Old 05-26-2009, 07:42 PM   #1
2016 27' Flying Cloud
Pittsford , New York
Jeep Commander as a tow vehicle
Anybody have any experience with a Jeep Commander as a tow vehicle. I have a 19' Bambi and am towing with a Jeep Liberty (5,000 lb max tow weight). Am looking to upgrade tow vehicle as inevitable path to a larger Airstream. Jeep rates Commander with Class IV hitch up to 7,400 lbs. Does this sound realistic?
TG2500 is offline   Reply With Quote
Old 05-26-2009, 07:46 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
It's got the power, but frankly with about 109" wheelbase, you really shouldn't tow more than say around 20'. Depending on what your thinking as an upgrade in trailer, if you want more than 20', you should be looking at something different IMHO.
Old 05-26-2009, 07:54 PM   #3
JimGolden's Avatar
1977 31' Excella 500
Wheelbase is a good thing to be sure. How about a crew cab long bed
If you have your heart set on a Commander (they are pretty nice...), you might consider getting a Hensely Arrow hitch for it. Biggest problem with the short wheelbase vehicles is sway, and the Hensely should take care of that.
Call 'em up and get the free DVD. Thing will even slice bread for you
take care,
- Jim
JimGolden is offline   Reply With Quote
Old 05-26-2009, 07:55 PM   #4
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
I tow a 1963 Tradewind (24') with a Jeep Grand Cherokee Overland. It has the same tow rating as the Commander. I have the Mercedes 3.0L diesel engine in mine, and it has plenty of power.
So far I have towed the Tradewind over 2000 miles with no problems. I use an Equal-i-zer hitch.
My Dad towed a 1962 Overlander (26') and a 1970 28' with Jeep Wagoneers in the late 60's and early 70's. Never had a problem. Jeep used to advertise towing an Airstream.
Mike Brumback
Grand Master is offline   Reply With Quote
Old 05-26-2009, 08:03 PM   #5
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
We tow a 23' with a 2000 Jeep Grand Cherokee and haven't had any issues with sway. It tows like a dream on flat and moderate hills. We haven't towed in the Rocky Mountains yet, so we don't know how it will perform there.
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 05-26-2009, 08:21 PM   #6
Road Ruler's Avatar
Images: 38
Good day Zev... The Hensley and others are state of the art.
Trailer Sway Elimination Guaranteed - Hensley® the ONLY trailer hitch guaranteed to totally eliminate trailer sway.
Old 05-26-2009, 09:56 PM   #7
c177tx's Avatar
2008 19' Bambi
Images: 20
Jeep Commander
I have the 2008 4.7l sport towing an 08 19' Bambi with a Equlizer Hitch. I have plenty of power and have not had any sway problems. At one point on IH 10 I was easly going the speed limit. The speed limit out west of Junction Texas is 80mph. The 4.7l has 305hp and a 6500# limit. The 5.7l hemi has more hp and the higher 7400# tow. One thing about the Commander is it has a short distance from the rear axel to the hitch. From what I understand this helps to prevent sway. The Commander also has anti sway control this according to the jeep web sight.
"Commander's available Trailer Sway Control[1] (TSC) system helps reduce trailer sway and improves handling in adverse towing conditions caused by crosswinds and traffic.
TSC works with the Electronic Stability Program[1] (ESP) and Antilock Brake System (ABS), alternating brake pressure to automatically correct oscillation in the vehicle trailer system.
TSC does not require any driver input. It automatically activates when needed. The ESP function lamp will flash when TSC is activated."
If I had a larger storage lot, I would have purchased the 23fb, for the Queen bed. But after camping with the bambi I am glad to have the shorter bambi. I love sitting at the front dinning table with the wrap around windows in the morning. I have owned jeeps for years and love them. But if I where going to get a 25' or longer I would get an extended cab PU.
c177tx is offline   Reply With Quote
Old 01-24-2010, 09:42 PM   #8
2004 28' Safari
Broomfield , Colorado
I tow a 28 ft Safari with my Commander. I has the power to tow my AS easily. I would recommend a sway control system (I have a Reese Dual Cam) if you plan on towing anything longer than 20 feet with a Commander. I get about 10 mpg when towing.
ID:	94737   Click image for larger version
Rush is offline   Reply With Quote
Old 01-24-2010, 10:01 PM   #9
2004 28' Safari
You could tow your Bambi easily with a Commander! Just get the Tow package! If you want to upgrade, I would not get anything longer than a 28. I tow a 2004 28 Safari W. Also, get extended mirrors. The stock commander mirrors aren't that great.
2008 Jeep Cherokee Diesel 4x4 - what can I tow?? TDITD Tow Vehicles 7 08-22-2008 09:28 AM
Tow vehicle help...please pamelake Tow Vehicles 8 11-06-2005 06:59 AM
Jeep tow vehicle johnwmooney Tow Vehicles 30 02-18-2005 05:38 AM
Tekonsha Commander Brake Controller y5e06 Brakes & Brake Controllers 3 08-13-2004 03:30 PM
Reason #2303 Jeep Should not Tow JodynJeep Tow Vehicles 4 09-15-2003 05:10 AM
