09-22-2017, 09:30 AM
1974 21' Globetrotter
2016 30' International
Houston
Is this a bad idea?
Thoughts? I've got to pull this from Dallas to Houston.
09-22-2017, 10:00 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Not necessarily bad for a short trip, but not great, either. The tow vehicle looks under strain even with a WD hitch. This may impact steering, especially on a wet road. If I were doing it, I would stay off of the Interstate.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
09-22-2017, 10:17 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Yes, it's a bad idea. Will it kill you? Probably not. Is it the worst thing I've seen today? nope. Have I done stuff like this .... errr .... You could loose both the trailer and the TV if there is trouble. That's a lot of money.
If this is a one time effort, there are places that will rent you a truck or van you can tow with. It's cheaper than a new rear axle (or even new rear bearings) on the SUV. If this is a regular sort of thing, I'd shop for a proper TV.
09-22-2017, 11:30 AM
Sag Harbor
, New York
Pretty hard to give an informed opinion without complete data on the tow vehicle's weight ratings and capacities, the WD hitch, and full data on the trailer IMO. [Edit -- full data should include tire ratings, tow vehicle rear axle ratings, TV cargo capacity, and a full-on weigh-in of the combined rig.]
Is this thread a continuation of the following discussion?
[click on arrow in quote to go to that thread]
It's going on a 2011 Ford Expedition, towing a 30 Int'l Serenity. I'll update on the install.
Heck of a lot easier to stay in one thread IMO.
Peter
PS -- I am going to venture a guess, based only on the tow vehicle being down at the stern, that you have exceeded at least one of the weight/capacity limits mentioned above. If so you are subjecting everyone to unnecessary risks IMO. Further, if you are involved in an accident, your insurance may not protect you.
PS2 -- The other thread:
http://www.airforums.com/forums/f238...ol-172728.html
09-22-2017, 11:34 AM
Tampa
1. Electric brake controller?
2. I'd put more "lift" on the WD bars.
3. Is the car rated to tow that much?
Would I? I've done some crazy things, so maybe.
09-22-2017, 12:41 PM
1973 31' Sovereign
Middletown
The most important thing is how much weight is on the rear tires. If your tires can handle the load and you are aware that you will have a problem if you have to make any sudden moves it should be doable for a one time deal.
09-22-2017, 01:20 PM
Houston
Thanks for the responses. Made it back to Huntsville so far. Tows just fine, brake controller works well and has plenty of power to cruise. Everything is completely dry and only me in the TV. Rated for 8900 lbs and 1350 tongue. Equalizer WD hitch. The hitch came off a f250 so needs some adjustment to take some of the stern load off. The mirrors are the real issue. Can't see anything behind me, so I've been cruising off interstate.
09-22-2017, 01:30 PM
Houston
Should also be noted that this is temporary as in this trip only. I will be getting a new TV.
09-22-2017, 01:50 PM
2005 30' Safari
Montgomery
Nice looking trailer!!! We're on the west side of Lake Conroe, hope you have a safe trip home! I pull our 30' with a 3/4 ton, great for pulling and also doubles as a rodeo simulator when I drive around Houston with it! Ha!
09-22-2017, 01:57 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Use The Waggle To See Behind Your Trailer
... The mirrors are the real issue. Can't see anything behind me, so I've been cruising off interstate.
Are you familiar with "The Waggle", a common technique with TT towing? It is a mild s-turn totally within your own lane. Start close to the left side of your lane, then steer to the right side and then quickly back to the left. As you start the manoeuvre back to your left you can see who is close behind you in your driver's mirror that may not otherwise be visible in your mirrors. It is safe, but may require some practice.
Ray B.
09-22-2017, 04:13 PM
Houston
Nope but I am now! Thanks I'll give it some practice.
09-22-2017, 04:14 PM
Houston
Just picked it up this morning! Time for the 4 of us to upgrade to a bigger trailer. No lie on the Houston roads....
09-22-2017, 06:29 PM
2017 30' International
Broomfield
Is this a bad idea?
I towed my 2017 30' international with my Infiniti QX for ~3,000 miles (moved up from a 25' which I towed for ~20,000 miles with the QX). There are plenty of members on the forum who use large SUVs to safely tow 30' trailers. The Infiniti has similar payload, max tongue weight and towing load as your expedition. I also use an equalizer.
I can tell you that for sure, you need to adjust your hitch with the help of CAT scales. With a large SUV with independent suspension everything should be level within 3/4" - front / rear TV fender height and front / rear frame clearance of the trailer.
It's clear that you've got too much weight on the rear axle of your TV and that trailer looks to be nose down.
Your ball height is probably good, but you need to get more aggressive with the head angle of the hitch / possible raise the L brackets one hole. I used 7 washers for mine - and everything is level within 1/2 inch.
Get familiar with running through the CAT scales to ensure you are within your rear axle weight rating and that overall TV gross vehicle weight is under what your door sticker states.
You can safely tow that trailer if you carefully manage TV payload and have a correct hitch configuration. Which basically means you cannot carry anything but a few people in the SUV as the 30' international will generate 950 - 1,000lbs of tongue weight loaded for camping with WD applied.... Lots of good threads here with more details on how to calculate your weights to ensure you are within the limits of your vehicle.
PS- I have since moved to a 3/4 ton diesel - for 2 reasons - (1) more payload and (2) more power/weight/wheelbase.
Having owned and towed a 30' with both a large SUV and 3/4 ton I can honestly say that each has its pros and cons.
Living in Colorado a larger rig ended up working out better for our particular needs, especially regarding payload, power and braking as we travel throughout the Rockies on a regular basis and like to take people + stuff with us in the truck.
09-22-2017, 10:16 PM
1972 31' Sovereign
felton
What vehicles would have been used back in 1972 to have towed my 31' Landyacht, Admittedly much lighter at 5,000 and 500 at the tongue but surely vehicles today are much beefier and safer ? Maybe not so ?
09-23-2017, 06:48 AM
Sag Harbor
, New York
Broad brushes like that, Nick, can mask irresponsible towing practices which put us all at risk, especially in this litigious society, with aggressive insurance companies writing the checks after expensive accidents.
"Measure twice, cut once" IMO.
The OP made it home safely, thankfully, but a careful set of data from a thorough weigh-in might reveal a variety of risks with the set up, again in my opinion.
Maybe not, but good luck on one adventure should not be used as a draft for the next.
Have a good weekend!
Peter
09-23-2017, 07:50 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
We have been through this in many threads. Like it or not, cars have gotten smaller over the years. They have gotten better in some, but not all respects. A "nice big family car" back in the 1960's was closer to a large SUV today than to a modern sedan. The difference between a 5,000 lb trailer and an 8,000 or 10,000 pounder still means a lot today, just as it did back then. Also back then, the whole idea of driving 80+ MPH as "normal" ... not so much. 20 MHP slower than the "other guy" was (at most) 45 MPH.
09-23-2017, 07:54 AM
2018 27' International
Southeastern MI
, Michigan
Earlier vehicles had a full frame but less horsepower and stability than what we have today.
Original poster's picture looks way overloaded in the back but I'm sure he was careful knowing how he was set up, and made it OK. I've towed a lot worse back in the day.
Just bought a Hensley for our new 27' but I noticed on the sticker my F350 payload is 4000 lbs and could probably tow just fine on the ball. Oh well, already spent the money.
09-24-2017, 10:05 AM
1973 31' Sovereign
Middletown
Hey Nick, if you weren't towing your 31"er with a Olds Vista Cruiser station wagon you just weren't cool!
09-24-2017, 01:42 PM
2014 30' Flying Cloud
Tampa
Looks fine to me.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
09-24-2017, 02:06 PM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
You have to dial in your setup to ensure that the Airstream is level. Raise the hitch on the shank, adjust the angle, and transfer more weight to your front Axel. Should then be a great combination.
