Old 05-29-2011, 10:29 AM   #1
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Is TV batt isolated from AS house batts?
Please pardon my continuing questions. I do a Search on most of these, but this one didn't seem to work out well.
Thinking about the WDH stuff, I was thinking about what else was going on at that interface beween TV and AS, and wondered if that 7-way trailer harness connector is tied in with the ignition switch on the truck.
Is this how and where the starting battery in the tow vehicle is kept isolated from the discharging house batteries on the Airstream?
this is some place the home handy man could screw up if he wasn't careful, huh.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 05-29-2011, 10:53 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Regarding the battery Isolation, the answer is maybe. I believe Ford uses a relay tied to the ignition switch, Not sure about the others.
In years past diode isolators were common but I don't think they are in common use today.
You can check for the presence of voltage at the TV connector with a meter or test light with the key on and off and without the trailer connected.
In my case I have added a relay and a separate switch to control the charge line which is usually OFF since we have solar.
This became necessary when I was delivering new trailers and frequently every light in them was turned on and they were all running off my battery.
Of course on an overnight stop you can always just unplug the TV cord. If I do this I will wrap the seatbelt around the steering wheel so I have a reminder that there is something I need to do before moving on
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 05-29-2011, 12:02 PM   #3
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Gringo, on the Fords, the charge wire is on a relay, and disconnected unless the key is in the on position. My Nissan was like that also, I thought a friends 2010 Chevy is like that, but someone in another thread says his older Chevy is hot all the time. In any case, i wouldn't worry about draining the trailer battery starting the truck. The wire in all these factory tow harnesses are too small to draw much current.
newroswell is offline   Reply With Quote
Old 05-29-2011, 01:06 PM   #4
JFScheck's Avatar
Rockville , Maryland
Images: 33
I agree - the drawl you pull from the trailer battery if any will be charged back up fairly quickly - and if it was actually drawing power from the Trailer - that wiring would most likely burn itself out so I'm betting by design it's bypassed via diodes or something else...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 05-29-2011, 01:10 PM   #5
one of those
Gringo's Avatar
I was more concerned the other way around. I wouldn't want to sit someplace for a day or two and find out that something in the trailer's 12 volt system had completely drained all the batteries, including the truck battery.
Old 05-29-2011, 04:35 PM   #6
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
At least on my '09 GMC, the charge line is "hot" all the time ... I hooked it up that way. So when I park for long and don't unhitch, I always just "unplug" the trailer. Causes me to wonder - and perhaps I ought to check - if I leave the plug in and it's sunny, would my solar panels on the trailer also top off the truck's two batteries, or is there a diode in the circuit somewhere?
AirsDream is offline   Reply With Quote
Old 05-29-2011, 05:46 PM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
If it direct connected as is most likely, the trailer panels should charge the truck battery. You should be able to see a voltage increase of a few tenths at the truck battery when you plug the cord in.
I developed an intermittent alternator in South Dakota and used the charge line from the trailer to help me along until I got back to TN.
Wouldn't provide all the charge to stay even but every now and then the alternator would start to work and between the two got home ok
13 Ram 2500 TD
Old 05-30-2011, 05:31 AM   #8
one of those
Gringo's Avatar
ah, so the answer is, if we find ourselves boondocking someplace for a few days, unplug the trailer from the truck. or else when we go to leave we might find ourselves up the proverbial tributary without the proper means of location.
and no way to start the truck.
Old 05-30-2011, 06:05 AM   #9
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
They used to provide a crank to turn the motor over... :-)
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 05-30-2011, 06:23 AM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Depends on your TV. The best way is to check the charge line when the ignition is off. Both of my Fords disconnect the Charge line when the TV is off.
Michelle TAC MT-0
Sarah, Snowball
Old 05-30-2011, 07:36 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
To be sure.
If you are not sure; there are a few options.
Unplug the TV
Install an isolator switch
Pull the fuse in the charge line.
Of course in all of the above there are things to remember.
I always check the lights on the trailer before leaving home or a camp site.
The seat belt thru the steering wheel is a good idea. I would have to put a "sticky note" on the dash to help me remember why the seat belt was there. LOL
Old 05-30-2011, 07:56 AM   #12
Ottawa , ON
Good one, and frighteningly close to the truth!
Old 05-30-2011, 07:57 AM   #13
one of those
Gringo's Avatar
you guys use seat belts?
Old 05-30-2011, 06:53 PM   #14
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A Silver Streak owner to the rescue
Oversized TV to TT Batt Chg
Airstream Ice Fishing House? vroom Modifications 16 01-07-2015 07:32 PM
Did Wally own a house? Ganaraska Airstream History 19 04-28-2012 09:14 AM
Airstream on the Tiny House Blog moosetags Airstream "In the News" 5 02-10-2011 06:50 PM
Holiday House for SALE! Foiled Again Vintage Kin 19 02-03-2011 03:36 PM
Radio on house battery michalakes Electrical - Systems, Generators, Batteries & Solar 1 01-05-2011 02:07 AM
