Old 03-06-2009, 05:28 PM   #85
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
2006 "0ld"
My sex life is like a Ferrari...
I don't have a Ferrari. 😘
“It’s a crooked piece of time that we live in….”
John Prine
"Tahawus"
Old 03-06-2009, 05:31 PM   #86
MuddyAxles's Avatar
Cowtown , New York
Your 2006 spit a plug??
Tow vehicle: 2006 E-350, SD Chateau, Quigley
MuddyAxles is offline   Reply With Quote
Old 03-06-2009, 06:01 PM   #87
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
There was and probably still is a solution to bad threads—it usually happened from cross threaded spark plugs in the softer metal of aluminum heads. It's a heliocoil, perhaps spelled right. Never used one, never saw one, almost have cross threaded plugs, but not quite. Sounds like something screwed into the hole and it opens and grabs it and provides a new thread for the plugs. Sure would like to see that Ford with plugs flying through the hood though.
Gene
Old 03-06-2009, 06:43 PM   #88
1972 Travelux Princess 25
Cobourg , Ontario
Years ago when I worked in a garage we had a 4 cylinder Pontiac towed in. It was 7 years old and still had the original plugs in it. The driver just kept driving until it would not start anymore. The whole ignition system was burnt out. It cost $700 to fix it and this was 20 years ago.
Quite an expensive set of spark plugs.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 03-07-2009, 07:26 AM   #89
MuddyAxles's Avatar
Cowtown , New York
Lightbulb Close enough
Gene
Heli-Coils have been around for decades. We used them when I worked in a machine shop to make repairs to non-critical pieces in the production process. That was thirty years ago.
The work piece (cylinder head) has to be accessible enough to drill, tap, and thread the coil into the hole, The coil is stainless. I have heard they work very well for this, but have never used it.
The usual method to try to prevent blow-outs is to re-torque the plugs every 40,000 to 50,000 miles. I have read where people have gone through and pulled every plug, check it for gap, etc., coated the threads with a product to help prevent seize-up, and re-torque them at the chosen interval, replace them at the second interval, if all were good before.
Many folks do not realize that threads must be clean, dry, and in the case of aluminum/steel connections must be coated with at least a light film of oil, if not an anti-seize compound otherwise there may be thread tearing and definitely you will not get a true torque reading.
I believe I remember there was a special "anti-seize" recommended for the steel/aluminum contact made by the plugs, which would be different from a steel/steel connection elsewhere.
Just stuff to remember.
Slimp Dolly JimGolden Hitches, Couplers & Balls 13 06-21-2009 02:38 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Slip Fitting On Top Of Black Tank To Toilet Radman Sinks, Showers & Toilets 3 05-02-2007 03:11 PM
85 Limited robandzoe Cleaning, Stripping & Polishing 2 05-28-2004 05:00 AM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
