Old 04-20-2009, 07:30 AM   #1
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
It is raining and the truck wont start!
I have a 1998 Chevy 1500 4 x 4 with 130000 miles on it. I am at home in the driveway, and currently unemployed (no big hurry to have it running). This is the third time for this. The first time I went through the electrical system and found nothing! After changing the cap and rotor (which looked like new) the truck ran fine. Four hours in the garage with the heater blowing at it while I checked the ignition control module at the auto parts store ( it checked fine) then removed the coil took it to auto parts store ( it checked fine) so I bought a cap and rotor and installed them. The truck fired right up. A month later it rained over night after a three hour trip home from Indy. Then nothing!!! No spark, had air, had fuel, No reason to suspect no compression,= must be no spark. I left it sit in the sun the rest of the day and in the morning it started right up!
Now I have the trailer hooked to it in the driveway (I live in a subdivision where the trailer cant live!) was going to take the trailer back to the barn last night and after raining all day now the truck wont start again!! If you have a suggestion where to turn next let me know. I will pouring through the chiltons manual again to see if I can get it figured out. Thanks in advance Mike
memgrove2000 is offline   Reply With Quote
Old 04-20-2009, 07:46 AM   #2
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
try a blast of WD 40 in the cap and on the rotor. I had a Ford that did that from time to time when it got damp and WD 40 would cure the problem until the next time.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 04-20-2009, 08:02 AM   #3
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Check your coil wire, & coil again. Moisture is shorting something out. Adios, John
Diesel1 is offline   Reply With Quote
Old 04-20-2009, 08:31 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Do you have spark at the cap terminals and coil and nothing at the plugs?
Try the "tap" test on the Computer. Crank over while tapping. Computer should be above the glove box right side. May be an intermittent open in the PCM. Check the connector terminals for the green grunge.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-20-2009, 08:33 AM   #5
Elkhart , Indiana
Thanks will do !! As soon as the rain lets up a bit. Now a new note. The truck wont fire while the starter in engaged but it will fire one or two cylinders after I stop turning the key. But it wont stay running. I think the temperature has risen 8-9 degrees since last time I tried. Mike
Old 04-20-2009, 08:46 AM   #6
Ignition Switch is a good place to start. ( no pun intended)
PFC
"Tahawus"
RLC
John Prine
Old 04-20-2009, 09:12 AM   #7
Cincinnati , Ohio
Get a tube of dielectric grease.
Apply a liberal application of said grease to both ends of all the spark plug wires.
Remove the cap, dry out the interior, add a bead of RTV to the bottom lip, and put the cap back on.
You also might want to check all the relays under the hood. Corrosion of the copper connections is not uncommon and could be causing a spotty connection. My old truck did this to me often.
Whenever I pull anything electrical apart on my truck, I use a liberal application of the dielectric grease to prevent future corrosion.
Hope this helps,
Woody
Woody.303 is offline   Reply With Quote
Old 04-20-2009, 12:11 PM   #8
1971 29' Ambassador
Leonardtown , Maryland
Mike, Next time take the distributer cap off and blow everything out with a hair dryer, Is there a rubber seal around the bottom of the Cap? Should there be? Examine cap under a strong light looking for a hair line crack. I had a Plymoth and an MG with this problem, did not know the Chevy had same problem. dale
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 04-21-2009, 09:19 AM   #9
Mike,
My comment in post 6 may be a little vague. The actual switch I was referring to is NOT the key switch. There is a switch located on the the lower portion of the steering column, right side, just above the firewall, when it goes bad will give the symptoms you described in post 5, can be very intermittant. It supplies power to the ignition in the start/run position. It has a gear inside that has gone out of "time", and could now be powered only in the run mode. Turn the key on and with a test light see if you have power at the coil, try the start mode and re-test. If not a new switch must be installed and positioned correctly to supply power in both start and run positions. If you have a remote starter button you could try starting by connecting directly to the starter.
Hope this helps..
PFC
"Tahawus"
RLC
John Prine
Old 04-21-2009, 10:33 AM   #10
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Another thing to check is to try and start the engine at night, while it's still damp out. Watch all the sprak plug wires, expecially from the coil to the distributor for arcing, which you may not see during the day. I've found bad plug wires that way many a time on older cars and trucks. Just be careful of course!
Chris
Old 04-21-2009, 11:11 AM   #11
Elkhart , Indiana
New info.
Well it cleared up yesterday afternoon and warmed up a little. And the truck started so I was able to get the Airstream back over to the farm house where it lives two miles from here. I purchased a code reader from the auto parts store and now have new info. The first code is the MAF ( I would think this would make the truck run just too rich or too lean?) I did not think that it would be "run or not" when it is cold and damp. The second code is Break in the circuit camshaft/crankshaft position sensor. This could be the problem now I know what sensors to check I will go out with the test light and multi meter and try to follow the Chilotn manual to test them. Thanks for all the Ideas I still have not ruled out the Ignition switch ( there seems to be a lot of moisture on the floorboard in that area). Like I said I am unemployed and this is now our third vehicle so getting it fixed is only keeping us from our camping schedule. I hope to have it fixed by the first of may!! Thanks again and keep your thoughts coming. This site is great!!!! Mike
Old 04-21-2009, 12:05 PM   #12
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you unplugged those sensors and turned the key on, it could have stored those codes.
The crank position sensor should be on the front of the engine, behind the crankshaft pulley/harmonic balancer. The crank sensor could be what is giving you the problems. Check the wires going into the plug, and the plug itself, for that sensor. The mass air flow sensor being bad will allow the truck to start, but it will run very poorly.
Old 04-21-2009, 12:29 PM   #13
Minno's Avatar
1972 31' Sovereign
I would disagree with having a bad MAF will still allow the engine to start. I had a 98 Ford van, and when the MAF failed, the engine would not start. Ran fine the previous day. Of course, all auto makes have different quirks. Just telling you this so you don't rule it out.
Chris
Old 05-01-2009, 10:24 AM   #14
Elkhart , Indiana
Robert Cross... Bob
Would the Ignition stitch "timing" be affected by the cold/rain? I have a code reader and have replaced the Crank position and cam position and Mass air sensors.
The truck ran for a couple of days ( no rain) and would not start again yesterday (rain all night).
I will test the power to the coil as described in # 9 as soon as I can spend some time in the garage (our two year old doesn't allow much uninterrupted wrench time)
The P 0340 code from what I find is a "fault in circuit cam sensor" is still showing. How do I test this circuit?
The MAF code and the crank position code have gone away. But the truck still doesn't like the rain.
Please let me know what you think? Thanks Mike
furnace wont start matthew NYC Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-15-2009 05:11 PM
You guys wont believe this... Mrcrowley Nu-Tone Appliances & Central Vac System 7 08-18-2008 01:08 PM
Brake light wont work; where to start. Swat Brakes & Brake Controllers 2 07-11-2007 08:09 PM
Oh no it wont move!! Angel73 Fresh Water Systems 9 03-17-2007 09:56 AM
raining inside gotair Leaks - Weatherstrips, Gaskets, Caulks & Sealants 24 01-26-2005 07:11 PM
