Old 02-12-2012, 04:58 PM   #43
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Originally Posted by starcraft View Post
New fords look pretty good on paper.
......and off road and towing,,,,and with a Airstream in tow.
I have 36,000 miles and love my 6.7 diesel the same as I did driving it off the lot. Ford hit a homerun with these trucks. VERRY happy and satisfied Ford guy here.
Also I agree def is a non issue.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 02-12-2012, 07:02 PM   #44
JFScheck's Avatar
Rockville , Maryland
Images: 33
Concur with "ThePill"...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 02-14-2012, 01:59 PM   #45
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Originally Posted by REDNAX View Post
I'm getting 16+ mpg towing the trailer.
What is your travel speed?
The number is consistent with at least a half-dozen others using 2nd & 3rd Generation Dodge diesels, pulling 28-34' A/S, Avion and Silver Streak trailers.
Glad to hear of your good fortune with the truck (knock on wood). DTT and a couple of other shops seem well-regarded if the transmission ever becomes troublesome.
I tow at just under 60mph - between 57 and 59 mph with cruise on.
The lead diesel mechanic at our local Dodge dealership is a long-time personal friend. His advice was don't mess with the engine - no chipping - as the additional torque will shorten the life of the 4-speed auto tranny. The truck is equipped with a transmission oil temp gauge, and it is pretty much steady at 140 degrees, but does rise some when in stop and go city traffic.
All in all it was a good purchase (makes up for all the times I screwed up).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 03-15-2012, 04:10 PM   #46
mefly2's Avatar
2015 25' FB Eddie Bauer
16+ mpg towing FC20 on relatively flat terrain @ 50-55mph
Don't know why any of you are worried over DEF. The trade-off of a bit more complexity is offset by higher fuel mileage. The non-DEF trucks are cheaper to buy, but the cost difference comes back out in re poor fuel mileage. DEF has the advantage.
Not seeing a higher fuel mileage in the many rigs of DEF diesels owned by friends around here. They are envious of the fuel mileage we are getting. I must add that we are using a fuel addative ($tanad^ne) that might partially offset any cost saving of not needing the DEF; but friends put the same addative in their diesel fuel as well as DEF. We certainly did NOT find the non-DEF Dodge Ram cheaper to buy than a DEF added GMC, Ford, or Chevy! Equipped the same, the Ram 2500 was a couple of hundred dollars more - but we really liked the features and got a great deal! Of course YMMV and we are driving in a higher altitude area of a cold weather state.
Old 03-16-2012, 10:39 AM   #47
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
That's a consistent number, then, and I thank you for the context. It is the highway speed I run as that is the "fastest" slow speed one can attain just prior to the onset of aero resistance. (The resistance curve shoots skyward). Also, CUMMINS indicates best mpg when engine is at 1300-1500 rpm, so the closer we are, the better.
The CTD is one heckuva truck. Much the best vehicle I've ever owned. And, while I agree with your mechanic, depending on the model year, a CTD can have retarded engine timing. FYI, a SMARTY JR used on or one step up from default configuration "restores" engine timing without adding extra fuel (where the problems of transmission longevity arise). There is no free lunch, one is not, IMO, "free" to use the additional umph so much as letting the trans shift early as the engine rpm rises that much more quickly. IOW, that "the truck is quicker" is not quite to the point . . it is that the engine does not "hang" prior to a shift (if that makes sense). And there is a measured FE benefit of around 1-mpg for average mpg.
One does not have to a boy racer to use some tuners for effectiveness (where burning less fuel is rightly understood as "performance").
But I don't have on either. And for the same reasons as your mechanic cites (in principle: potential reduced component life). But I'm tempted since with a manual transmission I might achieve just that much more control. About $600 USD. A reduction of about .5/gl per 100-miles (22/gls per 10k miles) for my truck & use. But better quality shifts might make the long payout worthwhile.
Thanks again. That makes about an even dozen owners of CTD trucks with 28'-'34 (8k-11k) aero aluminum trailers (Avion, Airstream, Silver Streak) who achieve that fuel mileage while underway with otherwise stock trucks.
Virtual Inspection - Please give your input WineStream Dollars & Cents 25 02-24-2009 10:26 PM
input please gleebin 2007 Safari 12 04-29-2007 03:42 PM
Tow Vehicle input and ideas please! modnodd Tow Vehicles 11 12-21-2005 12:39 AM
2005 Bambi 19' interior scratch repair input please! Rhodie 1997 - 2004 Bambi 13 06-16-2004 09:22 PM
Photos on the Portal Page. WE NEED YOUR INPUT! Vote please! Andy R Our Community 6 10-25-2002 08:55 AM
