Old 07-23-2014, 12:55 PM   #21
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
long wheel base issues..
It just depends on how skilled a driver you are.I ran into flood waters in MN last year on a narrow county road with no shoulders that was blocked off and backed up 1/4 mile onto a tree lined private drive,never a problem.
Nothing is as stable on the highway than a large wheelbase truck That weighs 9300lbs.
400 hp 800ft lbs torque.Smooth
Old 07-23-2014, 12:59 PM   #22
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I was thinking maybe 18" longer-
A foot and a half-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-23-2014, 01:23 PM   #23
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
you da man..
1/4 mile backwards is a long fricken way especially on narrow road. I am guessing there was no or light traffic?
How about putting a hitch on front of truck to use in case of too tight camping spot or does that hardly every come up.
PS,, What is that in the back,, Harley or ATV
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 07-23-2014, 01:42 PM   #24
Moflash's Avatar
That is a two up Can Am Outlander max 800 atv.By the way I backed around and thru the backed up traffic in MN.just returned from a 7800mile adventure and not once did I wish for a smaller rig
Old 07-23-2014, 01:50 PM   #25
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We bought an inexpensive 5' x 8' steel utility trailer with drop-down ramp, easy to load/unload for the heavier hauling, and have a maneuverable short wheelbase truck to pull it and our Airstream.
Doug and Cheryl
Old 07-23-2014, 01:54 PM   #26
dkottum's Avatar
Makes sense for those who travel with that much gear.
Doug and Cheryl
Old 07-23-2014, 02:33 PM   #27
Moflash's Avatar
Cant take the trailer and Airstream together.I have trailers also.I like to take things on my adventures.A atv to me is a must for exploring places like Moab Utah , Taylor Park Colorado,Alaska or ???Sometimes I take a motorcycle along to enjoy the scenery or pack for a month of off grid Airstreaming.A short box,well I have had many they look cool but for me are not a option.
A short wheel base regular cab is also not a option for me due to severe space limitations (I sometimes take people with me) and the unique handling they all exhibit when hooked to a long trailer( I have had many short box regular cabs also).
They make different vehicles designed for different applications.This is the perfect one for what I use it for(the atv in the pics above weighs 850 lbs alone),I have found no faults or drawbacks with this setup.
I recently parallel parked with trailer attached in eastern downtown Duluth MN in order to go to a Diners Drive Inns and Dives recommendation for pastrami.Wanted a home made pastrami sandwich so..............
Old 07-23-2014, 02:55 PM   #28
dkottum's Avatar
Moflash, we all travel differently and nothing wrong with that.
As for "unique handling they all exhibit", we were uncomfortable with two different w.d. hitches on 140" and our present 120" wheelbase in strong gusting crosswinds. Put on the Hensley/ProPride hitch design and it is no issue whatsoever.
Doug and Cheryl
Old 07-23-2014, 03:20 PM   #29
Moflash's Avatar
Your right Doug we all have different agendas and there is not just one solution for Airstreaming.
I also did not like the way the wd hitch beat up my trailer so I installed a Airsafe hitch and now it just bounces around on its own cushion of air with the wd attached..
Old 07-23-2014, 09:46 PM   #30
carl2591's Avatar
2005 31' Classic
how about a front hitch setup for maneuvering trailer in tight sections..
anyone have this on a truck.
how does it work out and how many time it been used. ??
Carl, Raleigh NC
Old 07-23-2014, 09:54 PM   #31
Moflash's Avatar
You would only see the front of the trailer.Learning to back up your trailer with your mirrors is the only way.Practice in a large parking lot,you will see how easy it is.
Old 07-24-2014, 05:48 AM   #32
carl2591's Avatar
2005 31' Classic
from backing up while driving a tractor trailer,(long haul and city delivery 8 yrs) to backing up while pulling a boat for the past 30yrs and backing up pulling a utility i use in my business I can assure you going backwards with mirrors is not that big a deal.
I understand you only see the front of the trailer. I was actually thinking about places where the long wheel base and tight camping spots could make it hard to "just back in normal". Plus i have a co pilot and can get a wireless camera to use on back of trailer to see going backwards.
With a front hitch you get more maneuverability in tight spots.
I was asking if having a front hitch is worth the money, $213.00 at etrailer.com or not.
Carl, Raleigh NC
Old 07-24-2014, 08:25 AM   #33
Moflash's Avatar
I never have found a instance that I could not use my mirrors in tight places with a long truck and a 28ft Airstream.
Old 07-24-2014, 11:08 AM   #34
MYater's Avatar
1948 22' Liner
Roy , Utah
Send a message via AIM to MYater Send a message via Yahoo to MYater Send a message via Skype™ to MYater
Originally Posted by carl2591 View Post
what are the plus and minus of longer wheel base vs shorter.. most likely going with 28-30 AS or SOB depending on what happens in the future.
I think the biggest plus of the extra length allows for less sway of the tow vehicle and prevents loss of control and then the really bad things......
"Some things you can tap. Some things you can hit. Know which one is which!"
1948 Airstream Liner 22'
MYater is offline   Reply With Quote
Old 07-24-2014, 11:22 AM   #35
MYater's Avatar
1948 22' Liner
Roy , Utah
I built my front hitch for my Dodge and have pushed a couple trailers using it with good success. They are nice and if you really think you will use it and the money is there, go ahead.
However, the question of worth it? I would say no. I built mine too use while on rescue missions and work related tasks (I reverse my truck and use my winch to pull disabled vehicles and trailers up onto my flatbed so the trailer doesn't tip up [so much easier than a come-along])
But for parking trailers, I've only used it two or three times in six years. Not really worth the manufacturerd price.
Old 07-24-2014, 01:18 PM   #36
dkottum's Avatar
It's been twenty years since the Hensley hitch was introduced, ELIMINATING the possibility of trailer sway, yet folks still recommend longer or larger trucks to REDUCE trailer sway.
Doug and Cheryl
Old 07-24-2014, 01:38 PM   #37
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Put a Curt 31051 front hitch on the front of the Dodge 2500HD diesel, just in case. Not much weight or expense. Not been needed to date. No issues backing 31' Airstream trailer into spaces. Not embarrassed to take it slow and get out to double check.
Old 07-24-2014, 02:11 PM   #38
Moflash's Avatar
There is more to it than the magic Hensley hitch can provide Doug,sorry.....
Old 07-24-2014, 03:03 PM   #39
N/A , N/A
Agreed. I read in an Airforum thread, a while back, someone experiencing sway with Hensley. I think to say it can eliminate sway is just marketing language, and not physically possible.
rostam is offline   Reply With Quote
Old 07-24-2014, 04:11 PM   #40
dkottum's Avatar
There's no magic to the Hensley/ProPride design, it's actually pretty simple mechanics. I think most of us have been quite surprised, and I think you would be too. No sway ever, the trailer stays in perfect alignment with the truck in the heavy gusting crosswinds, its a pleasure to tow in any traffic and wind conditions with our 120" wheelbase truck.
You would need the other reasons for a long wheelbase truck, sway control is no longer one of them.
Doug and Cheryl
Short Wheel Base Towing? Sean Woodruff Hitches, Couplers & Balls 14 08-27-2009 12:31 AM
Wheel Base Length LONG or SHORT??? shermantic Tow Vehicles 34 05-07-2009 09:18 PM
Wheel base on 24' 1974 Argosy MoHo keith53 Argosy Motorhomes 4 11-24-2008 09:37 AM
TV wheel base ? LI Pets Tow Vehicles 8 01-06-2008 03:45 PM
