Old 10-01-2010, 11:55 PM   #21
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
Just a few points - Avoid any significant grade or you may have an exciting ride downhill with the braking capability of a lawn tractor or even a vintage tractor. Also, when you are that close to the front of the trailer, you cannot see to back it up. You need a good spotter with a cell phone ecause you are blind.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Old 10-02-2010, 03:41 AM   #22
1969 21' Globetrotter
Seattle & Olympic Peninsula , Washington
I use a 3 point attached hitch to move my AS with my John Deere 4400 tractor once in a while with no issue but I don't think I'd try it with our lawn tractor. Our property is way too steep. I'd end up in the ocean.
Dave
EvelynDickinson is offline   Reply With Quote
Old 10-02-2010, 04:45 AM   #23
r carl's Avatar
Lin , Ne
Have breakaway cable in hand while moving with lawn tractor.
Old 10-02-2010, 07:51 AM   #24
2010 27' FB Classic
N/A , Texas
I have used a skidloader to move my stuff around. I have a ball and a bracket that I bolt to the bucket. A skidloader has 4 wheel drive and it turns on a dime because of the controls to move it uses joy sticks instead of a steering wheel.
It can pull it up and down hills in the grass or mud or pavement. It's also a pretty safe way to move a trailer in a tight area.
Old 10-02-2010, 07:51 AM   #25
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I thought about using my atv but I know it won't take the toung weight with that set up it could work. But I use my John Deer 30 tractor to move it around. Works great.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-02-2010, 08:01 AM   #26
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I use a little Kubota 0-category,recently moved trailer up hill to new shelter,had plenty of power,however on the hill,had to steer with the brakes,this was even with the weights on front. Dave
easyride is offline   Reply With Quote
Old 10-02-2010, 10:10 AM   #27
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Never try to move a trailer with a lawn tractor. The trans-axle is not meant to move that much weight even if a dolly such as was previously pictured is used. The brakes on a yard or lawn tractor are only a 2 inch disk with a pad thats only 1/2 in wide and 1 inch long and really are only meant to stop the tractor. Now if you are gonna use a BOBCAT type loader with the setup Bluto has,by all means go for it. AN 8N ford or any tractor that size will also do the trick. There are also electric dollys on the market that have brakes incorporated in them that work very well also.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 10-02-2010, 12:01 PM   #28
withidl's Avatar
2002 31' Classic
Houston , Texas
Agreed on the grade. I primarily use the lawn mower to move the AS in/out of the "tight slip" so that I can work on it. This keeps me from having to bring the X5 into the back yard and hook up to the Hensley just to move the AS 20 feet.
As to stressing the lawn mower, it easily moves the AS on the level with it's hydrostatic drive which also acts in breaking; when mowing the lawn the hydrostatic drive is subjected to more stress in reversing direction than when I move the AS; in fact I NEVER use the brake on the mower to start and stop as the hydrostatic drive does it all. As long as the AS is on an essentially level surface the mower has no problem handling it.
When I manuever with the mower if I am not sure of the AS position I just step off, go look, step back on and move several feet, step off, go look, etc. until I have the AS in position. I has worked well.
withidl is offline   Reply With Quote
Old 10-07-2010, 09:18 AM   #29
Airstreamer67's Avatar
I have a swiveling wheel that bolts onto the front jack of the trailer. I believe it came with the trailer. Could not this be used to support the trailer's front end when used on a hard, flat surface and use the tractor for pushing it into place?
Airstreamer67 is offline   Reply With Quote
Old 10-07-2010, 10:34 AM   #30
1986 25' Sovereign
Plant City , Florida
I have a Kubota B7200 4wd tractor with a 3 point hitch... Does any one know if this will safely move my stream? I know that it has plenty of power... It pulled my van and trailer before with no tounge weight.
ck21084 is offline   Reply With Quote
Old 10-07-2010, 11:59 AM   #31
I think your Orange B7200 weighs about 1,300 lbs. Not sure I'd want to try to stop on a slope with a 25' A/S. But then again Plant City is fairly flat....
Looking for the lawn chair thread Boondocker Off Topic Forum 5 03-28-2006 06:14 AM
Seaside Rally 2005 (New England Unit-Region 1) AirHog WBCCI Rallies & Events 146 05-31-2005 04:26 PM
Misc. ramblings till Our Community 14 03-06-2004 07:11 PM
lawn chairs art Airstream Motorhome Forums 1 07-15-2003 05:38 PM
what is this alum. sob? john hd Vintage Kin 13 02-13-2003 04:17 PM
