Old 01-11-2007, 10:48 PM   #1
Clayton , North Carolina
Leaf Spring Assist for my TV
Plan on using E150 5.8 as my future TV, but I would like to beef up the rear springs a bit. I still plan on using an equilizer/sway device and limiting to 24' in length.
I have a set of AirLift bags on my Toyota pickup and they work great. But I wondered about Timbren and if anyone has used them and their thoughts on them.
Paul NC is offline   Reply With Quote
Old 01-12-2007, 12:35 AM   #2
1960 24' Tradewind
santa barbara , California
Hello Paul NC ,
Ive talked to a few people about the timbrin ,they are like big rubber bumpers
that take the load under load.Eaton Detroit Spring can build you new rear leaves by application ,you give them your vehical info and number of leaves and that you want to increase carrying capacity .The double bellow air
bags are really good ,but the leaf spring upgrades are the best bet.you do
not have to have them be too rigid ,but increase the capacity .Ive done a set on a E150 1994 for a customer and used the Eaton springs ,worked out well .not a tow vehical ,just a work truck .The bags do allow you to increase
capacity and retain the ride not towing .That said ,the correct setup of your equalizer should get your TV and trailer level without any bags or heavier springs ,so look into the hitch adjustments ,it should not have any rear squat
if all is correct when hitched up .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 01-12-2007, 03:14 AM   #3
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Originally Posted by scottanlily
Hello Paul NC ,
Hi Scott: Well, well said, as a true conceptual engineer. It is not what you can do that matters, but the achievement of desired result trough wisdom.
Thanks, Tow Guru. "Boatdoc"
boatdoc is offline   Reply With Quote
Leaf spring suspension grommets Scott S Axles 10 06-02-2008 07:26 AM
Gas assist struts for lifting bed to access storage. Phil/Edee General Interior Topics 13 09-27-2007 10:12 AM
air lift assist for front springs jagcb750 Classic Motorhomes 8 09-03-2007 07:21 PM
Start Assist Chuckles Mechanics Corner - Engines, Transmission & More... 17 08-21-2006 12:57 AM
How many leaves in a leaf-spring axle??? 1959newbie Axles 20 08-05-2006 04:53 PM
