Old 10-04-2015, 06:11 PM   #29
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Pulling off a high way at speed and pulling into a fuel station without a little cool down is hard on any engine.. Even with sync oil.. But in most cases you coast down an exit ramp.. Drive around the station in 1st gear searching for your trailer safe island,, and pull in to refuel. That 2 or 3 minutes can be applied to your cool down time.. Just a minute of idle time while idling,, the engine is sucking 100% air all that time and a very small flame to keep it running.. Things cool down real fast with that amount of air flow.. Sodbust.
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 10-04-2015, 09:18 PM   #30
Granbury , Texas
Originally Posted by idroba View Post
I have no opinion on the matter, but it does amuse me that Google is cited as the authority. It is my experience that you can find any opinion you wish to find on Google.
I wasn't talking opinions but manufacturer recommendations. There is more to google than opinions.
cabinetmaker is offline   Reply With Quote
Old 10-04-2015, 09:31 PM   #31
Granbury , Texas
During cool down if you are going over a few minutes don't forget to raise your idle using the cruise control. You can raise it several hundred rpm's over normal idle which is better for the engine.
Old 10-04-2015, 10:58 PM   #32
worried...happy...wo...ha
Knuff's Avatar
2015 25' FB International
Menlo Park , California
Originally Posted by NevadaGeo View Post
Watch your turbine temperature gauge, when it comes down to the safe temp, you can safely turn the diesel off.
Sounds reasonable.
Sorry for my ignorance about proper procedures.
Knuff is offline   Reply With Quote
Old 10-05-2015, 08:15 AM   #33
Granbury , Texas
The oil in your turbo bearings is the same oil that's in the sump for the engine. The fact that the engine oil also lubes the turbo is one of the reasons you let the truck cool down at idle.
Turbo is still spinning after engine shutdown. Usually at high RPM after pulling. A short idle will allow the turbo to slow and cool. Very good idea.
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Bridge Shut Down, I-64 west of Louisville maccamper On The Road... 6 09-12-2011 11:17 AM
Armstrong AC fan won't shut down. Flynavy Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-28-2011 06:08 PM
Sprinters: to idle or not to idle? briborg Sprinter and B-van Forum 12 06-04-2007 10:14 AM
Yikes! No Idle Adjustment - Fast Idle. lebolewis Tow Vehicles 97 08-27-2006 05:20 PM
