Old 11-25-2014, 10:48 AM   #43
1975 27' Overlander
High River , Alberta
Originally Posted by old gray cat View Post
I tow my Airstream International 534 with a Peugeot 508 SW, (station wagon) engine size 2.2 litre. Even over the Alps! You have to take into consideration car weight/trailer weight/engine power, but your local dealer would advise on that. You don't need a big truck except for the big fellas.
I see that's a 200 hp diesel with 450 newton-metres/329 lbs-ft of torque. We need more of those small turbodiesels in North America. Notwithstanding the constraints of hitching and the law (in Europe at least), the power is there to tow 10,000 lbs, with 50 mpg (US) while not towing.
If you had a weight distributing hitch and effective yaw control, you could happily cruise at 75-80 mph.
AlbertF is offline   Reply With Quote
Old 11-25-2014, 12:30 PM   #44
N/A , N/A
BTW, Airstream International 534 has a gross weight of just 3740#, whereas Peugeot 508 SW has a tow rating of 4125#. You are well within the tow rating of your vehicle. Big trucks are still needed for bigger Airstreams.
rostam is offline   Reply With Quote
Old 11-25-2014, 01:35 PM   #45
Road Ruler's Avatar
Images: 38
Interesting, the 508 Wagon weighs about 600lbs less than a larger, more powerful, North American SHO Ford Taurus. No way a Taurus could tow an Airstream.
http://www.peugeot.co.uk/media/peuge...s-brochure.pdf
Old 11-26-2014, 12:29 AM   #46
Revery's Avatar
2014 23' Flying Cloud
2015 28' Flying Cloud
Laguna Niguel , California
Agree, I didn't mention we also used a weight distribution anti-sway hitch by Equalizer for 10,000 lb weight. And yes that makes a huge difference.
Revery is offline   Reply With Quote
Old 11-26-2014, 05:13 AM   #47
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Really? Better not let Can Am Andy hear you say that. I've towed a 30' Flying Cloud with his Taurus.
Old 11-26-2014, 07:48 AM   #48
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Why not try to pull one with a VW bug,looks like about the same thing!!!
Old 11-26-2014, 07:56 AM   #49
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Ask a truck salesman ...
and He'll tell you you should buy a truck. A big one. If you care about your family.
timhortons is offline   Reply With Quote
Old 11-26-2014, 08:02 AM   #50
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
not opinionated, but you should sell the BMW
My primary reservation on towing with a BMW 3 5 or the X family would be the german car ownership "experience" which I have reservations about reentering. VW and family being reportedly the least troublesome of the Bavarian makes.
Take the delightful 333HP M3 from 2001 for instance, 80k small sedan that needed front struts replaced with oil changes every 8000 miles. Looks awesome though. On a 3 year old 2011 the most enjoyable period may be passed.
Since my Honduca is 10 years old has 260k km and worth ~9k, I'm not as worried about it. Although somebody will probably post anyways warning me that I've voided my warranty.
Old 12-02-2014, 10:14 AM   #51
2017 25' Flying Cloud
w.springfield , Massachusetts
I still haven't seen any costs to cob up a receiver ,wiring,load rated tires, etc. for a car like the bmw ; vs just buying a good used truck /suv with factory tow package .
Every flying cloud has a silver lining !
mazoolah is offline   Reply With Quote
Old 12-02-2014, 11:43 AM   #52
Road Ruler's Avatar
Images: 38
The costs are minimal. The savings a respectable when you compare the savings in fuel the car gets compared to the truck when driving solo.
Old 12-02-2014, 12:05 PM   #53
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
People will always give you a hard time when you tow with something other than a giant truck. I even got a hard time from the Flex forum folks for towing my 2500# Caravel with my non-tow equipped Flex, because it is only rated for 2000#. The difference between tow equipped and not? A little oil cooler, which magically bumps your towing capacity up to 4500#! Even then someone told me adding the tow equipment still doesn't make it tow equipped, and if I got caught or had an accident I would be sued out of existance for exceeding factory installed tow capacity.
I'm still feeling pretty good with my choices.
Stephanie
Old 12-02-2014, 01:36 PM   #54
could you be more specific ? is minimal 500 bucks or 2000? My point as a rookie like myself ;why reinvent the wheel (or tv) rookies like me and the OP need to learn towing skills ,get comfortable with 1 1/2 tons on your rear end .not engineer a tv from scratch . Most of you guys know the ins and outs of towing an can deal with unique setups. have fun with that ,to each his own. But guys like me and the op need a cushion , and less things to worry about .
Old 12-02-2014, 02:06 PM   #55
Road Ruler's Avatar
Images: 38
Mazo.... If you are truly interested in understanding the superior towing solutions pull up the many posts by forum member "Andrew T". He writes about the many aspects you are wondering about. Thnxs for your interest.
Old 12-02-2014, 03:18 PM   #56
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
A properly adjusted hitch, setup by someone who knows what they are doing, and will instruct you on how to hitch up, on an adequate tow vehicle, will give you just as much safety cushion as you need. Using a bigger tow vehicle just because it is bigger is only safer in your head.
If you don't have the hitch set up correctly, and know how to set it up correctly yourself, and know how to handle the rig if something goes wrong, then you are no safer with either choice.
Stephanie
Could use some help - possible problem with charging system? MarshallSF Classic Motorhomes 11 03-17-2014 05:50 PM
is it possible to use the 4 pin connector on my car with an adapter? groovzilla Hitches, Couplers & Balls 8 11-25-2013 12:16 AM
lincoln town car tow car rick myer Tow Vehicles 10 03-10-2010 05:30 AM
Car Will Not Fit On Car Dolly! Chaplain Kent General Motorhome Topics 7 11-08-2006 04:46 PM
