Old 03-21-2016, 11:27 AM   #1
OliveRivets
OliveRivets's Avatar
1968 26' Overlander
1976 31' Sovereign
Wake Forest , North Carolina
Images: 8
Land Rover and Airstream..perfect
Does anyone pull their Airstream with Land Rover? Would love to see pictures or stories. It works out great for our family.
Adventure is out there!
1968 Overlander International
OliveRivets is offline   Reply With Quote
Old 04-01-2016, 10:27 PM   #2
2005 16' International CCD
Portland , Oregon
We are pulling our 23D International with a 2015 LR4 (3L SC V6). Great combination, if fuel economy is not a big priority.Click image for larger version
Name:	ImageUploadedByAirstream Forums1459571215.253614.jpg
minigoogoo is offline   Reply With Quote
Old 04-21-2016, 09:30 AM   #3
Brav's Avatar
2016 25' International
Huntington Beach , California
2010 RR SC and 25FB
ID:	261117   Click image for larger version
2016 International Sig 25FB
2010 LR RR S/C
Brav is offline   Reply With Quote
Old 04-21-2016, 10:37 AM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Originally Posted by Brav View Post
2010 RR SC and 25FB
Did you modify the standard reciever on your Range Rover?
You are super brave if you are towing with an unmodified Range Rover L322 reciever. I have had several range rovers including a 2011 SC (basically same as yours). I also have a 25' international. But I don't tow with RR (I use my Infiniti QX56)
The 2010 comes with a class III hitch and the mounting to the unibody leaves a lot to be desired - only rated for 550lbs tongue weight. It was never designed to manage the type of hitch weight (750-900lbs+) that a 25' late model airstream generates.
Check the welds frequently if you have not already modified the hitch for the additional tongue weight and torque that a WD hitch generates.
My $0.02 mainly - I'm just bummed that I couldn't tow safely with my 2011 RR. I even looked into the new 2013+ but even those require hitch modification.
wulfraat is offline   Reply With Quote
Old 04-21-2016, 06:43 PM   #5
Brav's Avatar
My Westfalia hitch says 770 tongue weight. The receive appears to be pretty damn beefy, no stress cracks to be found. I have been cautious of tongue weight from the beginning, and relocated batteries further back, and load under the dinette to keep tongue weight close to 800.
2010 LR RR S/C
Old 04-22-2016, 06:58 AM   #6
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Just get the hitch reinforced. Takes two hours, peace for years.
andreasduess is offline   Reply With Quote
Old 04-22-2016, 08:06 AM   #7
wulfraat's Avatar
Yes, that is stamped all the L322 hitches. Just know that the setup of that receiver bar on the range rover was not explicitly designed (as a system) to manage 800lbs of weight. definitely watch you rear axle / payload limits.
Glad that you are having some great success towing with this setup - I am jealous and I'm now wishing that I wasn't so conservative and hadn't sold my 2011 SC
Old 04-22-2016, 10:35 AM   #8
Brav's Avatar
Will look into it, thanks.
2010 LR RR S/C
Old 04-22-2016, 10:43 AM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I don't tow with a LR, but here's mine on the way to Alaska in 1971.
ID:	261177   Click image for larger version
2012 Dodge Durango Hemi/AWD
Old 04-22-2016, 07:16 PM   #10
Toronto , Ontario
I had the exact same model. A Series II SWB, 1964, except mine had a canvas top. I used to own a couple of classic Land Rovers, but that was my favourite. It had a tick where the front left signal light would not work, except if the screw holding the plastic cover was just a little bit loosened. It made no sense whatsoever, and I tried for hours to fix it, but in the end I just chalked it up to the famous Land Rover quirkiness and called it a day.
My wife, my girlfriend at the time, and I took ours across the Pyrenees from France to Spain, across tiny mountain passes and shepherd trails. Great fun.
Old 04-22-2016, 08:14 PM   #11
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Heck it made perfect sense, Lucas Electrics. Famous for crapping out at the worst possible time. I had a 64 and a 70 Rover and a string of MGs. All had the infamous Lucas gremlins. I would buy a new one in a heart beat if I could afford the payments.
MICHAEL
Old 10-24-2017, 05:30 PM   #12
OliveRivets
1968 26' Overlander
1976 31' Sovereign
Images: 8
Old 10-24-2017, 05:31 PM   #13
OliveRivets
1968 26' Overlander
1976 31' Sovereign
Images: 8
1979 Series 3 LWB turbo diesel
Old 11-06-2017, 08:16 PM   #14
Colts NECK , New Jersey
Lr4 towing
We tow our 22 Sport with a 2015 LR4, with weight distribution hitch. The ride is flawless.
Considering moving up to a Globetrotter 2018. What sort of reinforcement of the hitch would be required to make this feasible??
Stardust60 is offline   Reply With Quote
Land Rover LR3 towing story reventlow Tow Vehicles 86 06-09-2015 01:28 AM
2006 airstream 19' safari bambi se, 75th anv ed, immac s1967 series ii land rover "1 eBay Watch Airstreams on eBay 0 06-14-2010 09:20 PM
Towing with a Land Rover dan_lemire Tow Vehicles 6 02-10-2006 12:20 PM
Trailer size for a 2003 Land Rover Discovery runyandm Tow Vehicles 5 10-30-2003 09:09 PM
Land Rover Discovery to tow Bambi '62 Rosemary Tow Vehicles 10 10-20-2003 08:33 PM
