Old 09-12-2014, 05:24 AM   #15
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Try calling Michelin....
We'll gladly assist with load / pressure when towing a trailer. We recommend having the vehicle weighed with the trailer attached.
Please provide the tire size and the total weight.
Thanks again for writing a review and thank you for choosing Michelin.
It is our goal to ensure that your issue has been resolved or your question answered to your satisfaction. If we can assist you further, please respond to this email or call us at 1-866-866-6605 (toll free) between 8:00AM and 8:00PM Eastern Time Monday through Friday or between 8:30AM and 4:30PM Eastern Time on Saturday.
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 09-12-2014, 11:28 AM   #16
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I posed the question to a towing expert "What is the best 20" tire for towing with my new RAM 1500?"
His advice was to go with a Yokohama P275/55/20XL.
I'm interested to hear how the Michelin LTX M/S2 LT275/65/20LRE work while towing. Since my RAM has 3.92 gears, I think I'd prefer the taller tires for gearing, but not if the ride and handling suffer.
Lance
Top is offline   Reply With Quote
Old 09-12-2014, 06:40 PM   #17
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Top, Interstateflyer do some reading over on the ramforums dot com. A lot of guys running that and a good discussion on that size tire in the towing area under 4th gen trucks (our trucks).
The ride difference is marginal. You'll notice it harsher over speedbumps, pot holes, those sort of things. Most say there is no real noticeable change cruising down the high way.
I'll be switching to 275/65/20 General Grabber ATII's or Cooper Zeon LT's shortly. I'm starting to lean more towards the Zeon's after reading a lot of reviews. They're more of a highway tire with minimal offroad traction, considered a hybrid and not a true AT.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-12-2014, 06:55 PM   #18
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Do you mean ramforumz.com? With a "z"?
Lance
Old 09-12-2014, 06:57 PM   #19
Nomadic , USA
sorry no S just ramforum, but the Z one is good, too, just to many ads for my tastes, lol.
I think I've found about 5 dodge truck related forums, but those two are the most active by far.
Old 09-15-2014, 03:41 PM   #20
interstateflyer's Avatar
2017 25' International
Los Osos , California
America's Tire/Discount Tire's data base says that since the Michelin LT275/65R 20E are 1 inch greater diameter than the P275/60R 20 that they would replace......they could hit the inside of the wheel well when turning.
Also, my dealer says that it could affect the shift pattern, speedometer and other issues which they may not be able to program out.
So, it looks like any 20 inch LT275/65 LR E is out of the question for a 2013 RAM 1500 Outdoorsman 2x2.
How MUCH of an improvement do you guys think the Michelin LTX P275/60 R 20 would be over the OEM Goodyear Wrangler SR-AS P275/60 R 20?
I've gotten 16,000, sometimes white knuckle miles towing miles (21,000 total) out of the Goodyears and I'm ready for a change.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-15-2014, 04:02 PM   #21
Nomadic , USA
The stealership is full of crap. But if you're sticking with their advice, you're stuck with P rated tires.
Old 09-15-2014, 04:05 PM   #22
What do you think of the clearance information in America's Tire's database?
Old 09-15-2014, 04:22 PM   #23
Nomadic , USA
I think they think liability. The same reason why the dealership tells you installing an aftermarket air filter will void your warranty.
I could spend hours finding these. Tirerack lists that size as a plus one.
Toyo OC ATII 275/65/20
Another truck, Nitto Terra Grapplers 275/65
275/65/20 bfg all terrain
Towing a SOB on 275.65.20 BFG
Old 09-15-2014, 04:23 PM   #24
Nomadic , USA
Peer pressure. All the cool kids are doing it.
Old 09-15-2014, 04:29 PM   #25
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
They could possibly rub when turning, but there are many guys running the LT275/65/20LRE tires of many different manufacturers, but mostly Nitto and Toyo, on the many RAM forums, like BoldAdventure pointed out. The speedo will be off a little. The dealership can change the tire size in the PCM, but the OE size is the largest diameter of the available selections.
I'd bet that the P275/60/20 Michelins would be a better all around tire than the GoodYears, but I'm not certain that they would make a noticeable difference while towing. I would always select a Michelin tire over a GoodYear. That is just my preference.
If your primary reason for changing the tires is for better handling while towing and a better towing experience overall, then I would go with my towing expert recommended and change to P275/55/20XL Yokohama Geolander A/T-S (All Terrain) or the Yokohama Parada spec-X (if you will never travel in snow and ice). It is 32" in diameter. You can have the dealership change the tire size in the PCM to 285-45-22, which is a 32" tire as well, so your speedo will be correct etc.
Lance
Old 09-15-2014, 04:38 PM   #26
Nomadic , USA
Anything has got to be better than those Goopyears
Old 09-15-2014, 04:51 PM   #27
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Remember that a different diameter tire will have the same effect as a slightly different rear axle gear ratio. Larger diameter tire, less ability going up grades.
Doug and Cheryl
Old 09-15-2014, 07:26 PM   #28
Good point Doug. I'd forgotten about that.
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Goodyear Wrangler SRA LT265/60R20 SteveH Tow Vehicles 21 08-11-2014 04:43 AM
Tires: other than Michelin & Goodyear, what do you think? RAG General Motorhome Topics 25 03-05-2013 02:18 PM
275,500,00 obo Aerowood Off Topic Forum 8 09-01-2010 02:29 PM
Want to meet in Mi. sept 12-14 Yankee springs SRA? memgrove2000 Forum Rallies & Meet Ups 7 09-16-2008 02:37 PM
