Old 08-28-2008, 03:37 PM   #1
2009 28' Flying Cloud
Park City , Utah
Mercedes G500
Hello,
I am interested in a 2009 28' Flying Cloud( net 5500, gross 7300) and want to know if I have enough tow vehichle. I have a 2002 Mercedes G500 with a tow rating of 7000 pounds ( 7700 everywhere but the US )and of course the salesman says to pull it dry and we should have no problem. Imagine that?! I would like to hear from someone who doesnt stand to make a commision as to how close to the net weight a trailer is in a " real life" situation. I want to belive the Airstream dealer so bad. Can I do this safely?
Big Jim is offline   Reply With Quote
Old 08-28-2008, 03:45 PM   #2
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Seems to me that the margain for error is small here. Can you trully pull the camper "empty"? What about luggage, food, etc? With that said I have seen people pulling 34 footers with Cadillacs, Lincolns, and Mercedes using a Hensley hitch. Being that close to the rating would make me uneasy. I'm sure someone on the forum will have better info and or advice on this matter.
94Tri is offline   Reply With Quote
Old 08-28-2008, 03:49 PM   #3
1986 32' Excella
vledder , drenthe
Images: 8
First of all welkom to the forum.
gross of the trailer should be <80% of tow rating of the TV.
Plus that a G500 has a short wheelbase and a high center of gavity.
just a few day's ago I towed my 32 ft with a SWB landrover.
It was just for 5 miles and I did not dare to go above 30 mph.
Even at that low speed I could realy feel the trailer stearing the car.
remcolent is offline   Reply With Quote
Old 08-28-2008, 04:06 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I pull a 20' Safari, (5,000 lb) with an ML500 with no problem. But that''s 8 feet shorter than yours and I think you might have a shorter wheelbase than myn ML. YMMV.
Old 08-28-2008, 04:16 PM   #5
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
My opinion is simply when you get into the 27 or 28 foot market you are leaving the Half ton tow vehicle spectrum example 27 or 28 footer you could tow with a dodge 1500 ford f150 or chevy 1500 You can check wheel base difference between your vehicle and the one I mentioned. Now saying that you will get people on these forums that tow 31 footers with a 1/2 ton. I did but new it wasnt safe. You are at a threshold with a 27 or 28 ft trailer. less than 25 you might be fine for average terrain and climate. Good Luck with your choice. owe and welcome to the forums
mustang is offline   Reply With Quote
Old 08-28-2008, 04:24 PM   #6
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Not to mention, that your car will be running "hot" on the slightest grade and you're probably not going to be able to use your AC during the summer let alone on hills during the summer. I've mentioned before, I had a 2005 dodge Dakota quade cab with a 4.7L V8, 3.55 rear end and suppose to tow 7000 lbs. My trailer - 25 ft Safari at 5860 lbs dry weight, then you ad water, propane, supplies, people etc. it was very unpleasant worrying if the truck was going to overheat.
BTW, my airstream dealer said when I asked him if the truck could pull the AS......"come here, see that (V8) logo?" Yea I could tow it, yea the truck was heavy enough but to tow a 27 ft or more.... It was outof the question.
R/
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 08-28-2008, 04:25 PM   #7
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Thats a good lookin vehicle Big Jim. It would look bad towing a 23 footer I think, and probably be fine. I Just read 7000 lbs to max.
Old 08-28-2008, 04:26 PM   #8
Road Ruler's Avatar
Images: 38
It does have a nice, short, rear over hang.
Old 08-28-2008, 04:43 PM   #9
Park City , Utah
This is great information. I was told that sway bars might help as well. What if we put our supplies in the TV? Is that just wishful thinking. I ordered the trailer a few weeks ago, I hope our first trip isnt to the Ford dealer to pick up a F350! The good news is if I trade in the Mercedes I should have alot more gas money, wich it looks like I may need!
Old 08-28-2008, 05:12 PM   #10
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
By your own admission, the G500 has a tow rating of 7000 and you have an Airstream with a GVWR of 7300lbs loaded. Add fuel to your G500 and tha weight gets deducted from the tow rating. Passengers and driver in the G500? Yup, deducted from the tow capacity too. Any cargo in the G500, spare tires, jacks, etc....you guessed it, all deducted from the tow rating.
Besides it not having enough wheelbase it's a poor choice for towing something this large, even though it is a fantastic vehicle in general.
I would think about 20' might be the largest I'd tow with something that short on wheelbase.
Old 08-28-2008, 05:27 PM   #11
_
Originally Posted by Big Jim View Post
...I have a 2002 Mercedes G500 with a tow rating of 7000 pounds... Can I do this safely?
hi jim and WELCOME to the forums!
here are the 2 relevant threads with many useful links inside on this issue.
http://www.airforums.com/forums/f463...ing-37963.html
http://www.airforums.com/forums/f463...sel-42737.html
imo the g wagen is a poor choice, given what is at stake. especially from the older chassis.
while the f-250 is built EXACTLY for this purpose and with capacity for MORE should you go larger in a year or 2...
and RIGHT off the lot with mirrors, receiver, and integrated brake controller that do the job.
regardless of how we play with the ratings to make the merc/air combo feasible,
it will be WAY OVER PAYLOAD even if you carry only the bare essentials for camping.
cheers
2air
Old 08-28-2008, 07:28 PM   #12
soldiermedic's Avatar
Florissant , USA
I tow my 29' Ambassador with my Chevy 5.3 liter crew cab 1/2 ton, and have never had an issue. I would think the cedes would be a little light for towing what you want.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 08-28-2008, 08:04 PM   #13
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
BIG JIM WELCOME
F250 Crew would do just great. We tow wiff a F350 Crew/ 8ft/7.3 liter /. IT will pull our 27ft Overlander anywhere we want and I can load the bed wiff what ever I want.
U will do Fine I'm sure Cause U got the rite altitude SAFETY SAFETY SAFETY BOTTOM LINE
Mikethefixit is offline   Reply With Quote
Old 08-28-2008, 08:28 PM   #14
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
3/4 ton diesel
Hey Jim, it looks like you live around a couple "hills". I'm traveling in the mountains north of you and am very glad I invested in a 3/4 ton diesel for our 34 footer. Granted, our trailer is a little bigger than what you've ordered. However, in the last week we crossed the Big Horns west of Buffalo, WY (almost 10,000' elevation) and didn't even think about turning off the air going up hill. Going down hill on those grades wasn't much of a problem either with the heavy duty transmission with tow command allowing me to keep the speed very comfortable without having to use the brakes all the time.
Then we hit Worland, WY and the temps were in the high 90s and low 100s yet the water and transmission temps hadn't budged from normal.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
No towing for me. lendoyle Member Introductions 3 08-30-2006 09:22 AM
Towing perfuse2004 Tow Vehicles 5 10-01-2004 04:51 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
Towing COArgosy78 1969 Overlander 5 09-05-2002 10:18 AM
