10-17-2011, 08:19 AM
2008 19' International CCD
Spring
Mercedes ML350 Bluetec
Wife and I are considering a slightly used Mercedes ML350 Bluetec (diesel) to tow our 19' versus 2011 Expedition. The Mercedes has a towing capacity of 7200 lbs while the Expedition has an 8900 lb capacity. I would think that maintenance costs will be the biggest difference. Feedback will be welcome.
Ed
10-17-2011, 08:34 AM
2014 25' Flying Cloud
Cuddebackville
, New York
We tow our 20' with an '05 ML500 and have been completely happy with it. I know of folks who tow a 25' with the ML350 Bluetec.
10-17-2011, 08:41 AM
Spring
How are the maintenance costs?
Ed
10-17-2011, 09:34 AM
2007 23' Safari SE
Central
, Connecticut
Just throwing this out there - are the ML and the Expedition the only choices? Seems to me that there are plenty of other nice-driving tow vehicles that can readily handle a 19' - Jeep Grand Cherokee, Dodge Durango, Acura MDX, Ford Flex (especially with the Ecoboost)...
Tom
10-17-2011, 12:08 PM
2020 30' Classic
Derwood
, Maryland
That engine along with it's VW\Audi's brother (3.0 V-6 TDI) are great for towing, 405lbs of torque - with the dual turbos no loss of power at altitude, Great Rig but I would suggest you get an extended warranty, these engines can be expensive if something goes south.
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
10-17-2011, 01:14 PM
Montreal
, Quebec
I have an '09 ML320 BlueTec, and pull a 30' Flying Cloud.
Power is absolutely no issue whatsoever. I had my hitch reinforced by CanAm in London, ON. I recommend a Hensley or ProPride hitch if you'll pull a 25' or longer. But she pulls like a dream and gets 14-16 mpg.
Don't be swayed by the nay sayers who have never tried this combination, rely on opinions of those of us that have.
Go for it!
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
12-25-2011, 10:26 PM
Southern
We tow the Rockies with our ML350 Turbodiesel. It may drop from 7th to 5th towing up the steeper grades but it seems like a waltz for the engine. Remember this is essentially the Sprinter engine with a different state of tune.
As for cost of maintenance - one of the reasons I stick with M-B is the overall low cost of maintenance, especially over the long haul.
Mike
12-26-2011, 06:53 AM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
mikapen, there is a significant difference between the 350 and the 450 when it comes to a "D" service. The 350 BluTec is about double the cost of the gas powered 450.
Wasn't that way with the BluTec 320, but…
12-27-2011, 07:44 AM
Southern
My recent A service on the ML350 cost $341 plus the $31 I spent at NAPA for AdBlue, which was installed by the M-B dealer for N/C.
I will research, but I don't think I have a D service - only As and Bs with an occasional C when I change my oil more frequently than 10,000 miles.
12-28-2011, 08:53 AM
Western
, Massachusetts
Maintenance
eleighj-
ML maintenance costs aren't cheap, but with a CPO, they are very predictable. Our local dealer publishes their charge for each service (not sure it's online). Check with your local dealer.
Our 2007 ML320CDI has the same engine, without the BlueTec system. Our only non-standard maintenance item is coming up. We're developing a rear main seal leak after about 90K miles.
It's a proven engine. I consider ours a baby.
John
12-28-2011, 10:01 AM
Branson
, Missouri
65CV, I had a '08 GL320, and you're right. The maintenance costs are pretty much in line with the other lineup of GLs.
However when the BluTec350 came upon the scene, for whatever reason, the periodics are all of a sudden much more than the 320.
At least that's what the service manager at the MB dealership in Springfield, MO says.
I recently went in for a "D" service on my 450. It was almost $500. That's when he said, the same service on the 350 was almost double.
12-28-2011, 10:19 AM
2007 19' International CCD
2002 19' Bambi
2005 30' Classic
Dover
, Arkansas
Mercedes suv
I have one of the original ML 55 AMG that was made back in 2001...There were just 2 left at the dealer in Little Rock, and they dropped the price by $15,000...My wife takes it to the dealer once a year and has every little thing that's wrong fixed...She is really the only one that drives it, just over 100,000 miles, and the thing will fly...gets great mileage also....I am going to buy her a new one next year, and keep this one to pull my 19ft. Bambi.
12-28-2011, 11:14 AM
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
@murreywalker: A big part of the reason for the sticker shock on the Bluetec service is that most dealers drastically overcharge for the "Adblue" (urea) fluid refill. It costs about $4-5 per gallon at auto parts stores, and dealers typically charge $30 per gallon (in half-gallon increments on the invoice). Since the GL tank holds 8.5 gallons, you're looking at $255 or more just in the fluid, plus a ridiculous service fee to put it in.
And every 20K miles the maintenance program calls for a complete purge and replacement of the tank (no matter how full it might be when you come in for service) so you're going to get hit for the maximum charge the dealer can come up with.
You wouldn't pay $255-350 to have your washer fluid topped off, would you? But many ML & GL Bluetec owners just assume it's too difficult to DIY, or they don't realize how badly they're getting screwed. Take this fee away and the "B", "C", and "D" services are about the same cost as the gas engines.
With a helper you can refill the tank yourself in 5 minutes. Just be careful not to overfill, as spillage of urea solution can damage electronics in the area. The trick to a clean fill is described on various MB and VW forums, like here:
AdBlue Home Refill - Club Touareg Forums
@eleighj: The diesel is the way you want to go if you are considering an MB for towing. Be sure to get the hitch receiver reinforced, as the factory receiver is not very good out of the box. An ML350 Bluetec will haul the hell out of any 19-foot Airstream, over mountains and across windy plains, and never break a sweat doing it.
12-28-2011, 12:22 PM
Branson
, Missouri
rluhr, I don't mean to be argumentative but…
As with other additives, you're correct and urea can be purchased at auto parts stores for significantly less. However, doesn't a DIY service invalidate a warranty? And even at $255, that's only a portion of the almost $1000 for the service.
With regard to the hitch receiver.
After talking with Andy at TransAm, who falls into your camp, AND the tech at Mercedes, who says there is no problems, what's one to do?
I even had the tech dialogue with Andy to no avail.
Of course, with things mechanical, I'm a neophyte. Do you have concrete documentation that the MB GL receiver hitch is substandard? If so, I would be most appreciative in you sharing it with this thread.
12-28-2011, 02:18 PM
Western
, Massachusetts
2007 Model Year
murreywalker-
I was a little concerned about the new technology when buying our used ML. The April Consumer Reports shows that the '07 model year has the best reliability. Don't know if they lump the Gasser (ML350) and Diesel (ML320) versions together.
John
12-28-2011, 02:56 PM
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
OK, quick reply. All of this info is out on the web if you want to dig around a bit.
1) Under Federal law, DIY service does not invalidate warranty. Google "Moss Magnuson Act" if you want to know more.
2) You need to get a definition of "Service D" before you understand the full implications of gas vs. Bluetec diesel in terms of service costs.
3) If you put more than 600 lbs on the factory receiver it will crack. It's only a matter of time. See the placard on the receiver. I know of at least four Airstream owners who have had the exact same receiver failure. I was one of them. Another guy was carrying a tongue weight of only 500 lbs but the extra force exerted by his weight distributing hitch was enough to break the receiver anyway.
Andy T works on these things every day. How many towing customers does the Merc tech have? You can decide for yourself who to believe.
12-28-2011, 03:03 PM
Branson
, Missouri
65Cv, I would like to think Consumer Reports can and would differentiate between the two, but I don't have the foggiest.
12-28-2011, 07:18 PM
Southern
There seems to be a large discrepency in the reported / estimated service costs for the M-B Turbodiesels. Not only here, but on M-B forums, too. I have seen the top service quoted to range from $299 to $798.
My recommendation to the original poster is to go to the service department and ask them specific questions and don't take a WAG for an answer. Ask them "if i bring my car in for the XX,000 mile service, what will it cost?" Get every service. That is the only way you can get a handle on what the local dealer will charge.
Odds are it will cost less than a 3/4 Ton Turboodiesel domestic truck.
12-30-2011, 12:11 PM
Austin
I have been following the Touareg TDI (JFScheck) and the Mercedes ML and GL (rluhr) discussions. The 2011, 2012 Touareg TDI with 225 HP, 406 lb. torque, and normal tires had the edge over the Mercedes products until the 2012 redesign of the ML350 Bluetec.
The GL350 Bluetec will be redesigned for 2013 but has as a standard feature the air suspension which I do not feel is a good feature for weight distribution hitches (comments welcome). The Touareg does not have air suspension and on the ML350 the air suspension is optional.
For 2012, the ML350 diesel ADBLUE tank was moved from the spare tire location and the fill tube is next to the diesel fill tube. So normal tires with a compact spare like the Touareg. The diesel engine was improved and now has 240 HP and 455 lb. torque making it the king of suv diesels. Sorry Touareg.
Now there are two good choices for towing smaller Airstreams. Of course the hitch on either vehicle needs to go straight to Andy for reinforcement. If my thoughts on air suspension are not valid, then the 2013 GL350 Bluetec will be a third choice. The Touareg and ML350 are basically the same size with the GL350 being larger with three rows of seats. The ML350 is rated for towing 7200 pounds with the Touareg and GL350 at 7700 pounds.
The ML350 has a seven speed tranny and the Touareg has an eight speed tranny both of which get good reviews for towing. Of course the massive torque helps the most.
12-30-2011, 01:18 PM
2007 23' Safari SE
Central
, Connecticut
Rumor has it that the 2013 Grand Cherokee will get a diesel stateside (they're currently sold in Europe where a non-diesel SUV would be DOA.) 237hp, 406 lb-ft torque (although the quoted numbers online are all over the place.) I'm waiting for that; it has a stouter hitch than the Benz, fewer of the 2" ball/no-weight-distribution restrictions that the Germans seem to like to throw in the manual's fine print, more dealers in rural areas, and probably $5k less than a Treg.
I've towed with a HEMI-powered Grand Cherokee with a weight-distribution hitch and air suspension. Didn't really find it to be a problem.
Tom
