Old 02-12-2006, 05:16 AM   #1
2003 22' International CCD
East Durham , New York
Manual or Automatic
Hello,
Can anyone provide information or real world experience towing with a manual transmission instead of an automatic?
I really miss driving with a manual and was wondering if it would be a mistake to consider a tow vehicle with a stick.
My coach is a 22ft. CCD.
Many thanks in advance!
bluvalley
bluvalley is offline   Reply With Quote
Old 02-12-2006, 06:17 AM   #2
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Old Age Creeps In
Greetings,
My legs are toast. After a long spell of traffic they ache bad.
Some new automatics get better mileage than standards, although the initial cost and maintenance is higher.
Think about being stuck in LA traffic for hours just creeping along, you made the right choice.
R
fastrob is offline   Reply With Quote
Old 02-12-2006, 06:17 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Many manual transmissions are really weaker than comparable automatics these days. The maximum towing capacity is usually achieved with an automatic. When shopping for a larger tow vehicle for our coach, I found that the towing capacity was significantly less with a manual.
Old 02-12-2006, 07:17 AM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I pulled a '77 31' Excella 500 for a short period of time with a '92 Chvey 1500 Z71 4X4 with 5.7 engine and 5 sp. manual. I really liked the truck but not with the manual while pulling the trailer. My son solved that problem by rolling the beloved truck totalling it. I bought a'01 2500hd with 8.1 engine and 5 sp. auto transmission. Aside from the larger engine and heavier suspension, the auto transmission took all the work out of towing which makes it more pleasant when going through small towns with plenty of stoplights or negotiating steep hills.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-12-2006, 08:00 AM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Most, if not all modern automatic transmissions have locking torque converters, which allow a direct mechanical connection between engine and transmission. This, coupled with overdrive and 5 speeds, (GM has a 6 speed Allison now!) make the choice of an automatic a no brainer!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
1975 Service Manual casarodante General Repair Forum 4 09-28-2017 03:40 PM
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Owner's manual Cheryl 1978 Excella 11 08-04-2012 09:35 AM
1977 Safari Manual RamblinRose General Interior Topics 2 04-17-2004 04:51 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
