11-03-2014, 09:40 PM
Superior
Luv Truck as a Tow Vehicle
Hey all! I have a 1981 4x4 Isuzu Luv Truck and am looking at airstream trailers to tow with it. Important questions:
1. Can you recommend a make/model of Airstream trailer that would be within the capacities of my Luv Truck?
2. Will I need air bags for ride comfort?
3. The sticker inside the door says my GVWR is 5600 lbs. Will I be able to have slideouts?
5. Are you still reading?
6. Will a Hensley Hitch make me look fat?
7. Will braided brake lines help me stop faster?
Thanks for your help and insightful comments that I'm sure will all be factual and un-opinionated.
PS - Please point out any safety issues I may have overlooked.
11-03-2014, 10:23 PM
CHIEF THINGAMAJIG FIXER
bugtussel
, South Carolina
Luv truck
I hope you are mocking some of the questions on here because the answer to your question is NONE!!!!!!
11-03-2014, 10:26 PM
1999 34' Excella
Hillsboro
That's funny!
You could hang an Airstream Christmas Tree ornament from the bumper..
Seriously... You really attempt towing a T@B or similar... then realize the AS will be much more challenging.
Peace and Blessings..
Channing
WBCCI# 30676
11-04-2014, 04:58 AM
Lin
, Ne
I think if you put a Hensley Hitch in the box you will be at max payload.
11-04-2014, 05:37 AM
1995 30' Excella
Bowie
, Maryland
Nice!
11-04-2014, 07:46 AM
Common Sense
An actual attempt to answer your questions, if you are serious.
1. "Can you recommend a make/model of Airstream trailer that would be within the capacities of my Luv Truck?"
Any 16' Airstream, but no larger and then you might not like towing it.
2. "Will I need air bags for ride comfort?
Yes, they would help.
3. "The sticker inside the door says my GVWR is 5600 lbs. Will I be able to have slideouts?"
No.
5. "Are you still reading?"
Yes, I'm enjoying it.
6. "Will a Hensley Hitch make me look fat?
No, but it will make your rig lower and longer. (they are too heavy for you)
7. "Will braided brake lines help me stop faster?"
Now I know you are not serious, but the answer is no.
It was good for me, how about you?
Regards,
Steve
11-04-2014, 08:00 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
If the hitch ball is bolted to the bumper, it will tow much better.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-04-2014, 08:22 AM
Refugee from Napa, CA
2015 25' Flying Cloud
Formerly Napa
, On the road
I was thinking the hitchball should be on the rear view mirror...
Instagram. Alluminator
11-04-2014, 08:41 AM
2015 30' Classic
Calgary
, Alberta
No, you NEED a 3/4 tonne or 1 tonne dually diesel pickup to pull ANY airstream and a Hensley is required or anything above a 5mph wind will induce unrecoverable sway. The great advantage to the pickup is that when not towing you'll have a large compartment to store your lunch box to/from to work and the ladder needed to get into the cab. They also have the wonderful ability to just plow through an accident instead of being able to avoid them and making friends with the local gas station attendant is made much easier due to frequent visits.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
11-04-2014, 11:14 AM
2013 30' Classic
Greenwood
, Mississippi
I never knew there was an Isuzu Luv. I thought it was Isuzu P'up or Chevy Luv- same truck either way-
I know someone is being silly, but a P'up/Luv might tow a 16' Airstream.
I pulled utility trailers, cargo trailers, and horse trailers (albeit not very fast and it didn't climb hills well) with a 1987 Mazda B2000-
I would have pulled a 16' Airstream with that Mazda.
Does your Luv have a Prodigy, Hayes, or Tekonsha brake controller?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
11-04-2014, 12:43 PM
Superior
I'm not sure what you mean. My brake controller is my right foot.....so maybe it's by Nike?
11-04-2014, 01:32 PM
2000 30' Excella
Monticello
My guess that will end this thread ?
11-04-2014, 03:35 PM
Superior
Too much of a good thing?
11-04-2014, 03:59 PM
2013 30' Classic
Greenwood
, Mississippi
Does your Luv have a 4 speed or 5 speed?
Do you have to leave it in third gear to tow?
TAC #MS-10
Airforums #70955
11-04-2014, 04:28 PM
2014 28' International
Blacksburg
April fool
LOL, M.Hony, caught it. its 'Chevy luv' . can you get 13" D load range tires ?
If its a 81' I bet the frame is rusted out, or you have re-welded your welds? If you have the diesel Isuzu P'up, you have a fuel mileage champ. Check the frame.
At least he didn't say 'S-10' LOL
Have a good one.
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
11-04-2014, 04:48 PM
2002 31' Classic
Monroe
, Iowa
If you can tow a Bambi with a bicycle, you can tow one with a Luv truck.
Your best bet would be to draft a tractor trailer rig as you drive down the road. Slip the driver a couple of 100 dollar bills to take you right where you want to go.
You won't need a brake control if you mount tires on the front of your Luv truck. In a panic stop, you will run into the back of the Semi, tires on front absorbing the collision.
Hitch ball on bumper is OK as long as you safety wire the bumper to the frame with bailing wire. (Duct tape will work if you don't have bailing wire)
Bring a log chain so you can chain your Luv to the semi if you run low on gas, or get into really big hills.
Did I miss anything?
11-04-2014, 04:53 PM
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
nobody mentioned yet to make sure you followed up with all the re-calls on your Luv before you start to pull ... or hold on.. that was chevy.. not isuzu
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
11-04-2014, 05:15 PM
1972 27' Overlander
Penokee
, Kansas
I had a Luv pu years ago,, and for myself I would not pull a 5 foot trailer with a riding lawn mower on the back for more than a few blocks.. There is nothing left for reserve power or brakes for anything else...
The clutch and transmission were hardly enough to pull the pu around let alone any trailer for any distance.
Sorry..
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
11-04-2014, 05:16 PM
2013 30' Classic
Greenwood
, Mississippi
Have a good one.
It would have had 14's...
TAC #MS-10
Airforums #70955
11-04-2014, 05:32 PM
Builder of Diesel Jeeps
Sedona
The 52 hp diesel will pull Wally Byams beret off your head, but that's about it.
14 Serenity 28'
15 Grand Cherokee EcoD
#5261
