Old 02-06-2010, 02:44 PM   #1
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Longevity of Ford V10 engine.
I am looking at purchasing a vehicle with a Ford V10 engine in it. It has been used for shuttle purposes do no extended high speed driving. Oil changed every 3000 miles and has received all factory maintenance required. How many miles should I expect out of this engine?
2007 Safari FB SE LS
2008 F-250 Lariat Power Stroke Diesel Crew Cab
WBCCI 1538
To err is human. To arrrrrrr is pirate.
altamont is offline   Reply With Quote
Old 02-07-2010, 10:32 AM   #2
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
v10 mileage
I recently began looking for a v10 powered unit to replace my 460v8-the new ford v8 is not offered as of now in the E series. You cannot find them. Why? noone wants to get rid of them...they are that good. smooth, long lasting. I finally found what I wanted, and the dealer finally met my price (after me walking away and another 3 months of time!) so i now have a v10 powered cargo E series van. it is my understanding that these are wonderful engines, but no longer to be made. too bad.
good luck
ol' bill
wmarsha is offline   Reply With Quote
Old 02-07-2010, 10:38 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
They easily will top 180,000 miles, and I've seen them with well over 200,000 still going strong. the very early 6.8's had a tendency to eat their own pistons, but that seems to have been corrected. I can't remember the last time I've seen one with galled pistons.
As for them no longer being made, it's probably more to do with the lower fuel economy (@$3 a gallon) than anything else.
Old 02-07-2010, 10:50 AM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I've talked with a ton of people that have had that engine; no one has said any negative things about it.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 02-07-2010, 11:31 AM   #5
tintent's Avatar
1996 34' Limited
humboldt , Iowa
We own a 2000 Ford Excursion with V10. We use it to pull a 34' Airstream. We had to replace the exhaust manifold bolts on the left side in 2008. In 2009, we replaced the right side bolts. Other than that, we haven't even changed the spark plugs. It has 135K miles and still going strong. Drove it from Iowa to Vancouver, BC on the interstate (without trailer) on cruise control set at speed limit and averaged 16 mpg. My wife and I thoroughly enjoy using it with our Airstream.
tintent is offline   Reply With Quote
Old 02-07-2010, 11:53 AM   #6
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
My 2000 Excurision with V-10 has 58230 miles on it most of that pulling my Squarestream trailer.We have had no problems with it.
The only problem that I have head of is spark plugs blowing out on them,BUT I know no one that has had that go wrong.
My wife dose not like the leather seats.She said that the fabric one are more confortable on long trips.
Jimmini :
AKA : TUMBLEWEED. Just an old deplorable buzzard cling to my guns,& religion ,who loves & served the good old USA.
Cowboys have a way of looking at things a little differently than most folks.
jimmini is offline   Reply With Quote
Old 02-07-2010, 12:02 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
good luck
ol' bill
Apparently no one has told Ford that they are no longer to be made. They still list it as one of the engines on their website. Of course I was looking in the F series. the E series is here. I have looked a little lately, and they do seem to be unusual, though.
Vaughan
Old 02-07-2010, 01:05 PM   #8
banjobill
wmarsha's Avatar
2000 30' Limited
new v8 and diesel
I tried unsuccessfully to purchase a 2010 E series with either the new gas v8 and 6 speed torqshift, or the 3 valve v10-all of which are offered in the F series. I did find a 2007 that had been sitting on a dealer's lot since 8/07 with a 2 valve v10. I discovered that in the WAGON E series(passenger), the v10 is no longer an option. So, my assumption was that the v10 would no longer be available after the 2011 year. I could very well be wrong on that, but I seem to remember reading the new gas V8 was to replace the V10. Ford is building a new diesel to keep the diesel engine under Ford mfg, again, this engine is in the 2011 F series which is being touted now. the 2011 E series has not been announced as of now.
bill
Old 02-08-2010, 05:28 PM   #9
holland , Michigan
This is interesting. If they drop the v10, a risky move in many ways. Lots of loyal Ford 3/4 ton and up customers went with big gasser due to all the problems with the diesels. Also, the rv industry must be scratching their heads. Most low to mid level Class a/b and c have the v10 since Gm dropped the 8.1. This may really change things for them. I just do not see where a 6.0 g.m can replace the v10. 6 speed might help, they need to get the torque ratings higher by a or longer stroke or a blower. The marine industry is still offering 8.1 in some new models. Go figure.
I have never understood the difference on the e series and f series 5.4 for example. Must be accessibility or cooling or something. Why would you build 2 different versions of the same thing? Maybe that is why they call it a modular design.
safari 28 is offline   Reply With Quote
ford v10 and allison 5 speed auto wmarsha Tow Vehicles 0 08-21-2009 01:47 PM
1997 airstream by thor 190 bvan ford v10 19' excellent! eBay Watch Airstreams on eBay 0 08-14-2009 09:00 PM
Ford V10 2WD Silver Lining Tow Vehicles 12 07-04-2009 06:00 PM
72 Tradewind Inverter Longevity yochanan Electrical - Systems, Generators, Batteries & Solar 3 07-04-2006 12:03 AM
B190 engine, 460 vs V10 dougfur Sprinter and B-van Forum 3 09-02-2004 09:48 AM
