Old 04-27-2007, 12:59 PM   #1
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Is 82000 Miles Too Late ?
Have over 82K, is it too late to change to Synthetic's and get a benefit? Thank's in advance.
knunut is offline   Reply With Quote
Old 04-27-2007, 01:04 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
It's not too late. Syn will work just as good as conventional oil, but still have some better properites than conventional.
I use synthetic because I have new vehicles that get used under what the manuals consider severe service. I also use it because it has better properties under extreme heat, cold and sludge buildup. That said, if you plan on holding onto the vehicle forever, and will tow in mountains, or extreme cold, sure, but at 82k, the only benefit to you would be the properties of heat and cold. I had 170k on a 1980 307 and only used conventional oil. Though the car didn't do any heavy towing, the body was rotting off, but the engine never burned a drop of oil and the engine would have run at least another 100k it ran that well.
Old 04-27-2007, 01:49 PM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I don't know the age of your tow vehicle but with today's engines, I don't consider 87K a lot of miles. On my older tow vehicle I went to semi-synth, which I think gave me a little better protection than dino only.
For all intents my advice would be to go with synth, watch the consumption on that first go around. If you don't see any abnormal usage, stay with it. On my current tow vehicle which I bought new, I did semi-synth on my first oil change and then synth there after. I don't do more than 6,000 miles annually so that first change came about because of time rather than mileage.
The rule of thumb I've always heard was to break it in with dino, if it comes that way from the factory new. Once broken in synth should be fine.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-27-2007, 01:54 PM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
It's never too late! Even after eliptical wear has set in synthetic will help prevent further wear. In addition, the new synthetics help engines run a little cooler because of the loss of friction and breakdown. For the first few changes it is best to stick to 3K changes to allow for flushing out the old and any residue. After that changing every 5K will be fine for your older engine.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 06:11 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
7-year-old pickup rolls toward 1 million miles BobbyW Our Community 0 12-31-2002 12:13 AM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
The QUEST for 20-25 Miles Per Gallon Mr Jody Hudson Tow Vehicles 32 08-04-2002 05:16 PM
