Old 03-14-2016, 03:10 PM   #15
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
Just to bring you up to date on this, I discussed it with a local diesel mechanic, and he agreed that there probably was an overflow valve on the fuel tank, but that the gravity feed from the auxiliary tank shouldn't cause it to open. Based on that feedback, I decided to bring it in to Ford, as my best guess was that the fuel filler hose was leaking where it fastened to the tank, and if so, it should be a warranty repair. It was a roll of the dice, because if Ford found that either there wasn't a leak, because it was normal operation of the overflow valve, or that it wouldn't have leaked in normal operation because it wasn't designed to be full for long periods of time, then I would still be out the $200-$300 to drop the tank and inspect the fittings. However, Ford did replace a defective O ring where the fuel filler hose connects to the tank, and did not believe the normal operation of the auxiliary tank should cause any problems, so they authorized the repair as covered by warranty. Yay!
McDave is offline   Reply With Quote
Old 03-14-2016, 03:24 PM   #16
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Good to know! Thanks for the update.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 07:38 PM
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2009 10:21 PM
Leaking hi pressure water heater hose Astrodokk Water Heaters, Filters & Pumps 8 06-05-2005 10:13 PM
Leaking fuel tank in MH...need 2nd opinion. Astrodokk Mechanics Corner - Engines, Transmission & More... 5 01-07-2005 09:51 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
