Old 09-16-2007, 06:11 PM   #1
1999 25' Safari
Sebastopol , California
Is this F350 enough truck?
I'm looking at a 1994 F350 XLT with a 7.5L engine/auto trans and a 4.10 rear end. The tables in the Ford book put this at a max tow weight of 7600lbs. I'm considering using it pulling it with a 1983 31' Limited which is 5500lbs dry and quite a bit heavier loaded. Do you think this is enough vehicle for this trailer.
Ben
Aluminumb is offline   Reply With Quote
Old 09-16-2007, 06:18 PM   #2
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Ben
Hi Ben, What is the GVWR (gross vehicle weight rating) of the Airstream? This is the weight you should look at. Also you need to determine what the GCWR (gross combined weight rating) for the truck is too. This would be the total weight of the truck and trailer combined.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 09-16-2007, 06:25 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Ben, are you sure about those figures? My F250 with a 5.8, and a 4.10 rear, has an 8500 pound towing capacity. And our Sovereign weighs in at a little under 7000.
Old 09-16-2007, 06:46 PM   #4
1999 25' Safari
Looks like I have more homework to do
I know see I have a little homework to do before I ask this question. I don't know the GVWR for the trailer. Does anyone know the approximate GVWR for the 31' Excella center bath unit which is very much like the Limited?
The GCWR for the truck according to the Ford tables is 13000lbs. I don't know how much the truck weighs.
And Terry, the book says the Trailer weight range is 0-7600lbs. I bet your 250 is newer than 1994?
Ben
Old 09-16-2007, 06:51 PM   #5
Well Preserved
1993 21' Sovereign
Ben
My truck is a 1988...
Your trailer weight sould be within a couple hundred pounds of our 31. The truck and trailer combined are 11900. Trailer weighs 6420 pounds in working order, with water and holding tanks empty.
Old 09-16-2007, 06:59 PM   #6
1999 25' Safari
So is the 11900lb number the most important
Terry, does that mean the truck should be able to do it if the trucks limit is 13000lbs? Or do you need to have more of a buffer?
Ben
Old 09-16-2007, 07:02 PM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Ben
Something sure seems fishy on that dry weight! The '82 Limited 31' rear bath is listed as 8300 lbs. dry weight, the '83 is listed as 5550 lbs. My '77 Excella 500 31' had a dry weight with accessories of 5430 lbs. and a GVWR of 8100 lbs. so I would expect the trailers in the early '80's to be slightly heavier. Even the '82 Excella 31' rear bath is 6800 lbs.
Based on that info, weight it to get the real weight and check you GVWR tag.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-16-2007, 07:10 PM   #8
87MH's Avatar
1978 31' Sovereign
Images: 292
I... Does anyone know the approximate GVWR for the 31' Excella center bath unit which is very much like the Limited?....
You should have a plate under the front window (on the outside) sort of to the driver's side that looks very similar to the one below.
The one below is for a '78 Sovereign - The Airstream website (the old one) listed a weight of about 550 lbs for the tongue. Total weight for the trailer would be 3200 on each axle, plus the 550 to 700 on the tongue.
The Excella will probably have an additional weight rating of 100 or 200 lbs (or more) per axle since it came with some extras that the Sovereign did not.
The Airstream site listed the '83 31' limited specs with a dry weight of 5550 lbs and 725 lbs on the tongue.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-16-2007, 07:14 PM   #9
DFord79's Avatar
Yakima , Washington
Plenty of truck. The F-350 with the 460 is capable of much more than you will be asking it to do.
DFord79 is offline   Reply With Quote
Old 09-16-2007, 09:07 PM   #10
1999 25' Safari
Thanks to all for the input. Looks like this truck is capable.
Ben
Old 09-27-2007, 10:52 PM   #11
2007 25' Safari SS SE
Alton , Illinois
Hey guys, somethings wrong with those figures. We had an early 90s F350 XLT, 460 with a 5 sp. manual at the shop that made like 480,000 miles hot-shotting. Just an outstanding truck, 10 mpg unloaded or fully loaded, didn't matter. If memory serves this truck was designed to pull up to 11,000 pounds. We used to worry because a flatbed of towboat parts could weigh 13,000 pounds but we never had an issue, went through a lot of tires though. If trucks in good condition it should be fine.
The "Ann Rutledge"
Brad Hunt is offline   Reply With Quote
Old 09-28-2007, 05:23 AM   #12
Ben
Ben,
We have an 88 Ford F250 7.3 diesel (non-turbo) and we towed our 20' Argosy motorhome from Eastern Tennessee to Arkansas with no problems. Our combined weight was about 15,000 lbs. I most certainly wouldn't do this every day but we had no issues other than not driving over 53 mph.
An F350 should tow your trailer easily.
Old 09-28-2007, 08:15 AM   #13
1999 25' Safari
Thanks for all the input. I got the truck and it pulls the trailer great. I can tow up to 13000 lbs with its engine/rear end. It rides a little rough without any weight on it, but the power is definately there when I need it. And of course, it sounds like a tank.
Thanks, Ben
Old 09-28-2007, 10:50 AM   #14
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
7600lbs sounds low. Gas or Diesel? Bumper or reciever?
My old 5.4 Gas 250 was rated at 10,000 lbs.
Michelle TAC MT-0
Sarah, Snowball
F250 or F350? Craftsman On The Road... 43 02-10-2018 04:27 PM
Too much truck? gowyn Tow Vehicles 23 08-19-2007 08:34 PM
You can never have to much truck.... wasafari Tow Vehicles 7 06-14-2007 11:27 AM
price ford F350 1982 remcolent Tow Vehicles 0 04-28-2007 02:31 PM
MPG of F350 Diesel Dually??? joossens Tow Vehicles 13 06-13-2004 12:55 PM
