Old 11-27-2013, 10:20 PM   #1
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Looking for feedback on Ram 2500 5.7 ltr
I've finally "bit the bullet" so to speak. and purchased a new truck. A 2013 Ram Power Wagon 2500 5.7 ltr gas motor.
My previous TV was a '99 GMC Suburban 2500 4x4, while a great truck, it was on the verge of being retired as a dedicated tow vehicle due to high mileage and becoming a maintenance nightmare!
Being that it's winter and we're all settled in...I wont be hooking up and doing any towing for 4-5 months I'm looking for any feedback as to what I can expect as far as performance from my new Ram.
Anyone by chance towing with a late model Power Wagon? Or with a 5.7 ltr V8 6 speed tranny?
Just trying to get a "heads-up" on what to expect from my new ride....
truxpin is offline   Reply With Quote
Old 11-27-2013, 11:37 PM   #2
2017 27' International
Fall City , Washington
Sweet truck. Why not the Cummins?
2014 28' Flying Cloud
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 11-28-2013, 10:18 AM   #3
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Yea, I have been getting that a lot! Not even an option on the Power Wagon, for one. Mostly because I just didn't want the higher costs associated with the diesel. We live in our '34 Limited, and while we may pick-up and go on vacation with it a few times a year (which the Ram is certainly capable of) we've reserved to purchasing a "smaller" Airstream for our travels. Something a little lighter and more maneuverable, and more suited to the gas burner Hemi V8.
I'm gonna save the big diesel purchase for the next phase(retirement) when we're afforded more time to wander.
Old 11-28-2013, 10:49 AM   #4
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
Although I don't have the Power Wagon, we do have a 2007 Durango (last year on the truck frame) with a 5.7 Hemi. We have had 70,000 trouble free miles, with 1/2 the miles being used for towing. First a 25 Safari, now a 27 Classic.
The Hemi tows without straining, except on really step grades. Not one problem with the drivetrain -- she runs cool, even with the 109F temperatures we had last summer on a 3,000 mile trip.
The only problem we had was a frozen caliper at about 50,000 miles. I am about to do the pads on the rear brakes for the first time this month.
Good luck -- nice ride!
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 11-28-2013, 05:19 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Scale it, and compare HP/LB to 1/2-ton and other Hemi-powered vehilces (such as the Charger). Compare actual first gear ratios and total braking distances from 60-mph.
A gasser truck is penalized by un-needed weight (vehicle type + construction), and penalized again compared to a diesel by its lower compression ratio (a comparable diesel won't notice 1k in the bed, but mpg on a gasser really drops).
Bang for the buck comes down to cents-per-mile of ownership. EDMUNDS has a good comparative page on this.
Solo miles rule for the vacationer (versus the fulltimer). How far off it is from other TV's with the same engine will tell the story (as an A/S doesn't need a truck).
slowmover is online now   Reply With Quote
Old 12-01-2013, 11:51 AM   #6
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Thanks for the "real world" review Tkowalyk. In todays 3/4 ton trucks I've noticed it's getting harder and harder to find any with gas motors. The little bit of on-line info I can gather about the Power Wagon is "sketchy" at best. No 2 sources have any identical info, which leads me to wonder how accurate ANY of the info I'm gathering really is! Even the Ram.com page has different stats than what is represented on the truck itself.
Thanks for the info, Todd.
Old 12-03-2013, 10:08 AM   #7
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Nice truck!
The only thing I think you might need are some running boards and mud flaps on the truck.
Just the other day I was curious about the 66RFE transmission in the gas 3/4 ton trucks and found it to be geared identical to the 68RFE used in the diesel trucks.
The 68RFE and 66RFE automatic transmissions for Ram trucks
If I recall the Power Wagon has really low axle ratio - you should have a 4:56 gear set.
With the transmission gearing and low axle ratio you shouldn't have an issues pulling. Fuel mileage will be your only concern.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-03-2013, 01:23 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We tow with a 2012 Ram 1500 5.7, 6-spd. Sweet engine and very pleased with gas mpg. I would say you could expect a lot of down-shifting or running in 4th gear most of the time towing due to your heavier truck/trailer weight and higher wind resistance of the truck. But you may have the low differential gears which can make all the difference in power. The power seems to come on well above 2400 rpm, so towing above that will probably be needed.
That's a high center of gravity with some stability concerns. Leave plenty of room to avoid quick lane changes.
Doug and Cheryl
Old 12-04-2013, 05:20 AM   #9
JFScheck's Avatar
Rockville , Maryland
Images: 33
Wonder if they will put the new 6.4 in the 2500 Power Wagon!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 12-04-2013, 06:51 AM   #10
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Yup, the '14 gets the 6.4 V8 w/MDS to kill 1/2 the cylinders under light load. Plus a bunch of other upgrades to suspension, frame, and luxuries on the inside.
It was tempting to wait and find a '14 instead of the '13, but price won me out in the end. $38,200+ttl, well below sticker and priced to move! So far I'm pretty happy with it. (of course! It's a new truck!) First tank of gas it averaged 11.3mpg( NOT a factor in my purchase criteria) I knew it wasn't gonna get good milage, but it IS an improvement over my GMC 2500 Suburban 4X4 (10mpg)
Rifle deer season starts today, so tomorrow I'll get a chance to see how it handles off road, along with some light towing.
Old 12-04-2013, 06:55 AM   #11
crispyboy's Avatar
1994 30' Excella
Looks like the 6.4 is the only option on the 2014 models.
2014 Ram 2500 HD Power Wagon First Look - Truck Trend
WBCCI # 3072
Old 12-04-2013, 09:23 PM   #12
tkowalyk's Avatar
2013 27' FB Classic
Images: 11
Originally Posted by crispyboy View Post
Looks like the 6.4 is the only option on the 2014 models. 2014 Ram 2500 HD Power Wagon First Look - Truck Trend
Nice truck - good gasser option
Tom & Lori
Airstream parkway 2006 2500 mpg with toad? Jgjimgrn Sprinter and B-van Forum 3 03-03-2012 12:03 PM
06 Ram 2500 and 08 Classic 27' breazy Tow Vehicles 9 01-17-2012 08:05 PM
2010 Ram 3500 MegaCab - Took the Diesel Plunge! Freeheel Tow Vehicles 9 01-18-2011 07:19 PM
2010 RAM 1500 Integrated Brake Controller Mifair Brakes & Brake Controllers 1 01-16-2011 05:07 PM
New Tow Vehicle - 2010 Dodge 2500 sgray Tow Vehicles 13 01-11-2011 07:41 AM
