Old 05-22-2008, 07:11 AM   #15
Denis4x4
Denis4x4's Avatar
Profile:  2006 Safari LS
Durango , Colorado
For the record, performance equipment for tow vehicles became hot during the first gas crisis in 1973. Jerry Jardine, Fred Offenhauser, Bruce Crower and Vic Edlebrock, Jr. used race car tow trucks as a test bed for equipment. Remember, a lot of race cars were towed on roll backs or on trailers behind a truck with a camper. As these products were developed, ads in CamperCoachman and TL generate 1000's of responses and 100's of satisfied customers.
I ran a Wrangler through a hub deep stream on Sunday with a K&N filter charger with nary a drop of water in the intake tube. While I respect Tom's opinion, I would point out that every single truck manufacturer, including Toyota, Honda and Nissan, works with SEMA members and the 2009 F-150 has already been set for measurement sessions.
Products we're talking about here are not from J.C. Whitney nor are they sold on late night TV by Billie Mays.
In all honesty, I doubt that the cost benefits of installing high performance equipment on a modern TV would pencil out today. But, the benefits are still there if you want to pay the money and do it right.
Denis4x4 is offline   Reply With Quote
Old 06-29-2008, 03:05 PM   #16
Larry C
The Woodworker
Larry C's Avatar
Profile:  2000 30' Excella
Elberta , Alabama
Well said!
A day spent fishing is not subtracted from your lifespan!
Larry C is offline   Reply With Quote
Old 06-29-2008, 05:17 PM   #17
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
This is a great article about the aftermarket air filters.
ISO 5011 Duramax Air Filter Test Report
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 06-30-2008, 01:03 AM   #18
dscluchfc
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
what would be the proper way to clean a Duramax Mass Airflow Sensor?
spray it down with electronic tuner cleaner?
should it be touched with a tac cloth when doing this?
anyone know the proper way?
I shoot PJ7 paper filter oil on Fram air filters, and someone told me a couple days ago that would foul my MAS....true? or myth?
David
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
archival giclée prints available for each picture, 16 x 21 and larger.
dscluchfc is offline   Reply With Quote
Old 06-30-2008, 02:39 PM   #19
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
No TV tuner cleaner. They contain a lubricant. Never touch the film or wires inside the sensor housing.
Find a spray can of Mass Airflow Sensor cleaner at the auto parts store. I like the CRC line of products.
If the sensor’s OK and isn’t throwing a code spraying it down generally won’t harm it. Just don’t expect miracles. There seems to be a tipping point from which they don’t recover.
As far as oiling a paper filter I don’t know about the PJ7 oil. I wouldn’t bother for all the reasons previously mentioned. In any case less would be more.
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 07-04-2008, 06:50 AM   #20
Jetstreamer
Jetstreamer's Avatar
Profile:  La Follette , Tennessee
It's my understanding that a diesel engine has a fixed amount of airflow for all power settings. Only fuel is modulated as needed for performance. A clean stock filter should provide the proper airflow and superior filtering.
Jetstreamer is offline   Reply With Quote
Old 07-04-2008, 08:27 AM   #21
jdalrymple
jdalrymple's Avatar
Profile:  1981 31' International
Siloam Springs , Arkansas
The usefulness or performance of aftermarket products aside, the fact is vehicles produced in America, or produce in another country for sale or for use in America, achieve the poorest fuel economy in the world.
While vehicles sold here are some of the most technically advanced, government regulations on emissions require a waste of fuel to achieve the required levels. The on-board computers actually add fuel on the input side when the sensors see unburned products of combustion in the exhaust system. This additional fuel promotes higher temps in the catalytic converter, which re-burns the exhaust gasses, to assure the required emissions level.
An example is the European SmartCar. This vehicle achieves 50-60 mpg in the EU, but due to the emissions laws in the US, it is de-tuned to around 30 mpg. This is also witnessed by the fact that new engines, and improvements to current engines, are meant to meet emissions standards, and are less concerned about improving fuel economy.
One wonders if the outcome is truly a gain. Is burning more fuel now really better than the limited improvement of a slightly better emissions measurement.
Further, not all the automotive engineers work for the auto manufacturers. It seems that products not totally concerned with emissions limitations can make some improvements.
Jeff, Cindy and the Brittanys:
Remi and Hunter
'81 International 31'CB "Fus-a-lodge"
'03 2500HD Chevy Duramax w/improvments
WBCCI #7026 Air #17054
Old 07-05-2008, 08:15 AM   #22
Denis4x4
Denis4x4's Avatar
Durango , Colorado
You hit the nail on the head! I participated in several tests using speed equipment installed on a SBC that not only increased HP, but improved economy both on the dyno and on the street. AND, was within the parameters of emission control requirements. What we didn't know at the time was the political forces that were at work to set standards that weren't always in the consumer's best interest. A good example was the "visual" test. I had two cars that had to be sold out of state (California) because they would not pass the visual test due to the installation of tube headers and an aluminum intake manifold with a low restriction air cleaner. Interestingly enough, both of these vehicles passed the smog check.
Emission controls need to be set by engineers, not congress pandering to environmentalists. That goes for state law makers too.
Old 07-05-2008, 04:28 PM   #23
canadianguy
Profile:  Currently Looking...
Red Deer , Alberta
We have the poorest average fuel economy in the world because we drive vehicles with the highest average weight, and designed for style and comfort rather than aerodynamics, and we drive them too fast. You can also blame highway safety requirements for increasing the weight of vehicles on our road.
That's not true. The difference in efficiency between the air fuel ratio for optimum emission control, and the one for optimum efficiency is very small.
The catalytic converter works by absorbing nitrous oxides, carbon monoxide, and unburned hydrocarbons. Nitrous oxides are broken down by the catalyst to provide oxygen to consume the carbon monoxide and unburned hydrocarbons.
Until a few years ago the way the precise ratio was achieved was by running slightly rich to build up carbon monoxide and hydrocarbons on the catalyst for a second, then burn slightly lean to produce NOx and excess oxygen for a second. This was done because the oxygen sensors weren't accurate enough to stay on the exact ratio. The solution was to make sure the time average is the correct ratio. You can see the oscillation clearly on an oscilloscope.
About 5-6 years ago broad-band oxygen sensors came out that were capable of measuring the correct air fuel ratio came out. The improvement was fairly minor.
According to Smart's website the 2008 version uses 4.8 L/100km. By my calculation this is 46 MPG. This is for gasoline. Most of the European ones are diesel.
canadianguy is offline   Reply With Quote
Old 07-06-2008, 03:22 PM   #24
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Diesels do not have a throttle plate, as a gasser does. The plumbing through the air flow is fixed in size but the volume of air that flows through it increases as RPMs increase. That is where K&N claims to have an advantage and yes they do but the amount of dirt that flows through the engine the rest of the time does not justify the increased air flow unless you are racing and intend to rebuild the engine anyway.
Bigger holes pass bigger pieces of dirt.
Been there did that and it is not worth it.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-06-2008, 08:01 PM   #25
Tom Nugler
Tom Nugler's Avatar
While this thread has strayed from the original post, canadianguy pretty much nailed it down. The range of fuel efficient sub compacts in Europe is quit broad and generally unavailable in the US. I’d love to see a Polo in this country. Sales says there’s not enough demand to bring in a US spec model. (time to rethink that position.) We got a Jetta in this Tuesday with the new "Clean Diesel" engine. 50 state certified and MPG numbers similar to Prius. This in a car with a real trunk and performance.
Recent polling data seems indicate that the general public is starting to re-examine the way, and what they drive. The data is born out in last months sales figures posted by the automakers.
I think for the non-technical readers it should be noted that gas and diesel engines have become nearly identical in the way fuel management and emissions are handled. The Duramax mentioned in the first post has electronically controlled fuel injectors, EGR, Catalysts and a full array of input and output sensors. Just like your family sedan. The Horsepower, Performance and Emissions balancing act have always been a difficult compromise.
Politics aside, even I have "Air Quality" issues with my county board. The opinion of some of my friends and colleagues here on the Forum is that air quality and economy be left in the hands of the engineers and not to the legislature. They might want to ask the people of some smog afflicted community how they feel about the problem. And how they voted. There’s no going back now.
OK, I'm done now,
Tom.
WBCCI # 6411
Old 07-06-2008, 08:17 PM   #26
yakman
yakman's Avatar
Profile:  2007 25' International CCD FB
Gahanna , Ohio
Ditto. I'm with you on this one. It's always been my understanding that K&N are designed for race applications. More airflow and less concern about what goes into the engine as it will be rebuilt soon anyhow. You have to be a master of the exact amount of oil to use on them etc. If you're not racing, don't bother with the K&N. Any gain will be offset by premature engine wear.
yakman
yakman is offline   Reply With Quote
How does new diesel fuel affect older engines Stream 1529 Tow Vehicles 9 10-19-2007 10:03 AM
Navistar halting production of diesel engines for Ford Silvertwinkie Tow Vehicles 14 04-21-2007 09:21 PM
ULSD fuel and older Diesel engines? jking Classic Motorhomes 2 03-08-2007 06:52 PM
K&N Filters joel Towing, Tow Vehicles & Hitches 9 01-23-2006 05:01 PM
air conditioner filters canyonrich Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-27-2003 07:21 PM
