Old 06-20-2018, 07:26 PM   #1
Newmarket , Ontario
Jeep Grand Cherokee as TV for 23’ Airstream?
Hi, my husband and I have purchased a 23’ Airstream. We previously had a 30’ Evergreen which swayed terribly. We are hoping that we can tow the 23’ across the prairies easily. We are looking at tow vehicles and like the Grand Jeep Cherokee or the Ford Explorer. Both of these vehicles can tow 5,000-6,000 lbs. The 23’ Airstream weighs around 4,800 and the max. weight is 6,000. Are these vehicles underpowered, especially since we enjoy the mountains and will be looking to spend some time in Colorado. Thanks for your help.
wkaren3 is offline   Reply With Quote
Old 06-20-2018, 08:36 PM   #2
2002 19' Bambi
Lafayette , California
We have towed our 19' for years with various Jeep Grand Cherokees, all with V8 engines. Our present tow vehicle is a 2016 Jeep GC with the 5.7l V8 and air suspension. All of our Jeep GCs have pulled our trailer with ease, both on the flat and in the mountains. We have always used a Hensley Arrow hitch so there is no sway. Many consider a Hensley (or ProPride) to be excessive for a small trailer and too expensive. We like the peace of mind it has always given us.
Tim
Tim A. is offline   Reply With Quote
Old 06-20-2018, 09:06 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
For the absolute best advice, please contact the foremost expert on what will tow what length of Airstream; Andy Thompson at Canam RV in london Ontario.
You maybe surprised at what vehicles he would recommend to tow a 23'. Get the whole list and then decide what vehicle would A) be best suited for you as a daily driver for 9/10ths of the year, and B) what vehicle would tow the Airstream for the 1/10th of the year.
Cheers
Sidekick Tony
Old 06-20-2018, 09:10 PM   #4
2012 19' International
Southeastern MI , Michigan
Grand Cherokee V8 yes. Explorer V6 (basically a front wheel drive car) ... No.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 06-20-2018, 09:44 PM   #5
jcl
Vancouver , British Columbia
The Explorer is available with a 365 hp Ecoboost V6 as used in the F150. Hard to imagine that being underpowered for a 23. Agree with calling CanAm.
jcl is offline   Reply With Quote
Old 06-20-2018, 11:24 PM   #6
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
The Dodge Durango may be worth investigating. Compare wheelbase. Much other similar or the same as the JGC. Several folks have had good results with the JGC in several power plant variations.
https://www.dodge.com/durango.html?s...E&gclsrc=aw.ds
The 23 is an easy tow, but much of the fun is being able to maneuver in tight spaces. How the RV handles is key there, so keep turning radius in mind.
No, the Explorer is listed at a 5000lb tow capacity, so with a 6000lb gross on the 23, it's less than ideal.
Andy has suggested the Jeep 4dr wrangler tows well. He had the opportunity to drive one recently.
All of these vehicles have a high center of gravity due to the SUV design. If you can find a lower CG solution, it would help towing stability considerably. The alternative that helps is a suspension that is stiff for towing, but compliant to road surface for superior traction.
Good luck with your investigation. Pat
Jeep Grand Cherokee EcoDiesel TV with 27' Airstream. Zybane Towing, Tow Vehicles & Hitches 33 05-10-2018 08:45 PM
Jeep Grand Cherokee DIESEL as towcar Coloradobus Tow Vehicles 10 09-02-2008 02:47 PM
2007 Jeep Grand Cherokee Gravelcrunch Tow Vehicles 11 07-29-2008 04:36 PM
Jeep Grand Cherokee CR Diesel Nicksut Tow Vehicles 19 10-19-2007 09:07 AM
2004 Jeep Grand Cherokee V8 and a 20' Safari? Roger S Tow Vehicles 10 04-15-2007 04:04 PM
