09-29-2014, 05:50 AM
2014 23' Flying Cloud
2015 28' Flying Cloud
Laguna Niguel
Is ML430 suitable to tow 23' FC
Just bought our first trailer, a Flying Cloud 23', and planning to tow with my ML430 using equalizer hitch. Anybody have experience or info on this combination? Most towing on the west coast.
09-29-2014, 07:12 AM
1973 21' Globetrotter
Houston
Welcome to the Forums!
There are many threads in the forums about using Mercedes M and GL class SUVs as tow vehicles. A search may help, but there are also a lot of threads on Mercedes Interstates, so you will probably have to play with the search terms, and look specifically in the tow vehicle forum to narrow your results. In short, if your vehicles' towing capacity and tongue weight capacity can accommodate the trailer you have, then there should be no fear. There are also the folks who believe that the GL/ML hitch needs to be reinforced, but it is debatable whether such reinforcement isn't more psychological protection than anything. You might also check on one of the Mercedes forums (Benzworld.org or MBworld.org) to see if you can get a broader report on experiences with Mercedes as tow vehicles.
good luck!
09-29-2014, 12:46 PM
2013 30' Classic
Greenwood
, Mississippi
It might work. We met a man from Pennsylvania while we were at the mother ship a couple of weeks ago. He had a white Mercedes diesel SUV and a 28' International. He had purchased the trailer in Oregon. His 6 cylinder diesel engine had similar horsepower and torque numbers as mu V8 gas engine. He had taken the Mercedes SUV to CanAm in Canada to get the hitch receiver reinforced. He said it towed great.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-30-2014, 08:15 AM
Laguna Niguel
Thanks for info, I checked with my mechanic that has serviced the car over the years and he said "Only for a while" it really needs bigger radiator, trany cooler and beafed suspension. So I'm looking for a Infinity QX56. Can't wait to hit the road.
John
09-30-2014, 09:15 AM
Houston
I'm surprised to hear all of that. There are plenty of people towing with the 320 CDI and 350 Bluetecs, and the Jeep Grand Cherokee diesel. To my knowledge, they all have the same suspension, and would guess the same tranny cooler. As far as I know, the only modifications that go into an ML or GL when the tow hitch is installed is the hitch itself and the electronics to support it. No change in radiators, etc., are involved.
Then again, you will find opinions that cover the whole spectrum when it comes to tow vehicles. You will find someone citing the use of a Jetta TDI to pull a trailer such as yours (I have actually seen this in a post), and those that insist that an F250 is the only viable option. Ultimately it boils down to what you are comfortable with, and what can be safely justified with manufacturer's ratings and recommendations.
good luck.
09-30-2014, 05:58 PM
2013 30' Classic
Greenwood
, Mississippi
John
I've heard of 2 people who were towing with an Infiniti QX56 (now QX8) and were disappointed. Both people ended up trading for a Ram 2500 diesel.
TAC #MS-10
Airforums #70955
10-03-2014, 05:43 AM
Laguna Niguel
Thank you all for your comments. Since I do not want to push the envelop on a vehicles tow capacity and the last thing I want to do have any problems towing up and down the California grades or dealing with the high desert wind gusts I decided the ML430 might be a bit weak. Yesterday we bought a QX56 so we'll see how that does. M.Hony I'll let you know how it goes. Heading to New Mexico next week for first trip. Bye Bye
10-03-2014, 06:37 PM
2013 30' Classic
Greenwood
, Mississippi
Yep.
You'll have a Ram 3/4 ton next...
TAC #MS-10
Airforums #70955
10-03-2014, 07:06 PM
2015 30' Classic
Calgary
, Alberta
To be honest, you probably would have been better off with the Benz compared to the qx56. The Benz even at a smaller physical size and even with slightly lower manufacturer tow rating is a much more solid vehicle, better brakes and more precise steering .... and German horses are bigger than Japanese horses . Regardless, it sounds like it's a done deal, good luck with your choice.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
10-03-2014, 07:25 PM
2008 25' Classic
Full Time
Sounds like your ML430 was either a V6 or small V8.
Your QX56 has a 5.6L V8 and enough payload for a 23 plus extra space for extras your Airstream can't carry. It will probably do fine.
Kelvin
10-03-2014, 07:29 PM
2013 30' Classic
Greenwood
, Mississippi
The Mercedes V6 diesel has more horsepower and torque than the V8 Nissan-
TAC #MS-10
Airforums #70955
10-03-2014, 08:04 PM
2008 25' Classic
Full Time
OP didn't mention the model year or if it was a diesel so I'm assuming he had the gas version and that is why he went with the Infinity. It wasn't until the later model years a TDI version came out from what I've read. If I had a TDI and I'd only trust Can-Am to reinforce the hitch and give advice for other changes plus Andy doesn't like Equalizer.
Kelvin
10-03-2014, 08:18 PM
N/A
, N/A
Since it's ML 430, it must be 2000 or 2001 model. 268 HP and 288 ft-lb of torque. OP did not mention QX's model. If it's a newer model, it's HP/torque figures are both > 400. First generation ML was also a truck based vehicle, so not much better handling than truck based QX. And QX has a longer wheelbase. A newer model ML would be a different story. 455 ft-lb of torque and it's unibody. Anyway, QX is a comfortable and very capable vehicle. Rated 8500#. The fast lane truck did a 0 -60 with QX and it best many 1/2 ton pickups
10-05-2014, 07:53 AM
Laguna Niguel
Thanks you guys, I love this forum. Our ML is '99 gas v8, and my biggest concern was handling and long term reliability, it has 114,000 miles. Space was also a concern, we plan to tour with a couple dogs and 3 adults. The QX we found is a '09 with 50k and factory tow pkg, and rated at 9000# capacity and with longer wider wheel base and more room I felt more comfortable with the overall set-up. We have had other MLs and currently also have a QX4 for our daughter. Had tranny problems with prior ML320 at 150K hence the concern. QX4 at 140K has been trouble free car for our college student driver. Looking for a comfortable tow and a little more space as a bonus swung the decision. We'll see how it works out. Due to dogs and every day duty the PU was ruled out. It's momma's everyday driver. Car and trailer are being fitted tomorrow at the Airstream dealer and we're off to New Mexico on Wednesday, so I'll let you know how the decision turns out.
10-05-2014, 03:06 PM
2013 30' Classic
Greenwood
, Mississippi
That QX4 is essentially the same vehicle as my Pathfinder. It has been reliable for 15 years. I'm gonna try for another 15 years.
TAC #MS-10
Airforums #70955
10-05-2014, 03:53 PM
St. Catharines
, South Western Ontario
John
The Mercedes SUV's are highly praised TV's especially for Airstreams. Wondering how much experience your mechanic has towing Airstreams?
Also... for many years now we towed our 23' Safari with an Infiniti G35 V6 sedan. Works great. No problems. The car now has 245,000klm's on it.
10-05-2014, 07:52 PM
2013 30' Classic
Greenwood
, Mississippi
Originally Posted by m.hony
that qx4 is essentially the same vehicle as my pathfinder. It has been reliable for 15 years. I'm gonna try for another 15 years.
TAC #MS-10
Airforums #70955
10-07-2014, 07:57 AM
Laguna Niguel
Nice looking car m.hony, our QX4 is also black, and our ML430 is black and the new addition QX56 is black. Hard to keep clean, but the best looking when they are.
Road Ruler, I had planned to use the ML430, but it has had some issues in the past and I had some concerns. Our mechanic is certified Mercedes mechanic, but to my knowledge has never pulled an Airstream, he does pull a 20' or so enclosed auto trailer, but perhaps he was being over cautious. I have pulled large cargo box trailers with 3/4 ton pickups and know there can be some advantage with a heavier larger footprint TV. I will no doubt be surprised at how good the Airstream pulls. And finally my wife loves the QX4 Infinity our daughter has and is absolutely crazy about the QX56 ..so "happy wife..happy life". I'm confident I will be please with the bigger car, so we will find out tomorrow as we hit the road. And, hey, if it doesn't live up to expectations we still have the ML430.
10-07-2014, 12:31 PM
2013 30' Classic
Greenwood
, Mississippi
I have owned the Pathy for as long or longer than I have any vehicle. I typically hold on to them for a looooong time. I like not having car payments. If it still looks this good after 15 years, maybe the appearance will hold up for another 15 years. It is my wife's daily driver. My daily driver is a black Road King.
I wanted a black Tundra, but could not find one. I settled for silver and I'm glad I did. It nearly matches the trailer.
TAC #MS-10
Airforums #70955
10-11-2014, 11:05 AM
Laguna Niguel
Nice set-up and the silver / silver is a good choice. Well first report is in. Pulled 900 miles in two days and I'm very pleased with results. Trailer is a trouble free pull with zero sway or handling issues. The QX56 has the power for an easy tow as we set the cruise control at 63-68 and it cruised at about 1800 - 1900 rpm without a struggle. Uphill grades would kick down to lower gear and run at about 2500-2800 rpm and maintain speed. A bit more engine noise when in lower gear and a slow clime from about 60 to it set point of cruise. Could probably use a different gear ratio or a bit more torque, it does have tow mode operation which changes the shift pattern and that helped. But the comfort, one of the most comfortable seats I have driven in, and after 11 hours driving with only stops for gas and a snack I felt no fatigue. I'm sure a 3/4 quad would be a stronger TV, but I found the comfort trade-off to be worth it. And plenty of room for the dogs and back seat movies were nice for our daughter. Gas mileage for the 900 miles was 10.5 avg. More later
