Old 05-22-2008, 06:11 AM   #15
Denis4x4's Avatar
Durango , Colorado
For the record, performance equipment for tow vehicles became hot during the first gas crisis in 1973. Jerry Jardine, Fred Offenhauser, Bruce Crower and Vic Edlebrock, Jr. used race car tow trucks as a test bed for equipment. Remember, a lot of race cars were towed on roll backs or on trailers behind a truck with a camper. As these products were developed, ads in CamperCoachman and TL generate 1000's of responses and 100's of satisfied customers.
I ran a Wrangler through a hub deep stream on Sunday with a K&N filter charger with nary a drop of water in the intake tube. While I respect Tom's opinion, I would point out that every single truck manufacturer, including Toyota, Honda and Nissan, works with SEMA members and the 2009 F-150 has already been set for measurement sessions.
Products we're talking about here are not from J.C. Whitney nor are they sold on late night TV by Billie Mays.
In all honesty, I doubt that the cost benefits of installing high performance equipment on a modern TV would pencil out today. But, the benefits are still there if you want to pay the money and do it right.
Denis4x4 is offline   Reply With Quote
Old 06-29-2008, 02:05 PM   #16
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Well said!
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 06-29-2008, 04:17 PM   #17
Dwight's Avatar
1999 34' Excella
Joshua , Texas
This is a great article about the aftermarket air filters.
ISO 5011 Duramax Air Filter Test Report
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 06-30-2008, 12:03 AM   #18
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
what would be the proper way to clean a Duramax Mass Airflow Sensor?
spray it down with electronic tuner cleaner?
should it be touched with a tac cloth when doing this?
anyone know the proper way?
I shoot PJ7 paper filter oil on Fram air filters, and someone told me a couple days ago that would foul my MAS....true? or myth?
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 06-30-2008, 01:39 PM   #19
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
No TV tuner cleaner. They contain a lubricant. Never touch the film or wires inside the sensor housing.
Find a spray can of Mass Airflow Sensor cleaner at the auto parts store. I like the CRC line of products.
If the sensorís OK and isnít throwing a code spraying it down generally wonít harm it. Just donít expect miracles. There seems to be a tipping point from which they donít recover.
As far as oiling a paper filter I donít know about the PJ7 oil. I wouldnít bother for all the reasons previously mentioned. In any case less would be more.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-04-2008, 05:50 AM   #20
Jetstreamer's Avatar
1988 32.5' Airstream 325
La Follette , Tennessee
It's my understanding that a diesel engine has a fixed amount of airflow for all power settings. Only fuel is modulated as needed for performance. A clean stock filter should provide the proper airflow and superior filtering.
Jetstreamer is offline   Reply With Quote
Old 07-04-2008, 07:27 AM   #21
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The usefulness or performance of aftermarket products aside, the fact is vehicles produced in America, or produce in another country for sale or for use in America, achieve the poorest fuel economy in the world.
While vehicles sold here are some of the most technically advanced, government regulations on emissions require a waste of fuel to achieve the required levels. The on-board computers actually add fuel on the input side when the sensors see unburned products of combustion in the exhaust system. This additional fuel promotes higher temps in the catalytic converter, which re-burns the exhaust gasses, to assure the required emissions level.
An example is the European SmartCar. This vehicle achieves 50-60 mpg in the EU, but due to the emissions laws in the US, it is de-tuned to around 30 mpg. This is also witnessed by the fact that new engines, and improvements to current engines, are meant to meet emissions standards, and are less concerned about improving fuel economy.
One wonders if the outcome is truly a gain. Is burning more fuel now really better than the limited improvement of a slightly better emissions measurement.
Further, not all the automotive engineers work for the auto manufacturers. It seems that products not totally concerned with emissions limitations can make some improvements.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-05-2008, 07:15 AM   #22
Denis4x4's Avatar
Durango , Colorado
You hit the nail on the head! I participated in several tests using speed equipment installed on a SBC that not only increased HP, but improved economy both on the dyno and on the street. AND, was within the parameters of emission control requirements. What we didn't know at the time was the political forces that were at work to set standards that weren't always in the consumer's best interest. A good example was the "visual" test. I had two cars that had to be sold out of state (California) because they would not pass the visual test due to the installation of tube headers and an aluminum intake manifold with a low restriction air cleaner. Interestingly enough, both of these vehicles passed the smog check.
Emission controls need to be set by engineers, not congress pandering to environmentalists. That goes for state law makers too.
Old 07-05-2008, 03:28 PM   #23
Red Deer , Alberta
We have the poorest average fuel economy in the world because we drive vehicles with the highest average weight, and designed for style and comfort rather than aerodynamics, and we drive them too fast. You can also blame highway safety requirements for increasing the weight of vehicles on our road.
That's not true. The difference in efficiency between the air fuel ratio for optimum emission control, and the one for optimum efficiency is very small.
The catalytic converter works by absorbing nitrous oxides, carbon monoxide, and unburned hydrocarbons. Nitrous oxides are broken down by the catalyst to provide oxygen to consume the carbon monoxide and unburned hydrocarbons.
Until a few years ago the way the precise ratio was achieved was by running slightly rich to build up carbon monoxide and hydrocarbons on the catalyst for a second, then burn slightly lean to produce NOx and excess oxygen for a second. This was done because the oxygen sensors weren't accurate enough to stay on the exact ratio. The solution was to make sure the time average is the correct ratio. You can see the oscillation clearly on an oscilloscope.
About 5-6 years ago broad-band oxygen sensors came out that were capable of measuring the correct air fuel ratio came out. The improvement was fairly minor.
According to Smart's website the 2008 version uses 4.8 L/100km. By my calculation this is 46 MPG. This is for gasoline. Most of the European ones are diesel.
canadianguy is offline   Reply With Quote
Old 07-06-2008, 02:22 PM   #24
HowieE's Avatar
Princeton , New Jersey
Images: 12
Diesels do not have a throttle plate, as a gasser does. The plumbing through the air flow is fixed in size but the volume of air that flows through it increases as RPMs increase. That is where K&N claims to have an advantage and yes they do but the amount of dirt that flows through the engine the rest of the time does not justify the increased air flow unless you are racing and intend to rebuild the engine anyway.
Bigger holes pass bigger pieces of dirt.
Been there did that and it is not worth it.
2004 Excursion 4x4
Old 07-06-2008, 07:01 PM   #25
Tom Nugler's Avatar
1972 25' Tradewind
While this thread has strayed from the original post, canadianguy pretty much nailed it down. The range of fuel efficient sub compacts in Europe is quit broad and generally unavailable in the US. Iíd love to see a Polo in this country. Sales says thereís not enough demand to bring in a US spec model. (time to rethink that position.) We got a Jetta in this Tuesday with the new "Clean Diesel" engine. 50 state certified and MPG numbers similar to Prius. This in a car with a real trunk and performance.
Recent polling data seems indicate that the general public is starting to re-examine the way, and what they drive. The data is born out in last months sales figures posted by the automakers.
I think for the non-technical readers it should be noted that gas and diesel engines have become nearly identical in the way fuel management and emissions are handled. The Duramax mentioned in the first post has electronically controlled fuel injectors, EGR, Catalysts and a full array of input and output sensors. Just like your family sedan. The Horsepower, Performance and Emissions balancing act have always been a difficult compromise.
Politics aside, even I have "Air Quality" issues with my county board. The opinion of some of my friends and colleagues here on the Forum is that air quality and economy be left in the hands of the engineers and not to the legislature. They might want to ask the people of some smog afflicted community how they feel about the problem. And how they voted. Thereís no going back now.
OK, I'm done now,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Old 07-06-2008, 07:17 PM   #26
yakman's Avatar
2007 25' International CCD FB
Gahanna , Ohio
Ditto. I'm with you on this one. It's always been my understanding that K&N are designed for race applications. More airflow and less concern about what goes into the engine as it will be rebuilt soon anyhow. You have to be a master of the exact amount of oil to use on them etc. If you're not racing, don't bother with the K&N. Any gain will be offset by premature engine wear.
yakman
yakman is offline   Reply With Quote
Old 12-25-2010, 06:31 PM   #27
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by Tom Nugler View Post
The "tuners" mount the intake tube with a bare filter element mounted low behind the bumper. Works great a sucking puddles up into the engine on rainy days.
Tom.
When I bought this MH I figured I would sevice the K and N, read online how it is washed and oiled. On studying the installation I found the air intake was placed infront of radiator above bumper, the water diverter section was mounted 90 off, allowing any water pickup at the intake to be able to travel up to the motor instead of draining away. Somebody screwed up. My feeling is original installer as no bills were in the maintenance file, is K&N original equipment by AS? Chevy should have Delco?
Old 12-25-2010, 07:50 PM   #28
SSChanger's Avatar
Louisville , United States
Thanks to everyone for all of this info. My 2003 Silverado 2500HD with the 6.6L Duramax Diesel has the K&N filter, which I knew could be washed (I've done that) but didn't know was supposed to be oiled....
Yikes!
Got a Delco paper filter as a back-up. I'll be leaving the K&N in the garage.
Thanks!
SSChanger
'94 Excella 1000; '03 Silverado 2500HD
Louisville, Tennessee
SSChanger is offline   Reply With Quote
Navistar halting production of diesel engines for Ford Silvertwinkie Tow Vehicles 21 01-18-2009 08:52 AM
How does new diesel fuel affect older engines Stream 1529 Tow Vehicles 9 10-19-2007 09:03 AM
ULSD fuel and older Diesel engines? jking Classic Motorhomes 2 03-08-2007 05:52 PM
K&N Filters issues on my GM truck joel Tow Vehicles 9 01-23-2006 04:01 PM
air conditioner filters canyonrich Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-27-2003 06:21 PM
