Old 02-06-2009, 04:59 PM   #29
Augie R.
1960 22' Safari
carlsbad , California
well the head was welded onto a bar .looking at what you just sent me i see this ting has been rigged. how does that ball welded on the side do anything ?
here is a few pics of what goes on the truck end
ID:	75145   Click image for larger version
ID:	75147   Click image for larger version
augier is offline   Reply With Quote
Old 02-06-2009, 05:52 PM   #30
1963 24' Tradewind
San Diego , California
Augier You are movin right along. The ball on the tongue, the one welded on is for a friction sway bar, it needs a ball also attached to the hitch next to the main tow ball. That way the sway bar will be connected to the tongue frame and the hitch. I don't see a place on the above pics to attach the 2nd small ball.
Also if you take your time and the fact that the AS is empty your 2nd choice for a TV should work. Good luck
Sixty3TW4US is offline   Reply With Quote
Found juel Fun & Games 2 06-08-2008 09:40 PM
Look what I found! Minnie's Mate Off Topic Forum 4 05-25-2007 05:24 PM
Found it bina Member Introductions 9 02-12-2007 02:22 PM
Found One- 1973 Ambassador! Rivetedude 1970 -1973 Ambassador 27 05-11-2005 04:11 PM
Need help? found A/S Airstreamlover Trailer Values 3 11-02-2003 07:15 AM
