Old 10-12-2014, 07:49 PM   #43
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
If you want a rough ride you can now have it! LOL Goodyear must of been scanning Dodge forums, they're the first to market with a Load Range E tire in our STOCK FACTORY size of 275/60 R20 = https://www.tirerack.com/tires/tires...omCompare1=yes
They're an AT which means they're probably gearing it at a certain group. But maybe some of the other players will listen and offer better load range in the next couple of years.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-13-2014, 06:51 AM   #44
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Thanks for sharing.
The link is for a LRD BFG All Terrain T/A KO2. Not a bad tire at all. $261 from Tire Rack.
Lance
Top is offline   Reply With Quote
Old 10-13-2014, 08:44 AM   #45
Nomadic , USA
I checked and my local Costco is selling this tire now. It's an AT so might not be suitable, but it's about 11lbs heavier than the M/S2 and of course 10 ply. The M/S2 is actually 7lbs heavier per tire than the stock Goodyears BTW.
Old 10-13-2014, 12:42 PM   #46
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Yes, the stock GYs are THIN!
I picked up a nail and got a flat a few weeks ago. I was surprised at how thin the sidewalls were. You get what you pay for, I guess.
Lance
Old 10-13-2014, 01:23 PM   #47
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
I run mine at 65 psi. The dealer I bought my ford from did the exact same thing. He also put in a second battery. I figure he knew something....
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 10-13-2014, 03:15 PM   #48
Nomadic , USA
The stealership knows something?
I hope you don't run your Goodyears at 65psi since they are max 44psi.
Old 10-13-2014, 04:54 PM   #49
Photobum's Avatar
Who would buy a goodyear tire? I run michelins and have forever.
Bold, your biases are inappropriate....stealership. But I recognize that you know more than anyone else.
Old 10-13-2014, 07:49 PM   #50
Nomadic , USA
Wow, Sensitive much?
You just entered the thread and told everyone you run your tires at 65 psi without mentioning which tire you where referring too.
Old 10-14-2014, 05:27 AM   #51
Photobum's Avatar
[QUOTE]I've run the Michelin LTs at or near the max of 80 psi indicated on their sidewall on trucks and trailers.
Should I completely disregard the 39 psi door jamb guideline and go somewhere nearer 80 psi on the Michelins?/QUOTE]
Maybe if you read the original post you would understand it. Just saying...
Old 10-14-2014, 03:40 PM   #52
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Hey guys, don't get into it too much with each other, you both have good points but don't get kicked off by a Moderator.
Remember your max Psi for a certain tire is posted on the sidewall and is determined by build and ply rating: 'C', 'D' or 'E'. The Door jamb guide is, just that, a guide, and for the OEM tires the Auto comes with. Like I posted before, the auto manufacturer will state the recommended inflation is for all sort of things, ride, tire wear, etc. But, for the big tires--the "E" rated tires--on the bigger trucks, you will find the door jamb guide numbers many times strange, to say the least. Numbers like 60psi in the front and 75 psi in the rear. Do the numbers for the load/inflation PSI for that tire and you will find PSIs like those above for the 2500 Chevy 3/4 ton bring the tires to the exact load carrying ability as the axles. In this Chevy case, door jam pressures to keep tires and axles matched for liability reasons.
Howard L. is offline   Reply With Quote
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Goodyear Wrangler SRA LT265/60R20 SteveH Tow Vehicles 21 08-11-2014 04:43 AM
Tires: other than Michelin & Goodyear, what do you think? RAG General Motorhome Topics 25 03-05-2013 02:18 PM
275,500,00 obo Aerowood Off Topic Forum 8 09-01-2010 02:29 PM
Want to meet in Mi. sept 12-14 Yankee springs SRA? memgrove2000 Forum Rallies & Meet Ups 7 09-16-2008 02:37 PM
