Old 11-23-2014, 05:49 PM   #29
Urbanologist's Avatar
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area , Michigan & Texas
Yes, you can!
The key concept is doing so safely and being able to maneuver and STOP!! CanAm setup my 2009, 5.7L V8, Tundra Short Bed to properly to our Panamerica. They took me out for a spin in a 34' AS using a Taurus SHO!! Call them. They will give you ALL the info you'll need.
Urbanologist is offline   Reply With Quote
Old 11-24-2014, 03:30 AM   #30
2010 International 534
Rotherham , Yorkshire
towing Airstream
I tow my Airstream International 534 with a Peugeot 508 SW, (station wagon) engine size 2.2 litre. Even over the Alps! You have to take into consideration car weight/trailer weight/engine power, but your local dealer would advise on that. You don't need a big truck except for the big fellas.
old gray cat is offline   Reply With Quote
Old 11-24-2014, 10:34 AM   #31
2017 25' Flying Cloud
w.springfield , Massachusetts
I'm a newbe here ,just got my trailer and tow vehicle this year .But have driven BMWs all models for many years ,and done all my own repair work .You could get a lot of modification's to make it tow ,but ,and this point is lost a lot of times in these discussions, at what cost? if you are a good used car (truck ) shopper there are plenty of used pickups/suv's with factory tow packs , load rated tires ,etc. for what it would cost to convet a bmw . And while bmws are great to drive ,I think their automatic trannys and cooling systems are marginal. If you smoke a bmw tranny its 5-6 grand .and their plastic water pumps are infamous for blowing up . Their differential mounts are also a know weak point that a trailer would stress to the max. As boring as they are to drive a good late model truck is way more cost effective .
Every flying cloud has a silver lining !
mazoolah is offline   Reply With Quote
Old 11-24-2014, 10:53 AM   #32
Road Ruler's Avatar
Images: 38
mazoo... Not a BMW but an Infiniti G35 sedan (similar).
Ten years ago our car was set up by Can Am to tow our 23'.
Not much different to set up than many other vehicles. It got a custom built 2" receiver, tranny cooler, brake controller, and a set of M'Kesh mirrors.
10 years later very few problems*
*Except for regular services, a tie rod end and one rear wheel bearing. The rest of the vehicle is fine and it drives like new. Not many out there towing with a pick up have reported such few problems from their tow vehicle.
Old 11-24-2014, 10:53 AM   #33
jcl
Vancouver , British Columbia
And as a counterpoint, a BMW X5 is a fantastic tow vehicle. I had an E53, 2000-2006, rated for 6000 lbs towing. I now have an X3, rated 3500 lbs.
Plastic water pump impellors weren't used after the 90's, the X5 never had them. Automatic transmissions haven't been a failure point with heavy loads, most likely due to the factory coolers on all models. Brakes are large disks, with lots of stopping power. Rear suspension is fine unless you run very wide rubber on oversize wheels, then bushings are required from time to time as a maintenance item. OE hitch is the way to go, it reinforces the unibody on the X5 and doesn't just bolt on the rear pan. Factory trailer stability control is standard, and an OE wiring kit (everything but brake controller) is a plug in option from the dealer.
The X5 is built on the E39 5 series, same chassis and power. A 5 series would tow fine, a 3 series would be fine for trailers under 3500 lbs, or slightly more with a reinforced hitch installation. No further modifications required. Recent models with the turbo gas or diesel have excellent power and fuel economy, with good low end torque.
Jeff
jcl is offline   Reply With Quote
Old 11-24-2014, 10:55 AM   #34
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
The petite Sport (aka Bambi) weights about 3500 lbs. One other consideration with a TV is how you will transport your gear. At 16' it just doesn't have a lot of storage space.
Our preferred TV is a truck with a cap (aka topper, canopy) on the back as a means of dramatically increasing what we can take with us.
A big issue is a generator if you plan to boondock for more than a couple of nights, plus a gas can. Do you want those in the trunk of your car, or transported inside your trailer? Do you take along outdoor sports gear? (We frequently carry life jackets, canoe paddles, portaging wheels, cold-weather jackets and boots, and/or day packs for hiking.) For longer boondocks we carry a portable waste disposal tank, which is bulky.
We are about to take delivery (finally!) on our new 19' Flying Cloud. The amount of extra interior storage space (to us after 7 years in Bambi I) is amazing. But this unit weighs 4500 lbs. We decided on a new V8 truck to tow this extra weight. (And are now in the poor house. )
We mostly drive in mountainous areas, so that's another issue in terms of an under-powered TV.
Len n Jeanne is offline   Reply With Quote
Old 11-24-2014, 10:58 AM   #35
Road Ruler's Avatar
Images: 38
If we had to carry all that stuff with us we would need a truck or van too.
Old 11-24-2014, 11:59 AM   #36
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I see a lot of people saying to talk to the Dealers, but in my experience they know NOTHING about towing. Our Ford dealer, when we mentioned towing, was feeding us a complete line of BS. They had no idea what their vehicles could tow, in fact they overestimated the towing capacity of our Ford Flex by about double. What if they had sold us on that and we really did need something with 8k lbs capacity? Luckily we already knew the numbers from doing our own research, because I'm certain they wouldn't have stood behind anything they said.
CanAm on the other hand does towing setups all the time, and has their own testbeds that they actually USE for towing. They are the ones to talk to. Andrew T was very helpful when we were searching for our new tow vehicle, and we are VERY happy with what we ended up with.
Stephanie
Old 11-24-2014, 12:28 PM   #37
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
4 cylinder Sedan towing Bambi
Inspired by those on this forum who told me not to do it, this is a small spreadsheet I made while trying to decide my best setup for towing a 16' Bambi.
Engine Type Trans.
HP Torque RPM (peak HP) (peak trq)
2009 Jetta Diesel 2.0 -TDI SOHC 140 236 4000 1750 6
2014 ATS Gas - I4 2.5L DOHC DI VVT 202 190 6800 4800 6
2005 TSX Gas - I4 2.4 DOHC iVTEC 200 166 6800 4500 5
equipment
weight balancing hitch, unless you want struts through the hood !
Custom Class 3 RCVR/adjustable or welded bal thingiel.
Prodigy II Brake Controller and 7 pin connector, with electric trailer brakes (std)
transmission radiator
friction sway bar
trailers
Stock Weight GVWR Act Tongue
Bambi 16' Sport 2897 3500 350
ALTO F1743 1592+(250)? 2700? 250?
timhortons is offline   Reply With Quote
Old 11-24-2014, 12:32 PM   #38
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Fuel Economy MPG(rated) Towing Economy 0-60 w/ trailer
City Highway Highway Fuel Econ
2009 Jetta 29 40 32 reported
2014 ATS 22 33
2005 TSX 22 32 20 preliminary 7.5 15 sec?
Old 11-24-2014, 12:58 PM   #39
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
and here is a picture of same:
all threee setups were tested on the highway speeds on and off ramps , up and down hillsand in town stop and go for about 40 50 minutes .... thanks to CANAM, also rain one day and 35-40MPH winds on one of the two days
Traction was great. I never experienced any sway on either of the bambi setups, and stopping distance was great, in fact I was more worried about getting rear-ended by a tailgater than any concern about not being able to stop/avoid.
I did not do slalom, or any track type driving. The ATS with the DI boosted tourque and power had most acceleration on steep inclines and the Jetta TDI is the most composed highway cruising, but nothing was "buzzy", and of course my TSX has the best handling
ID:	227296   Click image for larger version
Name:	200X Jetta TDI, 201X ATS 2.5.png
Old 11-24-2014, 10:24 PM   #40
Revery's Avatar
2014 23' Flying Cloud
2015 28' Flying Cloud
Laguna Niguel , California
I went thru a similar brain buster. Bought a 23' FC with the thougt of towing with our MB ML430 (gas). Many forum folks said no problem, with cited experiences. The MB has a towing capacity of 5000-6000 lbs depending on who's rating you read and the trailer with food, luggage, 1/2 tank fluids and firewood for a 4 night stay would weigh in at about the same weight. I decided my family was too valuable to push the envelope and bought a larger SUV with 9000# capacity. Glad I did, not only piece of mind, accompanied by a pleasant no fatigue drive, but my first trip (900 miles one way) included over 300 miles of 30 mph crosswinds. Bigger car made it an effortlessly, comfortable and most of all fun trip to make. Size does matter.
Revery is offline   Reply With Quote
Old 11-24-2014, 11:12 PM   #41
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We chose to have enough truck for our 34' AS... before we purchased an AS... Just look at my avatar for a perspective.
Add to that a proper Weight Distributing Hitch (for my rig it is necessary) and Sway elimination...
Under 'normal' conditions, I would probably be able to tow my 34' Excella with my older 1999, 1500 GMC...
When have you seen 'normal' conditions on today's roads? Remember, you will be traveling, perhaps you will be on unfamiliar roads... so, things can get uncomfortable.
True story.. not long after purchase of our 34', I changed the 'hitch'.. it is a Weight Distributing and sway elimination setup. Returning home from a weekend trip with my wife and 3 granddaughters aboard, someone tried to pass us. Their poor judgement required me to take the 34' 2/3 of the way off the shoulder of the highway. The roadside was NOT hard surfaced.
Even tho I have towed quite a bit, this was a dangerous maneuver. the whole setup performed perfectly.. AS followed us without 'sway' or aberrant behavior... and we survived without a scratch... but AS got pretty muddy on the curb side...
Had I had the 1500 truck, this maneuver would have been more difficult... I don't want to prove this..... I can tell you, the difference of no damage that day had a lot to do with my decision to buy the new truck... and hitch system... and set them up properly...
Wish you all the best with your personal decision.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 11-25-2014, 08:37 AM   #42
Originally Posted by Revery View Post
Size does matter.
Yes and no.Yes, the larger the tow vehicle, the handling could be better.
Why a no?
Just because the tow vehicle may be larger, does not escape the fact that a proper load equalizing hitch must be used, properly installed, and properly adjusted.
Then and only then, will towing and safety be maximized.
Could use some help - possible problem with charging system? MarshallSF Classic Motorhomes 11 03-17-2014 05:50 PM
is it possible to use the 4 pin connector on my car with an adapter? groovzilla Hitches, Couplers & Balls 8 11-25-2013 12:16 AM
lincoln town car tow car rick myer Tow Vehicles 10 03-10-2010 05:30 AM
Car Will Not Fit On Car Dolly! Chaplain Kent General Motorhome Topics 7 11-08-2006 04:46 PM
