Old 05-06-2015, 01:35 PM   #1
Icy
2010 22' Sport
Sarnia , Ontario
Jeep JK and an airstream 22' sport
25000 km, 21 states, 4 provinces and through the rocky mountain's. Averaged 15L/100km's without heavy winds. Jeep was prepared by CanAm RV in London Ontario, Jeep was equipped with a 3.6L, 6 speed manual and 3.73 gears. In all our travels from Ontario to Florida to California to BC and back home we had "0" problems towing.
Great SUV and a great trailer.
Icy is offline   Reply With Quote
Old 05-07-2015, 12:37 AM   #2
Seattle , USA
Nice looking rig!
You're lucky you have the 6spd manual...no overheating problems as compared to the automatics that need a transmission cooler to keep from frying the tranny without pulling anything.
What year is your Jeep? Have you had the left side head replaced yet?
RareStream is offline   Reply With Quote
Old 05-07-2015, 05:17 AM   #3
2015 16' Sport
Lakeridge , Virginia
Wow 15.68 MPG towing a trailer that is more than twice the manufacture’s limit for both weight (2000 lb) and frontal area (25 sqft) is quiet impressive. What’s the secret? I barely get 18 MPG mostly highway with my 2 door 2013 Rubicon auto not towing and 11mpg when I towed a little 1600lb T@B on flat land.
Peanut is offline   Reply With Quote
Old 05-07-2015, 05:36 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
How much does the Sport weigh?
I've been wondering if it would be ok to use my TJ as a tow dolly...just for moving my trailer around on my property.
TJ is a 4-banger/stick...and the camper is 4-5000lbs, but there is a steep grade for the last 100' of driveway.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-07-2015, 11:18 AM   #5
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Patriot....maybe deflate the camper a little.
Sorry...first thing that came to mind...
B00merang is offline   Reply With Quote
Old 05-07-2015, 11:18 AM   #6
2012 23' FB International
Woodstock , Ontario
My buddy used to pull his '68 Tradewind AS with his 1940 Willy's Army Jeep. Not sure why he would have wanted to since he had a proper Chev TV set up at CanAm, but I know he pulled it several hundred miles on one trip. For just moving the AS around the yard I don't see why not! Low gear gives a lot of grunt and over-heating can't be a problem in a short haul
JCWDCW is offline   Reply With Quote
Old 05-07-2015, 12:37 PM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, but if you do the math on this one, it doesn't have that much grunt. The 4-banger is not particularly powerful...it does have 4.11 gears, though. Seems to me I ran the numbers through Andy T's "thrust" formula, and came up with 2500lbs...in 4wheel-low.
I suppose that is probably enough, though.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-07-2015, 01:47 PM   #8
Road Ruler's Avatar
Images: 38
It should work. Your Jeep/23 combo weighs 3,000 + 4,500 = 7,500lbs.
and has 120HP / 140 ft-lbs.
Do you recall our Nissan mini van/23 combo weighed 4,200 + 4,500 = 8,200lbs
and had 150HP / 180 ft-lbs.
Crunch the number and they are very close as far as power to weight.
Also realize the van only had 3:89 gears, cruised the highways at 100KLH and we climbed a lot on hills here in Ontario.
http://img.photobucket.com/albums/v213/CF105/airr.jpg
Old 05-07-2015, 01:58 PM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Kitchen table math aside, I say as an actual former Patriot owner, no way and no how would it safely haul anything over 1ton.
MICHAEL
Old 05-07-2015, 03:35 PM   #10
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Wayne, have you actually had your Safari on a scale? I never have, so I don't know the actual weights...but I've always ball-parked it in that area.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-07-2015, 04:40 PM   #11
2014 23' Flying Cloud
Rhinebeck , New York
Thumbs up
Congratulations especially for the 25,000 KM on the road. I am envious. Our 2014 23' International Serenity has been in storage behind the barn and used but two weeks in the past year. Such is life. Once mama get's the bees and chickens cared for, and her new consultancy business in order perhaps we too will travel.
I am surprised frankly that your combination TV and TT actually work and especially well. Perhaps we are too conservative employing a Ford 250 / 6.7L diesel as a tow vehicle. Yes it is overkill but it sure feels "safe".....as safe as towing can be. Keeping up with traffic is easy regardless of terrain. The 3/4 ton truck with it's big diesel drives better withe the Airstream than w/o. It likes the stress.
Bravo for you guys in any case.
Adam Geuss is offline   Reply With Quote
Old 05-07-2015, 04:52 PM   #12
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Sounds great. The 3.6l engine is rated at 285 hp, which is plenty of power.
robert claus is offline   Reply With Quote
Old 05-07-2015, 07:19 PM   #13
Icy
2010 22' Sport
Sarnia , Ontario
Originally Posted by RareStream View Post
Nice looking rig!
2012
only early models had engine problems
Old 05-07-2015, 07:27 PM   #14
Icy
2010 22' Sport
Sarnia , Ontario
11.7L/100km's @ 115km/h with out trailer
15L/100km's @ 103km/h with trailer and no wind
its the rpm and torque curve I think
Old 05-07-2015, 10:24 PM   #15
Seattle , USA
Pentastar engine problems and valve failure persisted into the 2013 model year...I know from direct experience.
Old 05-08-2015, 05:46 AM   #16
Road Ruler's Avatar
Images: 38
Yes Chuck we did have it on the scales a few times. With options (awning, air, laminate flooring, Ikea kitchen cabinets, etc it's dry weight is almost 4,000lbs. Loaded for travel it gets up to 4,500lbs.
Old 05-08-2015, 05:55 AM   #17
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I guess the tag is fairly accurate, then, at least for this year/model. (3800 empty/5800gvw). I know I've seen a lot of folks grumping about how their measured weights are very, very different from what is published.
What about the "actual" tongue weight? That seems to be where most are unpleasantly surprised.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-22-2018, 08:01 AM   #18
2018 Basecamp
Santa Clara , CA
I have a JKU Rubicon and about to buy a Sport 16". Are you towing with all stock parts or did you upgrade and buy anything to ensure an easier or better tow?
smerritt is offline   Reply With Quote
Old 06-01-2018, 03:33 PM   #19
Vintage Kin
Fort Worth , Texas
Contact Andrew Thomson at Can Am RV. They’ve set up a good number of these. Plus 10,000 other tow rigs.
New 2015 16' Sport, towed by Jeep Wrangler Unlimited jt1911man 2005 and newer - Bambi all models 28 05-05-2015 05:53 AM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
Airstream Sport 22 :: 2011 Airstream Sport Lone Eagle0 Airstream Registry Discussions 0 08-19-2011 08:32 AM
Diesel Jeep Liberty and `61 Tradewind henrydahm Tow Vehicles 14 07-17-2006 05:56 AM
