Old 11-05-2014, 08:03 AM   #127
2015 27' FB International
San Francisco , California
MPG figures cannot be compared across the Atlantic; they are calculated entirely differently, and European numbers are always higher than the exact same vehicle would receive in the US. It's a simple calculation difference and has nothing to do with anything else.
European vehicles do tend to make do with smaller-displacement engines, so it's also true that as a general rule, European vehicles get better actual mileage across the board. But comparing apples and apples with identical vehicles (ML250 Bluetec 2.1), it's just calculation differences.
As an aside, justifying a price difference in the ML vs Tahoe would be just as much about driving a non-entry-level Mercedes vs driving a Chevy as it would be about diesel vs gas, imho.
ciparis is offline   Reply With Quote
Old 11-06-2014, 02:02 AM   #128
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The British imperial gallon has more ounces than the American gallon, so that skews the mpg numbers.
Also, four liters equals about 1.2 US gallons.
Old 11-06-2014, 05:25 AM   #129
2007 23' Safari SE
2016 23' International
Fernandina Beach , Florida
With the ML250 soon to be on dealer's lots, I'd be curious to see how much interest folks have in using that as a tow vehicle. Likewise for the new XC90 T8 Volvo (dual engine hybrid, 4cyl supercharged petrol FWD and electric RWD.)
Hadn't noticed before that MB has a $1500 uplift for all diesel SUVs over their petrol counterparts, even though is some cases the engine is smaller. My 2014 E-250 diesel, was and remains $500 less than the petrol counterpart (E-350).
Have already posted about the Sprinters, and am not at all unhappy with my RT CS with the 6cyl. Getting 20 MPG on a regular basis.
Tomzstream is offline   Reply With Quote
Old 11-06-2014, 05:45 AM   #130
Wayward's Avatar
Cary , North Carolina
Originally Posted by Tomzstream View Post
I have the 2.1L BT inline 4 in my 2014 E-250 and love it. ..................Not sure I would want to tow my 4600lb Safari with it, but it is within specs. the ML250 I4 Bluetec has 200 hp and 369 lb-ft of torque .
Those numbers caught my eye.....
The V6 in my F-150 tows a 5200lb Airstream with less oom'ph than that diesel.
Interestingly, the F150 and the E class weigh about the same
With 205 hp and 255 lb-ft of torque....
F150 curb weight is 3,900 lbs.
25' Safari curb weight (UBW) is 5200 lb
Rig weight
9100 lbs
With 200 hp and 369 lb-ft of torque...
E250 curb weight is 4,200 lbs
23' Safari curb weight (UBW) is 4600 lb
Rig weight 8800 lbs
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-06-2014, 06:01 AM   #131
2007 23' Safari SE
I did a little more digging and the Diesel uplift seems to be due to the Standard 4-Matic for the Diesel as opposed to a charge of $2500 for 4-Matic in the Petrol models (ML350) which puts the price differential of D VS P with 4-Matic at minus $1000. That's a pretty good deal. Towing capacity is in fact the same, and torque is way better in the Diesel, although HP is two thirds that of the Petrol engine...
Old 11-06-2014, 06:17 AM   #132
2007 23' Safari SE
I forget what the towing capacity for the E350 Station Wagon is, but I think its comparable to the GLK (3500 range). I would expect my sedan is less than that. It has to do with suspension and brakes I am sure. And they just don't offer a diesel in the wagon, otherwise I would have jumped on it. I test drove the GLK250 and performace was good, but the seats did not measure up to my wife's standards. Expect the ML250 to be better in that regard, with adequate performance.
Old 11-06-2014, 07:08 AM   #133
N/A , N/A
Also, Benz GL 350 (diesel) is ~$1500 cheaper than GL450 (entry level gasser engine).
rostam is offline   Reply With Quote
Old 11-06-2014, 12:17 PM   #134
Southern , Colorado
Originally Posted by jmpgino View Post
I was back home in England last month and met two blokes who had Diesel vans, they were getting 65 MPG.
THIS BLOODY GOVERNMENT HERE IS THE CAUSE FOR OUR POOR MPG, Europeans expect a return in the high 30's for a gas engine as well.
As was posted earlier, British gallons = 1.2 US gallons. So the occasional 35-40 mpg I get with my ML would equate to 42 - 48, and that's not a minivan.
Mountain towing if I stay at 55 mph, I have seen 25 mpg for a day's driving, which would be 30 if I used Brit gallons. (That's with my SOB flat-nosed TT.) Certainly not "POOR MPG."
The new technology using AdBlue is pretty much world-wide. European standards may be tighter than U.S. these days. Including off-road equipment. Hong Kong, too.
AdBlue and SCR actually free up diesel engine design and liberate the engines to greater performance and economy than earlier clean-diesel solutions.
As manufacturers redesign engines to take fuller advantage, we will see further performance gains, likely far more than pre-emission diesel designers ever imagined.
2 liter diesel tow vehicles with 400 lb-ft and 40+ real mpg? Probably soon, and as a direct result of clean diesel requirements. I'm OK with all that.
2010 M-B ML350 Bluetec
2011 Lance 2285 27' TT
mikapen is offline   Reply With Quote
Old 11-07-2014, 10:40 AM   #135
switz's Avatar
2014 31' Classic
Images: 8
Only the US market denies the existence of the diesel engine option on nearly every model of Mercedes. Big oil does not want economic vehicles here.
I have a lovely late 2002 Mercedes E320 station wagon (called an Estate in the UK) in Birmingham, UK. I have owned that car since it was new. It has the straight 6 3.2 liter turbo diesel engine which was both quicker and 30% more fuel efficient than the same configuration gasoline engine.
Just for grins, go to the UK Mercedes website and see all the engine options that are available else where in the world. Then realize that the ML class was made only in Alabama for years with many diesel engine options. Only in late 2006 were we allowed to order one with the V6 turbo diesel engine.
Old 11-07-2014, 01:54 PM   #136
Southern , Colorado
Yes, swiz, things have changed a lot in the last 9 years, haven't they?
Now it's hard to name a US M-B model without a diesel variant.
Old 11-07-2014, 02:55 PM   #137
N/A , N/A
They should really put a diesel engine in the G class. It has horrendous fuel economy!
Old 11-08-2014, 02:27 AM   #138
Wayward's Avatar
Availability of efficient vehicles in any particular county, is about engine technology vs that country's government environmental regulators, not the oil products that run in those engines.
Diesel engine efficiency does not come from the fuel itself, but from the high combustion temperatures and precise control of injection that diesel fuel allows. Gasoline engine efficiencies will soon approach that of diesels as Gasoline Direct Injection technology improves.
Not the case, and in fact, oil companies were part of the consortium that led to the EU emission regulations, specific for diesels, that unleashed high efficiency diesel technology there.
It is the environmentalists, regulators in the US who put the cabash on new diesel technology. US emsison regulations are not based on fuel type so, as diesel injection technology increased combustion pressures and temperatures, US regulations forced expensive low sulfur fuel and particulate matter traps.
Now that gasoline direct injection technology is approaching the efficiency of diesels, combustion pressures and temperatures will force expensive low sulfur gasoline, particulate traps and "Blutech" like contraptions on gasoline cars too.
Europe and the UK are about to end the high efficiency diesel era over there. WHO and other globalist groups which want us out of our own vehicles and into government transit, have declared diesel emissions a carcinogen.
A very serious environmentalist campaign against diesels, based on the WHO "data", is being led by the UK's, Simon Birkett, of Clean Air in London. who said “In terms of harmful air pollutants, diesel exhaust has been a public health catastrophe for Europe”.
Ironically, as the EU prepares to kill off the high efficient diesel market, the US emissions standards may put us in a better position to see new diesel and gasoline injection technology.
So far the US bureaucrats and Chicken Littles have rejected the WHO scare mongering campaign that "diesel engines cause cancer". If that holds, the US diesel market is poised to expand as Europe's declines. Those "evil oil companies" are among the diesel proponents lobbying hard for that market to expand.
As engineers make incredible strides, the regulators continue to throw their wrenches in the works.
Will America Avoid Europe’s ‘Clean’ Diesel Problems?
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-08-2014, 04:12 AM   #139
2007 23' Safari SE
An interesting read about Diesel in Europe. I loved my last of the iron blocks inline 6 CDI engine in my 2006 E320. While it had a particulate filter, it had no DEF requirement. And if someone insisted on tailgating me I could easily "Smoke" them by stomping on the accelerator and literally leaving then in a cloud of smoke. Of course I would be a mile ahead of them by the time the smoke cleared... It was an amazing engine and the torque at the high end made passing effortless.
One UPSIDE to Europe banning Diesel would be cheaper Diesel here in the US as much of our refinery output of Ultra Low Sulfur Diesel goes there. The other big drain on our refinery output this time of year is Heating Oil and as the gas boom continues, more folks, esp in the NE are converting to NatGas for Heat. I don't think Diesel has dropped as much as gasoline percentage wise, at least around here, but that could be due to tax differentials.
I have a Sprinter based RT and wish I could have had my old inline 6 transplanted into it, but for now the 3L 6cyl Bluetec sure beats any Gasoline van out there. But as far as cars go, I love my 2,1L BT diesel in my E250 and am getting over 44 mpg COMBINED long term. And now you can get a Sprinter with the same engine, although only in a 2500 chassis.
Now I agree gassers are catching up, and Volvo is doing some amazing things with their Drive-E 4 cylinder lineup as is Mazda with their SkyActive and of course the local favorite Ford Ecoboost (Turbo technology really borrowed from Volvo). But none of those engines matches the torque of a good diesel and when it comes to towing so it is a real factor in choosing a good TV.
ELECTRIC on the other hand has tremendous torque and is why Diesel Electric Locomotives are the current standard. To that end, I think Volvo is on to something with their XC90 T8 with both Drive E (powering the front wheels) and Electric (powering the rear) motors. While the range in all electric mode is limited, I can see it being useful for when you are creeping along at 5 MPH on the downtown connector in Atlanta Rush-hour(s), pulling an Airstream, and the Electric would be great for supplementing the gas engine on uphill grades when you need that torque boost. I would expect the gas engine to be sufficient while cruising at highway speeds. It will have regenerative braking so all that potential energy put into the TV and Trailer climbing grades or accelerating in traffic, can be recaptured for tackling the next hill or accelerating in stop and go traffic. Have yet to see the mileage estimates or towing specs for this vehicle but it will debut in the US in a few short days at the LA auto show.
Interestingly, I would look to California for leadership on the whole carcinogenic issue of Diesel here in the US, just as they did for the elimination of MTBE additive in gasoline (also a known carcinogen). Still, just like MTBE was used for making cleaner emissions, the Cal stance on Diesel was not always so friendly... I could not buy my CDI in 2006 in Cal (you could bring in used vehicles) and at one point there, they too were considering banning Diesel altogether. It wasn't until the legislature passed a strict global warming inspired CO2 emission standard, that Diesel became acceptable.
With the success of Tesla and some electric plug in hybrids utilizing gas and electric, my guess is this is what the future looks like and not so much diesel. For now, I am happy to be burning oil, albeit in reduced quantities due to the high efficiency of my Mercedes engines.
Old 11-08-2014, 08:11 AM   #140
N/A , N/A
What I don't understand is why all the EPA MPG numbers for diesel engines are understated. You would be lucky to get the EPA MPG number for a gasser engine (it usually happens only under "ideal" conditions), whereas all diesel vehicles I know, in reality, beat the EPA numbers. Our GL is rated at 17/21 MPG for city/highway, and we get 20/25 regularly, even though my wife drives aggressively (lots of unnecessary acceleration/breaking). Jetta TDI's also get 50 MPG on highway. There seems to be a flaw in the way EPA calculates the MPG.
The Retromobile Creamed a Mercedes Eaglemate On The Road... 47 12-01-2011 06:04 PM
2008 Roadtrek Adventurous RS 11K miles! Airstream Mercedes Sprinter 25mpg NR eBay Watch Airstreams on eBay 0 10-27-2011 04:40 PM
2004 airstream powered by mercedes diesel,16k miles,serviced,generator eBay Watch Airstreams on eBay 0 10-12-2011 11:30 AM
2010 Airstream Interstate 3500 B Van Motorhome with Mercedes Benz Diesel Engine eBay Watch Airstreams on eBay 0 09-17-2011 09:40 AM
L@K Airstream Mercedes Diesel Westfalia RV Class B OnaN SL@K Airstream Mercedes Diese eBay Watch Airstreams on eBay 0 03-28-2011 01:00 PM
