First post here after reading many, many posts. We have a g500 that weighs around 5,500 lbs. All time 4wd w/ 500 engine and 292 hp. Towing capacity is 7,000 lb on the m/b website.
Don't plan on long distance outings.....just around the DFW area to football games, ranch (90 miles) etc. A few hunting trips in Tx w/ friends, etc.
Can we safely pull a 27' safari, or bigger, with all the correct equipment?
I don't see why it wouldn't haul up to a 30'...but some of the more experienced Airstreamers should be able to add their input. Good Luck with your search and have a ball with your new baby whenever she arrives!
__________________ DW always tells me to "take the high road"...
2006 23' Safari
2007 F350 Lariat Crew 4X4 PSD
AIR# 21875
WBCCI# 3778
Region 3, Unit 144 (Eastern North Carolina)
On our last outing to Upstate New York we parked beside, and a few days later travelled with a couple that were towing a 25'+ newish Airstream with a 350ML. He raved about how well it worked. On a very windy day we followed the combo for a number of hours. It tracked straight and smooth without the slightest wimper. It cruised up the Up State New York hills and bridges very well too. The big 500 should only be better.
__________________ Airstreams..... The best towing trailers on the planet!
I'm in total agreement with whats been said about the Mercedes offering in terms of this particular question.
NO
A benz or any other non american car is not build to tow a american trailor
overhere the tonque weight is 75 kg ( around 200 pound ) MAX.
A G 500 is a great car to tow a european horse trailer or so but NOT for a airstream.
These cars are NOT designd to be used with a weight distribution hitch simply becouse we don't have that system overhere.
If you put yourself in a dangerous situation becouse your towing with the wrong TV its your problem.
But when you do that on the open road and get other people involved it's a other story.
What Rem says is correct, in my opinion. You'd have to see a European trailer hitch to understand. It is (I believe) attached to the axle or somewhere under the car, and comes out from under this in a long curved thingie with a bulb on the end where the trailer tongue goes on. It just looks weird.
From some web browsing and a little experience with the previous MBUSA SUV's, it seems these make pretty good tow vehicles IF set up properly with the leg up being the very short rear overhang. WD is critical on these lightly sprung, short wheelbase units.
CanAm would be a good first call.
__________________ Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and- 'Epiphany' the 29' Airstream
Thanks to each of you...... Hiho do you have a number for can am?
Still confused by the width of opinions. 2 tx dealers have stated that the g500 would work if set up correctly. over 60% of folks on one of the mercedes bbs's said the same............... any other comments, or experts' phone #s to call would be appreciated.
I agree the old G series and the ML series are two different animals. I tow our 20' with our ML500 and it works wonderfully. My next vehicle will be a GL diesel.
.....Still confused by the width of opinions. 2 tx dealers have stated that the g500 would work if set up correctly. over 60% of folks on one of the mercedes bbs's said the same...............
Those pesky sales people - always telling customers what they want to hear....
Can you pull a 27'er and still be within specs? - don't think so...
MB G500 - Max weight 6834 lbs
Dry weight 5510 lbs
That leaves 1324 lbs for beer, gas, driver, squeeze, and dog.
AS 27' tongue weight - 790 lbs
Tank of gas for the Benz - 162 lbs
Weight Dist. Hitch - 100 lbs (MUCH more for a Hensley)
Driver - 200 lbs
Squeeze - 140 lbs
You're already over Max Allowable Gross on the 'Benz AND you have to leave the Beer and the Dog behind!
Dennis
Thanks again for your time and help,
Bo
Hi Bo...I would talk to Andy Thomson at CanAm RVs (search should find it...ignore the US rental company with a similar name). W/O starting the whole issue of what TV can pull what...CanAm has 40-50? years of TV set-up and seem to know how to best set up a vehicle to tow at its' maximum capabilty (again...not arguing if they are right or wrong!).
The CanAm web site shows the types of TV combos they have that they actually allow "test" drives with. I am confident they can give you good input what you should do with your vehicle to best prepare it for towing your AS...unless you buy a one ton, dual rear wheel, diesel as a tow vehicle...just kidding ...Thanks...Tom R
