcement?
Looking at prices realistically, the 2012 is about $10k more, +/- $35k vs. $45k. I can't see that the 2012 is worth the extra $10k from where I'm looking right now.
Old 06-02-2014, 07:35 AM   #5
JDS
2014 Bowlus Road Chief
JDS's Avatar
Cumming , Iowa
Aside from the other considerations, I hate run flats with a purple passion. Swapped them out of my BMW 550i and couldn't be happier. They ride like bricks and get noisy to boot.
John S.
JDS is offline   Reply With Quote
Old 06-02-2014, 07:37 AM   #6
Give Andy a call.....He or his crew will know.....
The spare on mine is full size but has a steel rim and is not a "regular" tire in that it is speed rated at 60mph. If you are not overloaded, And you have the proper WD setup, I cannot see what the problem would be to use it to get to the nearest tire facility. Granted, I wouldn't want to drive 60 and go hundreds of miles on it.
Old 06-26-2014, 07:48 PM   #7
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
I've had both ML's. The '12 feels much easier towing because if the increase torque. Also has a much nicer interior. But its still 10k. Up to u.
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Mercedes ML350 Bluetec eleighj Tow Vehicles 227 10-16-2015 11:09 PM
2012 Mercedes ML350 towing math/specs-for 25, 23 AS vonzellen Towing, Tow Vehicles & Hitches 58 05-21-2014 08:55 PM
2014 ml350 2012FB Towing, Tow Vehicles & Hitches 8 03-10-2014 07:36 PM
Advice on Tow Vehicle - X5 or ML350? SeattleMum Tow Vehicles 36 02-10-2013 12:18 PM
2011 Airstream 22 FB SPORT 2011 eBay Watch Airstreams on eBay 0 01-21-2011 05:40 AM
