Old 09-22-2019, 05:24 PM   #41
JF
janelf's Avatar
Eugene , Oregon
Anyone give a best guess to what fully packed 23’ safari might weigh? With water - gas- gear. ? What traveling ‘payload’ should I prepare for when choosing a TV? Starting at 5k lbs empty.
janelf is offline   Reply With Quote
Old 09-22-2019, 05:38 PM   #42
VDR928's Avatar
2012 23' FB International
Charlotte , NC
Our 23 ft FB International Serenity weighs 4,500 empty and fully loaded it was right at 6,500 (water, gas, two humans, one dog!) Hope that may help!
2012 23FB International Serenity #Dorytheairstream
2019 GMC Sierra 1500 Crewcab 4WD Denali
"Denali & Dory"
VDR928 is offline   Reply With Quote
Old 09-22-2019, 06:48 PM   #43
2016 30' International
redondo beach , California
Dude, no people in the trailer when on the road!
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 09-23-2019, 10:44 PM   #44
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
Tongue Weight?
Originally Posted by out of sight View Post
An F-150 will do it. No need for a F 250 for a 5000 pound trailer with a 500 lb tongue weight.
Not sure about the differences in ‘05 Safari and ‘17 23D but the hitch weight I measured on my 23D is 800 lbs lightly loaded. While WD sends some of that to the trailer wheels, it still takes a big chunk of the payload capacity on my 1/2 ton Tundra. I love the Tundra but am making to change to a F350 because of payload.
By the way, we’re also trading up to a 28’ AS which makes the upgraded TV more of a necessity.
Am out West right now with the Tundra and it pulls and handles fine just as I would suspect an F150 would do.. It’s just that I’m so payload Limited that I need to make the change.
KK4YZ is offline   Reply With Quote
Old 09-23-2019, 10:50 PM   #45
KK4YZ's Avatar
Hiawassee , Georgia
I think there should be a placard on the trailer giving GVWR (trailer at max load) and dry weight.
Old 09-23-2019, 10:56 PM   #46
2007 22' International CCD
My Airstream has a permanent GVWR plate on the streetside front down low... I suspect it’s required nowadays
Old 09-25-2019, 08:44 PM   #47
DewTheDew's Avatar
2017 27' Flying Cloud
Frederick , Maryland
Originally Posted by olgoat View Post
I wanted to change the drop bar from 2” to 2 1/2” to match the receiver, but apparently there isn’t one available for the Reese SteadiFlex WD system. So I simply adjusted the head placement to be approximately 1” above level prior to hitching. The fine tuned the head angle to restore front TV rise back to acceptable limits. I could add more downforce, lowering front rise even more but I think I like it as is. If I could determine how to post photos I would, but no luck so far.
Hey olgoat; this thread induced me to mention to my wife about moving to an F250 diesel and she glommed onto that like a bear to honey. Going shopping on Monday. We will likely move from a 2017 F150 platinum (7k GVWR, 1543lb payload; I went to a CAT scale on our last trip and I was right at 7k lbs, which is why I'm looking to move up) to a similar 2019 F250 diesel (model I looked at online has a 2024 lb payload, 10k GVWR). From the picture it looks like you also have the Platinum.
I haven't been able to actually get to a dealer so thought I'd ask you; is the receiver the same size as in the F150? I have an Equalizer hitch and hope I don't have to buy another shank. The one I have has a few more holes that I can utilize to account for the taller height of the F250 (also will likely have the FX4 package, which my F150 does not have), which should be a good start for setting it up. Sorry, I'm somewhat of a newbie at this and I'm a scientist so I am doing research and taking advantage of your similar transition! I think we are getting a blue with the marsala interior, but your red one looks sweet! I decided not to wait for the 2020 upgrades since we are going on a long trip this Christmas with extra load (grandkids).
Thanks!
Oh, by the way, for the other commenters in this thread; yes the EB3.5 pulls the AS wonderfully. The problem is payload. I could move stuff around and leave some things at home but my wife doesn't like to load the trailer with my tools and I just don't want to be on the edge from a weight perspective.
I wonder how much this message board has cost me......?? :-)
DewTheDew is offline   Reply With Quote
Old 09-25-2019, 09:09 PM   #48
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Thanks!
You can get a F350 for $600 more payload and rides the same.
Old 09-25-2019, 09:21 PM   #49
2019 27' Globetrotter
Cypress , Texas
DewTheDew, our F-250 is a Platinum with the Marsala interior. We love the interior color. I am not a fan of the Camel interior and my last several vehicles had black interiors, so I was ready for the change.
Unfortunately the receiver size is not the same. The F-150 was a 2" receiver and the F-250 is a 2 1/2" receiver. I looked for a 2 1/2" shank for our Reese SteadiFlex hitch, but they are not available. I am using an adapter, about $20. The fit up is rather poor when you stack all the clearances, but I haven't noticed any issues with it thus far.
I looked at a lot of F-250 Platinum diesel Fx4's and it sounds like the payload on the truck you referenced is a bit on the low side. Most are around 2,190# without the 5th wheel prep and 2,090# with the 5th wheel prep. Just be sure to check the label inside the drivers door. I am not sure what extra options would drop payload to 2,024#. Maybe dual alternators or a pto.
If you do not have plans to tow a 5th wheel at some point, find a truck without the 5th wheel prep, it adds 100# to payload.
Let me know if I can help with anything else.
olgoat is offline   Reply With Quote
Old 09-26-2019, 08:31 AM   #50
2019 27' International
Western , North Carolina
This.. we went looking for a 250 and got the 350. Lots more payload
2019 International Serenity 27 FBQ “Serenity”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 09-26-2019, 09:28 AM   #51
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
The receiver should come with an adaptor for the smaller shank; mine did when I went from our F150Platinum to our F250KR. Some folks don't like using the adaptor; they say the pin hole's become elongated. I can see a very little of that but I have 28K miles towing our 28' and 68K overall on the KR. No issues from my perspective. As for the payload, I also have 2024; plenty of payload for our use...I was told there is no "5thwheel prep" option unless you order it, so shouldn't affect the payload on the 250. The F350 may be different story...extra spring and increased payload.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 09-26-2019, 09:37 AM   #52
KK4YZ's Avatar
Hiawassee , Georgia
If you get an F250 gasser, you’ll have about 3000 lb payload, depending on options. It’s the diesel engine’s increased weight that will drop you to 2100 or so. Going with the F350 pretty much makes up for the payload loss due to the diesel’s extra weight.
Old 09-26-2019, 10:17 AM   #53
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
F-150 axle ratings: front 3525 rear 3800
F-250 axle ratings: front 5990 rear 6340
For a few thousand more you get 2/3 more truck.
out of sight is offline   Reply With Quote
Old 09-26-2019, 01:03 PM   #54
gypsydad's Avatar
Just saw an announcement from Car & Driver today that Ford now has most torque/hp and towing capability with the new 6.7L Diesel. Not that I am thinking about selling my 2017 model yet...only have 68K miles on her!
2020 Ford Super Duty Takes Heavy-Duty Torque and Towing Crowns
Old 09-26-2019, 03:49 PM   #55
CRH
1995 25' Excella
xxxxx , xxxxxx
The 2019 SD's don't come with a hitch adapter.
CRH is offline   Reply With Quote
Old 09-26-2019, 04:02 PM   #56
Yes it cost 25 or so. I did have to purchase
Old 09-27-2019, 12:27 PM   #57
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Ford's new 2020 Super Duty can tow 37,000 lbs, thanks to 1,050 lb.-ft. of torque
https://driving.ca/ford/super-duty/a...b-ft-of-torque
waninae39 is offline   Reply With Quote
Old 09-29-2019, 08:14 AM   #58
DewTheDew's Avatar
it turns out that a lot of the F250s on the lots have the 5th wheel prep. Looked at one the other day without it and yes, it changed the payload by about 100 lbs (I think the one with was 2024 and without was 2135). Probably going to pull the trigger tomorrow.
Old 09-29-2019, 06:52 PM   #59
2015 27' Flying Cloud
North Smithfield , Rhode Island
My wife and I are in the same stage trying to decide if we should swap our 3.5eb f150 for a 3/4 ton truck. Having this information is extremely helpful as we plan to go fulltime this spring.
I haven't towed the AS that much just yet but the 3.5eb seemed to handle it ok aside from a few white knuckle moments but a few is too many for me.
Tkalb2 is offline   Reply With Quote
Old 09-30-2019, 10:56 AM   #60
gypsydad's Avatar
Take it from many of us who have made the upgrade from the 1/2T to the 3/4T with the larger AS's....night and day difference in the "journey" while pulling a 27' or larger AS! No white knuckle experience, plenty payload, and overall great for traveling. No regrets with our 28'!
Made the move... newsgauger All Argosy Trailers 77 11-08-2019 04:33 PM
250 meets 250 meets 250... "made for Germany" in Germany split window Classic Motorhomes 27 11-29-2016 12:44 PM
Any TV off road type tires? 2016 F-250. 250 vs 350? 6.7 Diesel or 6.2 Gas? Need help! Danattherock Tow Vehicles 53 07-19-2015 02:21 AM
250 MH :: 1990 Airstream 250 barend Airstream Registry Discussions 0 08-19-2011 09:32 AM
