Old 01-14-2007, 09:46 PM   #1
atticus_ar
Profile:  Ashtabula , Ohio
Is this a strong enough tow vehicle?
Well, I'm considering buying a friend's 1971 31 foot Sovereign International, rear bath, center beds, and I was curious if my 1999 Jeep Grand Cherokee Limited is going to be able to get the job done towing it?
The vehicle has a 6500lb tow max, and the friend that is selling it said the title says 4000lbs for the airstream, but that he'd guess it more around 6000lbs, and I was curious if this was going to be pushing it far too close to the vehicles limits for towing...
Anyone have any experience with jeep grand cherokees and their towing ability?
atticus_ar is offline   Reply With Quote
Old 01-14-2007, 09:55 PM   #2
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
I'd say NO
If you look on the blue bar above, you'll see a "SEARCH" function. You can find several great threads about towing written by heads with far more experience than mine. Try "Jeep Cherokee", "Best Tow Vehicle" etc.
The first thing to remember is that you not only need to TOW a trailer, you need to be able to hold one back going downhill and stop one. The Cherokee is light and also has a short wheel base... not a good thing with a long trailer.
Paula Ford
Foiled Again is online now   Reply With Quote
Old 01-14-2007, 10:00 PM   #3
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings atticu_ar!
Welcome to the Forums!
The '71 Sovereign International had a base empty weight of 4,840 pounds with a hitch weight of 480 pounds. Realistically when this coach has full LP tanks, water in the fresh water tank, and the day-to-day necessities for its occupants as well as installed options and accessories the ready to travel weight will likely approach 6,500 pounds with in excess of 725 pounds on the hitch.
One of my favorite tow vehicles was a full-size Jeep Grand Wagoneer, but I wouldn't have wanted to tow much more than my '64 Overlander that grosses out at about 6,100 pounds with a hitch weight of 750 pounds. Two things work against the smaller post-Grand Wagoneer products -- wheelbase, trac width, and power; and in the case of the Sovereign the gross weight of the coach would almost certainly exceed the GCVWR rating of your Grand Cherokee when both vehicles are loaded for a trip.
Quite honestly, I would be hesitant to consider an Airstream with a length much more than 22' with your tow vehicle.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 01-14-2007, 10:02 PM   #4
mistral blue
Certifiable
mistral blue's Avatar
Profile:  1977 Argosy 24
Beautiful , New England
Short answer: No
You'll be able to safely tow a trailer that is weighs 80% of your towing capacity. 5200# would be your max. And I thought '71 31' Sovereigns weighed in the neighborhood of 7100#.
mistral blue is offline   Reply With Quote
Old 01-14-2007, 10:09 PM   #5
atticus_ar
Okay, good to know, so I guess I either need a smaller airstream or to find a better tow vehicle.
In honesty, the actual towing will probably only be once or twice a year across town, as I switch from seasonal campground to seasonal campground, but I see the point in all this, and that is that the setup I'm talking about just won't work.
thanks for the replies, that really helped.
Old 01-14-2007, 10:21 PM   #6
Foiled Again
Cross town moving
If you're really planning on using it as a park model and just move it twice a year, don't even consider a tow vehicle. You can probably pay someone with a big honkin' Ford F-250 or F-350, or a Chevy 2500/3500 to move it for you.
Planning on living in it full time? Get the biggest one you can afford in good condition. PS, my family lived in Ashtabula in the 1930's. We visited there about a year ago - as well as taking in the Maple Festival in Burton.
Paula
Paula Ford
Old 01-14-2007, 10:26 PM   #7
atticus_ar
Yes, actually, good guess, I am planning on living in it full time.
Just out of curiousity, anyone have a good, older, cheap tow vehicle to suggest, not one for sale really, but one they'd say would make a good combo for this (and not 20grand ;-), I know there is a suburban about 20 miles up the road from me for sale for $2grand...but
What was this area like in the 1930's I wonder? Getting a bit urbanized now, but I remember back in the 80's it was country living ;-)
Old 01-14-2007, 10:33 PM   #8
Paul NC
Profile:  Clayton , North Carolina
I know you've made up your mind (a good choice I might add) but I just wanted to add one statement... weither it's just an occasional run down the road or a long haul, it still has to be a safe setup. You can run across the idiot who decideds to use your lane instead of his and put you in a bad situation like what happened to me one time. I was towing from Winder GA to Dacula GA (25 minutes) and was on a two lane road and going around a curve the idiot coming from the other direction decided he was a race car driver and take the curve in my lane. I had just added trailer brakes THE DAY BEFORE and I guarantee you if I did not have the brakes, and the proper setup (bars and such) the manuvers I had to do to avoid, the trailer would have come around and said "HI!!!" and I'm sure the jerk wouldn't have stopped to see if I was allright.
Stepping off my soap box.
"Cats are intended to teach us that not everything in nature has a purpose." - Garrison Keillor
Paul NC is offline   Reply With Quote
Old 01-14-2007, 10:35 PM   #9
Foiled Again
Hi Atticus
My mother and aunts were able to recognize everything in Ashtabula - but were shocked that the greenhouse grampa Scannell ran had been torn down (only half a century had passed after all). The area still has a lot of rural charm.
About the tow vehicle.... you'll probably be able to get it towed for $50 or less. I have a Suburban 2500 and get 12 mpg. Keep the Jeep!
Paula
Old 01-15-2007, 05:20 AM   #10
overlander63
Rivet Masher
overlander63's Avatar
Profile:  Bay Area , California
Many automobile towing companies have setups for their towtrucks to enable them to tow a trailer, you can make a few calls and see how much they would charge you. For $100-150 a year I wouldn't mess with a tow vehicle, if that's all you are going to be doing.
overlander63 is online now   Reply With Quote
Old 01-15-2007, 08:05 AM   #11
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
No Jeep
Good morning Atticus-
The two basic rules for TV vs. TT is wheel base and weight percentage. Your TT should never exceed 70% of your maximum towing capacity. You will find several discussions on the Jeep as a TV. It certainly appears the majority of your forum members feel the Jeep is not a good TV for AS. Use your search function and you will find several very good threads on this. Look forward to hearing on what you do end up with!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 01-15-2007, 08:07 AM   #12
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I think everything thats been said here is right on. Even short hauls need to be safe....the GC will move the RV you mention, but it won't tow it safely.
My brother has a 2004 GC with the high output V8 and wants to tow a 25' SOB that weighs about 6000lbs. I told him to reconsider that decision, just as many here have described to you.
Old 01-15-2007, 12:08 PM   #13
Paul NC
Good point!
Wonder if one could sneak that through their AAA rv coverage?
Old 01-15-2007, 12:28 PM   #14
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Originally Posted by rickandsandi
...Your TT should never exceed 70% of your maximum towing capacity.
holy cow! 70%??? then you can't tow anything but the shortest of vintage trailers with anything but a 3/4 ton truck. unless, maybe...one of those newer half-tons with the 9000lb rating...which nobody believes they can do, anyway.
the factories include a safety factor when they publish those ratings.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 02:58 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 01:18 PM
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 9 10-01-2004 12:05 AM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 08:04 AM
International 22' AS Tow Vehicle rmmm68 Airstream Motorhome Forums 7 11-02-2002 08:48 AM
