Old 11-07-2011, 05:42 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Looking for a Tow Vehicle
Money is tight and I cannot afford a new truck. I have not been crazy about the prices of trucks and Vans I am not sure of. I need some advice in purchasing a 2nd Tow vehicle since I will have two airstreams. I pull mine with my Dodge Ram, but I need a second for my son.
What about a 1980's or 1990's Crown Vic? They have a 5.0L engine and they look like they could be pretty comfortable. The price seems pretty good on those cars. I would not mind buying a old Van with a big enough engine. One you could stand in would be great. Any advice would be welcomed
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 11-07-2011, 05:44 PM   #2
1981 31' Excella II
New Market , Alabama
What is your budget and how good are you at fixing things?
Perry
Old 11-07-2011, 05:47 PM   #3
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Your son is pulling what again - a early 60s Overlander?
Tom
mutcth is offline   Reply With Quote
Old 11-07-2011, 06:02 PM   #4
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Crown Vic Police Interceptor would be cool.
Should be a lot of them coming up on auctions as police forces start modernizing.
Weren't they something like 1,000 lbs tow rated?
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 11-07-2011, 06:19 PM   #5
Lothlorian's Avatar
The 1960 Overlander would be pulled with the 2nd tow vehicle. The Overlander Dry weight I think is 3270 Lbs. I am not the engine mechanic. One of the reasons I went with a trailer instead of a motorhome.
Brian
Brian & Adrienne
Old 11-07-2011, 06:28 PM   #6
Lothlorian's Avatar
I have researched and this is what I found. I found different points of views. One guy said that the crown vic would make a great tow vehicle that Ford deliberitly down graded the towing ability so people would buy SUV's. Another said the Crown Vic would be good but you would need to put a transmission cooler on it.
I am open for any kind of Used Tow vehicle that could seat four people. I will continue to search.
Brian
Brian & Adrienne
Old 11-07-2011, 06:33 PM   #7
SteveH's Avatar
Common Sense , Texas
Any vehicle you buy to tow with that did not come from the factory with the towing package, will need a transmission cooler, that is if it has an automatic trans.
Regards,
Steve
Old 11-07-2011, 06:49 PM   #8
one of those
Gringo's Avatar
Might be time to run your Crown Vic idea by that RV towing guy in Canada. Can Am or something like that, isn't it? They can tell you what you would need to do to tow with that vehicle, I bet.
Old 11-07-2011, 07:03 PM   #9
r carl's Avatar
Lin , Ne
Wasnt the Pinto rated for 1,000lbs?
r carl is online now   Reply With Quote
Old 11-07-2011, 07:19 PM   #10
one of those
Gringo's Avatar
Was that with Firestone 500's all round?
Old 11-07-2011, 09:33 PM   #11
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Brian!
Brian
My suggestion would be to consider something like a Buick Roadmaster Estate station wagon from the mid-to-late 1990s. These were available with a trailer towing package that included the LT 1 5.7 Liter V8, and when equipped with the 3.23 differential gearing were rated to tow a trailer the size of your son's Overlander. Similar Buick Roadmaster sedans as well as Cadillac Brougham d'Elegance from the same time period were available with the same options including the trailer towing package. I am not certain whether the very similar Oldsmobile Custom Cruiser wagon was available with the heavy duty trailering package. The Chevrolet Caprice from that time period may also be a candidate as I believe that it was available with the LT 1, but I haven't encountered as many utilizing that particular vehicle. I would suggest staying away from any of these vehicles if it doesn't have the LT1 option . . . the 5.0 Liter V8 just doesn't have the power for an Overlander (IMHO).
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 11-07-2011, 10:15 PM   #12
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I would go for a mid to late 90's van. I have a 93 van and it is real low on power and torque. It is 5.7L and only 195 hp. In 94 or 95 they boosted it to 250 hp. I suspect a similar increase in torque.
Vans don't hold their value well, so you can get the most bang for the buck in a van.
Dan
Old 11-08-2011, 04:23 AM   #13
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Rear wheel drive
The DW drives a 94 Mercury Marquis {same as Crown Vic}. I always thought that with a beefed up suspension an tranny cooler it would be a good TV. Very few cars at that time had rear wheel drive. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 11-08-2011, 04:47 AM   #14
r carl's Avatar
Lin , Ne
No, the Firestones would outlast those cars.
The molds for those Firestone 500's must be in china now.
Van Conversion/Small Motorhome as tow vehicle? TG2500 Tow Vehicles 0 10-16-2011 06:07 PM
Tow Vehicle for 27' Overlander pyrenees Tow Vehicles 9 05-06-2011 08:18 PM
The ultimate tow vehicle! I found it! brad1 Tow Vehicles 8 03-21-2011 07:47 PM
