Old 04-06-2015, 08:00 AM   #15
1985 31' Sovereign
Lovettsville , Virginia
The post above is partially incorrect. Otherwise, it and the others are spot on. Your pickup and Airstream going to the lake for the weekend is NOT classified as a "commercial motor vehicle" unless your pickup has a GVWR of 26,001+ lbs (not GCWR) or unless you're hauling someone else's Airstream for a fee (like delivering).
As long as you're not towing someone else's trailer as a delivery or transport service where you will be paid, and you're not towing it in order to transport other goods for sale across state lines, you're fine and don't neet a DOT number. Take it from a guy that has a Class A,M CDL with every endorsement except for HazMat and Passenger/School Bus, and used to be someone who could be behind you in the car with a funny paint job and blue lights.
85 Sovereign is offline   Reply With Quote
Old 04-06-2015, 08:02 AM   #16
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Ha Love it, everything including HazMat but NO blue light history, except following me at times.
Take Care
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-06-2015, 09:40 AM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
The federal CDL regulations do not apply to RVs, trailers or MOHOs. However each state has it's own regulations on towing a trailer. The biggest consideration in these regulations is when a trailer has to have it's own braking system. Since almost all RV trailers exceed the lowest of these regulations it should not be an issue.
2004 Excursion 4x4
Old 04-06-2015, 12:31 PM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I meant to say "not". I left it out by mistake-
Oops.
I am a DOT compliance guy who apparently cannot type very well.
Towing your own travel trailer requires no special training, apportioned plates, or special driver's license.
The DOT rules and regulations apply to commercial motor vehicles, for hire, doing trade or commerce.
Also, your pickup and Airstream trailer do not have to cross the scales at weigh stations.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-06-2015, 11:42 PM   #19
Thanks to all for the great information. My wife WILL (hopefully) sleep better tonight not having to worry about this any further.
2Fast4U is offline   Reply With Quote
Old 04-07-2015, 01:38 AM   #20
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, in California, I looked this up a few years back because a co-worker was going from an already too heavy toy hauler trailer to an even larger toy hauler. The rule was that if the trailer weighed, GVWR, not actual weight over 10,000 lbs, you had to get a non-commercial Class A driver's license.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-07-2015, 01:40 AM   #21
Salem , Oregon
Images: 18
Hi, my co-worker's truck was rated to tow 7,800 lbs. He, later, lost control of it while passing a big rig down hill and rolled it. He no longer tows.
2005 Safari 25-B
Old 04-07-2015, 01:58 AM   #22
Salem , Oregon
Images: 18
Noncommercial class A driver's license.
Hi, I just did a search on this and in California you need a noncommercial class A driver's license if your trailer has a GVWR of 10,000 lbs or more. Also if you have a fifth wheel trailer that has a GVWR of 15,000 lbs or more. And if you have a live stock trailer that has a GVWR of 10,000 lbs up to 15,000 lbs. And these are for personal use only. [not for hire]
2005 Safari 25-B
Old 04-07-2015, 02:06 AM   #23
Salem , Oregon
Images: 18
Originally Posted by 2Fast4U View Post
If your GCWR > 10,000 lbs. do you meet all of the Department of Transportation (DOT) commercial operating requirements? Do you have a DOT number? Do you display it on your TV? If so what other "stuff" do you do to stay legal?
Doesn't this apply to most of us? How do y'all handle this legal wrinkle that I haven't seen discussed here before.
DOT Mandates May Apply When Using Trailers - Articles - Safety & Accident - Articles - Work Truck
Thanks!
Hi, I read this link and it's information is in-correct; Read my previous post.
2005 Safari 25-B
Old 04-07-2015, 07:29 AM   #24
K.C. , Missouri
What part of that is incorrect Robert ? It looks right to me because they are talking about commercial use. That is different from private, not for hire use.
gmw photos is offline   Reply With Quote
Old 04-07-2015, 08:40 AM   #25
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Non-commercial (meaning RV trailers and tow vehicles) vehicles seem to be mostly ignored by DOT unless there is a blatant visible safety issue. Highway safety devices (triangles or cones in case of a flat or breakdown) and fire extinguishers are just common sense to have when traveling along with a decent first aid kit.
Old 04-07-2015, 12:49 PM   #26
m.hony's Avatar
2013 30' Classic
What in the world is a non commercial Class A license?
There is no such thing in Mississippi.
TAC #MS-10
Airforums #70955
Old 04-07-2015, 01:17 PM   #27
K.C. , Missouri
No such thing in Missouri either. I think it's something that is unique to the peoples republik of Kalifornia. Sceptics would say it's just another way for the DMV to collect some more taxes. Supporters would say it's a useful road safety process because it requires passing a test that proves the operator understands the safety issues.
I can see valid points both ways.
Old 04-07-2015, 02:07 PM   #28
jcl
Vancouver , British Columbia
Doesn't exist in my province either. But it doesn't appear to be unique to California. On line sources suggest there are non-commercial special license requirements (based on GVWR of TV or trailer) in CA, CT, HI, KS, MD, NC, NM, NV, NY, PA, SC, TX, and WY, plus more if you have more than one trailer connected.
Jeff
jcl is offline   Reply With Quote
Gcwr MrUKToad Tow Vehicles 122 08-30-2013 08:05 AM
Comparing GCWR to Actual Weight BobGall Tow Vehicles 13 06-09-2013 04:41 PM
Anyone towing 27FB (7,600 lbs / 770 lbs tongue) with a V8 or TDI Touareg ? Timofeevich Tow Vehicles 41 09-23-2011 05:55 PM
Anyone towing 5,000 lbs with a V8 BMW X5? adwriter73 Tow Vehicles 20 06-17-2010 01:14 AM
Diesel Chevy, Ford, Dodge, or GMC?! 10,000 lbs NomadKitchen Tow Vehicles 12 10-16-2009 09:01 PM
