Old 07-22-2006, 09:23 PM   #1
Dr. E's Avatar
1976 27' Overlander
Temple , Texas
Thumbs up Lawn Tractor For Parking?
Does anyone have experience using a lawn tractor to repark a 27' or longer Airstream? I have some turning radius problems trying to get my trailer squared away at home when using my long wheel-base TV to manuver the trailer just where I want it.
The hitch bracket on the lawn tractors I've looked at seem rather lightweight.
Any experiences would be appreciated.
Gig 'em.
Dr. E
Dr. E is offline   Reply With Quote
Old 07-22-2006, 09:31 PM   #2
Druupy's Avatar
2005 28' Safari
Port Orchard , Washington
I've seen lawn tracktors with hitches at both ends, on different RV lots.
If your tractor can support a 3-point htich it shold be fine on the back.
If your tractor can support a front end loader it should be able to carry the tounge weight on it's front axle. It is up to you and your welder to add the proper size ballmount. I'm thinking of a mid sized kubota in a mostly flat yard.
Druupy is offline   Reply With Quote
Old 07-22-2006, 09:44 PM   #3
2005 16' International CCD
Ogden , Utah
When I think of a lawn tractor I see something way too light to move a trailer - can you give any more info on what you are going to use?
When I park my trailer I also have some tight maneuvers, with little side clearance. I ended up with a Power Caster (there are other similar devices, I just happened to pick this brand) and it took all the concern away. I could turn the trailer in a circle if needed to, it moves fast enough to get the job done but not so fast that I worry about getting too close too fast, and with a spotter it is pretty easy to get the trailer where it needs to go.
It was one of those purchases where I didn't really want to spend the money up front, but after getting it I have never had a regret, it makes putting the trailer away so easy.
RDM16CCD is offline   Reply With Quote
Old 07-22-2006, 11:29 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We use a lawn tractor to move our GT into it's space, but i don't think it could handle a 27-footer. We did modify the rear and add a ball-type hitch. The issues you have to consider are the tongue weight & power. Our tongue weight is less than 450 lbs and we bought a front bumper to stack 3 bags of tube sand on (180lbs) to get it front doing a wheelie. Our lawn tractor is 16hp and is fine on a level ground, but to get into the parking space, we have a slight grade which we need to get a running start at. Our GT weighs in at 3500 lbs...I'm certain a 27-footer weighs much more so you would need more power & weight IMO. Our situation is temporary (new house) we will be pouring a new slab on more level ground this fall, which should make it easier.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 07-22-2006, 11:35 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I saw a tread earlier where some folks have put a receiver on the FRONT of their pickups, which they use for bike racks, etc., and to backup and maneuver their trailers.
Check "search" - it was interesting.
Old 07-23-2006, 07:03 AM   #6
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Kubota BX1850
Timely question. I just took these yesterday! I use a Kubota BX1850 to move my 3,000 lb 17' Bigfoot and an aluminum utility trailer around, but the 3pt max weight is around 400 lbs. It's about the largest "lawn tractor" and is slightly smaller than the Case IH DXxxE series, the John Deere 2305, and the Massey Furguson 2300. The Kubota BX2350 is in their size class.
I wouldn't consider even trying to move my Airstream with my Kubota. I don't think any of those would work for your Overlander either. They're too lightweight and so are their hydraulics. I think you're probably looking at a 30hp minimum tractor for enough weight and 3pt capacity. If you check with your local dealers, they all give specs for the lifting capacity of the 3pt hitches.
Roger
Name:	Bigfoot Kubota pers pic 2.jpg
ID:	23817   Click image for larger version
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 07-23-2006, 07:07 AM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
rog you gotta bring that combo to davenport this year!
it might take ya 3 days to get there! ha ha!
john
you call them ferrets, i call them weasels.
Old 07-23-2006, 07:09 AM   #8
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
I may have to leave early, but I'll get three hours out of a gallon of diesel. How's THAT for fuel economy!
Think I ought to change my avatar?
Rog
Old 07-23-2006, 12:50 PM   #9
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
If your yard is paved, then a small fork lift will do very nicely. I use one to park my Overlander inside the warehouse, and it works very well. It won't be an option if you are moving your trailer on gravel or dirt.
I bought my fork lift used, it was less than a new powercaster. Besides i needed one anyways for business.
It is a nice tool for axle installs etc as well. Put a pallet on it,and have a great elevated work platform.
I know it's not for everybody, but it happens to work very well for me.
Uwe
www.area63productions.com
Old 07-23-2006, 08:51 PM   #10
Dr. E's Avatar
1976 27' Overlander
Temple , Texas
Thanks for all the input. I'll check with local dealers and get accurate spec's before deciding. Looks like it would take a pretty hefty tractor to move the trailer around safely. Not sure I want to invest that much.
Gig 'em.
Dr. E
Old 07-24-2006, 12:27 PM   #11
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Have you considered a vintage real tractor? My family has a 1949 Super C that's plenty big enough to move around a trailer, but they're cheap and parts are still available and reasonable enough for them. I'm pretty sure it's going to outlast ME.
Farmers have a unique viewpoint about old work tractors. Threw a rod? Fix the rod and weld up the hole in the crankcase. (That was done to this one about thirty years ago, and it's still chugging.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 07-24-2006, 01:54 PM   #12
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Gig 'em.
Dr. E
Go Here http://www.powermoverinc.net/
This is what I use, best customer service I have ever had. I can put my trailer through an opening with one inch on each side.
Good Luck
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 07-24-2006, 04:38 PM   #13
Dr. E's Avatar
1976 27' Overlander
Temple , Texas
Vintage tractor is an interesting idea. There is a very active vintage tractor group in this area. In fact they have a museum here in Temple, Texas. I'll check it out and see where it leads.
I'm aware of the Powermover option, but hoped to get double duty from the mover (aka - lawn mower). Scratching my head, now.
Gig 'em.
Dr. E
Old 07-24-2006, 04:51 PM   #14
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Pick up an old Ford N tractor. You can get one for under $2000 for one that needs a little TLC, and they can be used as lawn tractors, snowplows, bucket loaders, trailer parkers, heck, they can even be used as tractors.
Old 10-01-2010, 03:08 PM   #15
withidl's Avatar
2002 31' Classic
Houston , Texas
Been There, Doing That ...... Again
At the risk of bringing up Andrew Thompson, (Can-AM RV, London, Ontario, Canada) while I was taking delivery of my 2002 31 foot ASCL I expressed a desire to be able to maneuver it with my Honda 3013 hydrostatic riding lawn mower. The follow photos show the dolly which he fabricated. To use it I do the following:
  • Insert the drawbar into the back flange on the mower (where the diagonal grass catcher strut is inserted in the photo).
  • I raise the AS with the tongue jack
  • Then lower the front stabilizer jacks to support the AS
  • Then raise the tongue jack and position the dolly such that when I lower the tongue jack it inserts into the vertical tube protruding above the dolly
  • Lower the tongue jack into the vertical tube (the mechanical disadvantage puts less than 100 lbs on the mower flange)
  • Raise the stabilizer jacks
  • Pull away with AS
Additionally, if the dolly is flipped over it allows for hand maneuvering by inserting the tongue jack into the tube on the other side of the dolly (REALLY needs to be on level pavement to hand maneuver!).
Name:	Tow Vehicle (would you believe).jpg
ID:	112062   Click image for larger version
Name:	Tow Dolly 1.jpg
Name:	Tow Dolly 2.jpg
ID:	112064   Click image for larger version
Name:	Tow Dolly 3.jpg
Name:	Tow Dolly 4.jpg
ID:	112066   Click image for larger version
Name:	Tow Dolly 5.jpg
withidl is offline   Reply With Quote
Old 10-01-2010, 03:57 PM   #16
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
  • Pull away with AS
Good way to buckle the stabilizer. Dave
easyride is offline   Reply With Quote
Old 10-01-2010, 04:16 PM   #17
withidl's Avatar
2002 31' Classic
Houston , Texas
I considered that stress. My Limited AS has the electric jacks which go across the entire width of the AS. The jack legs readily take the load without any flexing. I do NOT use the stablizer jacks to LIFT the trailer, only to SUPPORT it after the tongue jack has lifted. I've done it many times without incident as the stablizers easily carry the STATIC load.
Old 10-01-2010, 06:48 PM   #18
r carl's Avatar
Lin , Ne
By god there is more than 1 way to move a camper, I would of never thought about using the jack that way.
Old 10-01-2010, 07:34 PM   #19
Spring Hill , Florida
Why not just put a jack stand under the tongue instead of using the stabilizers?
sepezlover is offline   Reply With Quote
Old 10-01-2010, 09:08 PM   #20
withidl's Avatar
2002 31' Classic
Houston , Texas
The design of the dolly is such that it's axle is about 8" behind the tongue jack tube when connected. This leaves no room on the curb side for a jack stand because the LPG gas line runs UNDER that side of the frame.
On the street side room for a jack stand is very marginal and when the tongue jack is raised sufficiently to move the dolly into position my jack stands have to have blocks under them since they are not quite high enough.
Additionally, jack stands can't be positioned under the body of the AS because the belly pan covers the frame.
But the real bottom line is that the electric stablizer jacks are THERE, they work and they KISS!
Have others ever RISK trying to use the electric stablizers to support their AS, or just ASSumed they will fail?
Looking for the lawn chair thread Boondocker Off Topic Forum 5 03-28-2006 06:14 AM
Seaside Rally 2005 (New England Unit-Region 1) AirHog WBCCI Rallies & Events 146 05-31-2005 04:26 PM
Misc. ramblings till Our Community 14 03-06-2004 07:11 PM
lawn chairs art Airstream Motorhome Forums 1 07-15-2003 05:38 PM
what is this alum. sob? john hd Vintage Kin 13 02-13-2003 04:17 PM
