08-25-2008, 06:24 PM
The Silver Schooner
2007 28' Safari SE
Dover
, New Hampshire
Mirrors for towing
I did a search and didn't find any threads about mirrors. I've searched on the web and there are all kinds of mirrors from $40 to about $400 each. So my question is if you have added side mirrors for towing what do you have and how do you like them? I'm concerned that the mirrors on my 2002 GMC standard cab, shortbed, truck aren't going to give me the visibility I need to tow an 8.5 ft wide trailer.
Recommendations please?
Louisa & Jasper Joy
08-25-2008, 07:23 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Mirrors for towing
Greetings Louisa and Jasper!
If my experience is typical, you will need auxilliary mirrors for safe towing. For the past ten years, I have used McKesh Mirrors on my Suburban as well as my '75 Cadillac Eldorado and '65 Dodge Coronet. The mirrors when equipped with the optional convex mirrors on each side are one of my favorite towing additions. The initial purchase price is high, but they last indefinitely, and the manufacturer provides repair and replacement parts even for their mirrors that are decades old (I purchased a pair of 1978 McKesh mirrors for use on my Cadillac and was able to purchase the necessary wear replacement parts <Webbing and Pad Kit> directly from McKesh for a very reasonable amount).
You can find out more about McKesh Mirrors at: http://www.hensleymfg.com/mckeshmirrors.html
Good luck with your research!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
08-25-2008, 07:36 PM
1986 25' Sovereign
Southern Middle
, Tennessee
I use the CIPA slip-on mirrors pictured below on my '01 2500hd and have been pleased with them. I eventually want to put on the OEM camper mirrors which were options for the '03-'06 CK/Silverado trucks. I'll try to post both sites for pictures.
http://www.cipamirrors.com/CIPACatalog.pdf
http://www.gmpartsdirect.com/results...umber=15904035
The driver's side mirror is part # 15904034.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
08-25-2008, 07:41 PM
San Antonio
I'll second the previous fine recommendation. We've had four trouble-free years with McKesh Mirrors. Most importantly, they give an enormous field of view - especially with the aforementioned "fisheye" optional convex attachments. We found them a lot more effective and easy to care for than the smaller plastic clip-on styles. Plus, they give a sort of functional look that shows you're a serious tower!
08-25-2008, 08:34 PM
1976 Argosy 26
Oxford
, Connecticut
Great topic for a post! I'm in need for tow mirrors as well and am looking forward to hearing what the forum "experience" has to say.
08-25-2008, 08:49 PM
2005 31' Classic
Placentia
, So. Calif.
Tow mirrors
I bought a pair of McKesh mirrors even before we took delivery of our AS.
We've never had a speck of trouble. They are rock solid and give an excellent field of view. With a little experimenting, and the optional convex mirrors, we can adjust them and coordinate with the OEM mirrors and end up with an unbroken field of view from just behind the trailer (about one and a half car lengths behind the AS) almost up to the rear doors on our Yukon XL. As a bonus, as long as you keep the straps scrupulously clean, they are very gentle to the finish on your doors. Just be sure to tighten the straps securely to avoid interfering with the operation of your windows.
Although they come a little dear, they will last you through your trailer towing career.
Dan
Dan
2004 8.1L GMC Yukon XL pulling 2005 Classic 31'
08-25-2008, 10:10 PM
2003 22' International CCD
Whittier
GM OEM Mirrors
On our 05 GMC Denali, I've added the Silverado truck mirrors noted above by Davidz71. They are 4 inches wider overall than the standard mirrors and they manually telescope out an additional 3 to 4 inches per side. Great mirrors and they are compatible with the wiring of the std mirrors. They fold in manually as tight to the side of the door as the std power folding originals.
In non trailering use, their only disadvantage is the larger planform and the greater width. Not a plus in tight parking situations.
GM parts direct put them on sale occasionally, in the $160/side range. Installation is straight forward.
08-25-2008, 10:56 PM
1992 34' Limited
Falls Church
, Virginia
my mirror story....
Hello all -
When I got to the point you are at now, needing better/ larger mirrors for towing, I too looked around here a while to get a sense of what worked for others.
Essentially, you have to figure out what your needs are. How often do you tow? How much do you want/ need to see? Naturally, there is also the $ and cents issue.
My situation was that I wanted to be able to see MAXIMUM around my vehicle at ALL TIMES - towing or not. So that meant no clip on style mirrors that so many find very acceptable. I looked into trying to get the factory mirrors as a retrofit, but found that I would have to forgo all the adjustability using the OEM interior buttons.
The solution, while pricey, was to get a set of Schefenecker mirrors. I can assure you that they are WELL worth the money. They offer full use of the OEM interior buttons for adjustability, they have the heated mirror function and they offer a much larger mirror, actually a 2 part mirror, which create an unparalleled view out back. They even look like a factory mirror. I am a happy camper - figuratively & literally!
So, back to the questions that started this thread - Figure out your needs, answer the $'s question, and the solution will likely present itself quite quickly. Best of luck with your search - and be SURE to come back here and let us all know how it worked out for you. Pictures are always appreciated!
Ciao!
Axel
SilverToy
08-25-2008, 11:31 PM
2007 19' Bambi
Somewhere
, Between the Tetons and the SF Bay
CIPA clip ons
I have the CIPA clip ons for my 2006 chevy HD. For less than $60 for the pair (at CampingWorld), you get a good view around the trailer. They are stable, don't pop off, stay in adjustment from one install to the next, don't marr the stock mirrors, and (best part is) they come off when I'm done trailering. I don't want big extended mirrors for non airstreaming.
I'd recommend trying a set for awhile, then think about spending the big bucks later.
TT: 2007 Bambi 19' 75th Anniversary Special Edition, David Winick
TV: 2006 Chevy HD2500 Duramax 6-speed manual
08-26-2008, 12:00 AM
2006 19' Safari SE
Tucson
We decided to give inexpensive clip-ons from Camping World a try before we launched ourselves into a major expense... despite not being expensive they do a decent job...we added a couple of little convex mirrors to them and we get pretty good visibility... and if they get broken or stolen, it will not break the bank... I was actually quite surprised how well they did for us.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
08-26-2008, 04:52 AM
1986 25' Sovereign
Southern Middle
, Tennessee
I might add that I bought my CIPA units off ebay for around $16 so it was even a cheaper investment. I'm still using them 7 years later.
Craig
AIR #0078
3.73 rear end
08-26-2008, 06:18 AM
Common Sense
I have the Cipa slide ons that are designed for my vehicle, an '07 GMC Sierra, and although they are nice, with satisfactory quality, I find them marginal in view for our new (to us) '01 wide body 25'. They were great with the earlier '75 23', however.
08-26-2008, 06:21 AM
gunnyusmc
Livingston
Mirrors
I use Power Vision out of Pendleton, OR.
Plugs into your wiring and power extends, defrost & turn signals. Bolts into original mirror mounting holes. Also breaks away in BOTH directions.
Gunny
08-26-2008, 05:09 PM
The Silver Schooner
2007 28' Safari SE
Dover
, New Hampshire
Thanks to all of you who responded. It was enormously helpful to have some guidance and feedback. I'm inclined to go with the McKesh because they are affordable, removable and I can probably deal with them alone - not an inconsiderable factor. I will post when I get it all together - and i expect to have a A.S in my yard within the next two weeks - woooo hoo!
Louisa & Jasper Joy
08-26-2008, 06:44 PM
Wrangell
, Alaska
Pulled 8000miles with my Mckesh mirrors last year on our Denali and love them.
08-26-2008, 06:56 PM
McKesh. You'll love them.
Daryl
"If the women don’t find you handsome, they better find you handy.” Red Green.
08-26-2008, 07:42 PM
2001 25' Safari
London
, Ontario
McKesh all the way...and don't forget the convex add-ons too.
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
08-26-2008, 08:17 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
08-26-2008, 09:54 PM
2002 22' International CCD
San Luis Obispo
McKesh with the convex add-ons.... great field of view... we love 'em!
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
08-31-2008, 06:08 PM
1976 Argosy 26
Oxford
, Connecticut
I fully understand safety first...and that we're not in a fashion show...yada...yada...yada...but those McKesh mirrors are so darn ugly that I don't think I can bring myself to buy them. The CIPA are affordable and look decent enough, the Schefenecker are really nice but will break the bank, and Camping World has a few different options to ponder.
The way my Argosy is shaping up I've got plenty of time to think about it (i.e. somebody call a plumber! ). Thanks for all the opinions.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Towing Mirrors
thebudd |
Tow Vehicles |
12 |
01-26-2008 09:03 PM |
Towing Mirrors
Double D |
Tow Vehicles |
32 |
03-09-2006 06:14 AM |
CIPA - Towing Mirrors
mopar7 |
2000 - 2004 Safari |
29 |
02-22-2004 02:24 PM |
Towing Mirrors
uwe |
On The Road... |
11 |
08-26-2003 04:36 PM |
Towing Mirrors
53flyingcloud |
Towing, Tow Vehicles & Hitches |
8 |
01-03-2003 04:28 PM |
